Question about Averatec Computers & Internet
Fan not working/noise
Makes a bearing type noise on the adjustable type cooling fan. It will just stop working all together after a while of it trying to work. # on fan is 1232-00200000, a fuor wire cooling fan that i have had not been able to locate a replacement for. any advise would be great, thank you
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 59 Answers
Http://www.google.com/search?client=ms-unknown&site=webhp&source=hp&ei=k8--Ut6BDInkyAGexoG4DA&q=1232+fan+motor&oq=1232+fan+motor&gs_l=mobile-gws-hp.3...5859.32028.0.33429.23.19.4.3.3.0.291.2548.4j14j1.19.0....0...1c.1.32.mobile-gws-hp..8.15.1441.jipg9NOlT4A
Posted on Dec 28, 2013
2 Suggested Answers
  • 362 Answers
SOURCE: where can i find a
Hello, depends where you live! Here in the UK take it to PC World for their techies to fix for you as they'll have the correct cooling fans in stock, or, if you're adventurous, take it with you to Maplins ~(for them to see the size) and they'll sell you a fan that you can fit yourself. If you're in the USA try Radio Shack or you may have a local computer shop with a technician who'll sell you a spare, or even fit it for you cheaply. Don't even bother to take the old one apart to try and fix; it's just not worth the hassle. Regards nicam49
Posted on Dec 04, 2010
Replacing the bearing on the cooling fan
Before replacing bearing, I'd try to lube the bearings with machine oil. Any oil which is used in light machinery will do.
I had an issue with my cooling fan making noise and despite cleaning the dust it did not help. I got told to replace the fan but I was reluctant and use the oil I got with my hair trimmer to lube the axle of the cooling fan and still that did not work. However, to my surprise, after few hours the noise stopped and then I understood that the oil took some time to reach the right places to lubricate the bearings and now it's all good.
Hope that helps.
Jul 04, 2017 | The Computers & Internet
Hi, I have two of these UPS and in both the cooling fan makes a lot of noise, is that normal, or how I can do it to stop that noise. Thanks
try removing the fans and remove a sticker at the centre, to find bearings,clean them with a cloth then spray Iso-Propyl alcohol (IP) clean with dry cloth put few drops of low viscosity oil(2T oil will help).tell me if the noise do reduce.
Sep 29, 2013 | Powercom (BNT-1500AP) UPS System
Overheat radiator fan runs for a few seconds makes a grinding sound
Is the fan a viscus coupling or electric elec is mounted on back or rad viscus coupling is connected 2 engine.
If connected to engine u will need 2 replace this unit un bolts from water pump need special spanner.
Tthe other the other one is electric fan there is a control some times in hose frome engine the other type screwws in to the side of radiator this unit controls the temp that switches on fan worn out get replacement un screw and replace it hope this helps u
Sep 02, 2012 | Gentex 2004 Mercury Grand Marquis - All...
Cooling fan makes little noise now and then on my xj6.
mcdevito75, This could be some wear in the bearings of the cooling fan, keep an eye out for the noise getting worse, if so replace the fan with a new one. These cooling fans are sealed units so when the niose gets to be too much you"ll have to replace with brand new.
Jun 17, 2010 | 1995 Jaguar XJ6
The cpu fan makes noise then stops. Is there any way to lube it? It's a TP23
Most fans like that you can peel away the label in the center and put light oil on the bearing and work the fan in and out lightly to get the lube into the bearing. It is best to replace though, as they are not reliable once you have to lube. The original lube has worn out and the bearing is scored adding friction.
Sep 17, 2009 | Computers & Internet
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
Over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
Jun 03, 2009 | Sony Computers & Internet
Electric cooling fan on 1998 volvo s70 makes alot of noise when it comes on
Replace it. The bearings are going bad, or the blade.
May 30, 2009 | 1998 Volvo S70
Fisher-Paykel washer pump noise & some water left in tub
Lube the brass bearings on the motor. For some reason the bearing on the bottom nearest to the cooling fan will start to whine. I would guess because it's kicking dust up around the unit. I used a lube that will hold in place. Lube between the bracket that holds the motor together and by the fan. The noise should stop. I also suggest you lube the top bearing as well. The lube I recommend is a Silicone paste type.
Jan 04, 2009 | Fisher Paykel EcoSmart GWL15
After Recording
Unit sounds like it has a small cooling fan at the rear. A bad fan bearing will produce a noise when dried-out. Replace the cooling fan.
Jun 23, 2007 | LG DR-4912 DVD Recorder
Computers & Internet Logo
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
