Question about JVC GR D370US camcorder Mini DV
SCRATCHY SOUND I own a JVC GR-D370U video camcorder. Whenever I play back my video recordings, I have this scratchy sound that comes in and out of my recordings. It's loud enough so that you can't hear the original audio during playback. When I transferred the recordings to my computer for editing, the scratchy sound was transferred also. I tried playing the video cassettes in a Sony camcorder and the scratchy audio was still present on the recordings. Is there anything I can do to fix my recordings or my video camera, or do I just need to get another video camera?
  • Samola Oct 19, 2007
    Sorry, I don't have an external microphone. Is there anything else I can do?
    Sergeant:
  • 274 Answers
Try this also before you give in:
Sounds like you use the camera a lot.  When was the last time you cleaned the heads?  People forget this one simple thing.  For every 20 hours of operation you should clean the heads.  Try using a commercial "dry" head cleaner first. Only thing is they don't clean the rollers very well.
Note: I will always prefer to do a "manual wet"cleaning.  It takes longer, requires more work, but gets the job done more efficiently.  It is also not for the "first timer".  You need to do it a few times to get the feel and hang of it. Start with 100% methanol  and optical swabs you clean all the heads, guide pins, and rollers. (For excessive build up and for an aggressive cleaning , using 50% Acetone/50% alcohol mix.)  Once cleaned, repeat with 100% methanol to remove residues.  Let dry before inserting a tape again.
You are removing the "oxides" left behind by tape wear. It is redish brown in color and will be seen on a cotton swab after cleaning.
Posted on Oct 20, 2007
  • 363 Answers
This could be a fault with the built-in microphone.
One thing to try before condemning the camera is to plug in an external microphone and see if the noise disappears.
Good luck
Posted on Oct 19, 2007
  • Martin B
    Martin B Oct 19, 2007
    Just plug a spare lead into the socket to disable the internal mic.
    You should then be recording silence, if the scratchy noise is still there then it's not the internal microphone.
  • Martin B
    Martin B Oct 25, 2007
    Did you get this solved? Let us know what you tried.
Recording problems
Needs your head cleaning badly (no the camera heads) that will sort you out my friend.
May 26, 2010 | JVC GR-D73E Mini DV Digital Camcorder
Video camera to pc operation
Probably you need to install camera software first.
Do you have the install disk?
Oct 08, 2008 | JVC GR D370US camcorder Mini DV
GR-D370 Mini DV Digital Camcorder: i have a jvc dr-d370u and i can't format my memory...
This model can accept SD card for up to 2GB only. You may be have more than 2GB card, otherwise there is an internal problem with your camera that needs repair. Hope this helps
May 17, 2010 | JVC GR-D370 Mini DV Digital Camcorder
Looking for sofeware for the jvc gr-D370u lost
Please go to the following link to download the drivers and manual for your JVC GR-D370.
http://camcorder.jvc.com/index.jsp
After you install the drivers you would be able to download and view them on your PC.
If you would like to touch the pictures or make major changes you should consider buying additional software.Good Luck!!!!!!
Jun 09, 2009 | JVC GR-D370 Mini DV Digital Camcorder
Record directly from jvc model GR-- D370U Digital Video Camera to my pc
Sorry, but it's not possible to record directly to a PC. Windows movie maker will only record from a tape. Please use a quality cable like Belkin, I have had issues with the cheaper firewire cords.
Good luck
Oct 07, 2008 | JVC GR D370US camcorder Mini DV
No sound when playing back video footage
If there is an external microphone jack on the camera, it would help if you tried recording with an external microphone. Also, the mini DV's will mute the sound if the tape guides are slightly out of adjustment. You can tell if they have moved by trying a known good sound tape in the machine. If that plays with no sound also, the tape guides have moved out of alignment.
Sep 16, 2008 | JVC GR-DX97 Mini DV Digital Camcorder
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Audio meltdown!!
Use a head cleaner tape (available on eBay most likely) and clean the recording heads.
Mar 14, 2017 | JVC GRD650US DIGTL VIDCAM 32X ZOOM 16:9...
Sound scratchy
Seems to me that the first thing you want to do is find out if your problem comes from the camera speakers/output, or if it records them scratchy. Take one of the "scratchy" cassettes, and play them on another device to see if it transfers bad audio. If it does, then you're worst off offcourse, more of a repair. If it doesn't you can decide you don't need a repair, as long as it does the job. Good luck
Apr 01, 2006 | Panasonic NV-DS60 Mini DV Digital...
Video Cameras Logo
139 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
