Question about Toshiba E-Studio 202S Digital Copier
Copy counter How can I get a copy count
Waste ink absorber almost full
To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to "Service menu counter access".
Press OK.
Use arrow keys to scroll to "ABS-M DOT COUNT"
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Dec 06, 2010 | Canon PIXMA MP130 All-In-One InkJet...
How do I reset the maintence kit counter for an Infoprint 1532?
This is a lexmark based machine with IBM logo's
1 of the 2 options should get you squared away
---- Option 1 ----
To enter the Diagnostic Mode:
1. Turn the printer off.
2. Press and hold the Go and Return buttons.
3. Turn the printer on.
4. Release the buttons when "Performing Self Test" displays on
the operator panel.
This counter is reset by the servicer after a "80 Scheduled
Maintenance" message displays (300K copies) and a maintenance
kit is installed.
To view the Maintenance Page Count:
1. Select Maintenance Count Value from the diagnostic menu.
2. Press Return to go to the previous menu.
To reset the Maintenance Page Count to zero:
1. Select Reset Maintenance Count. Pressing Select causes the
maintenance page counter to reset to zero.
- Reset Maintenance Count Saved displays momentarily.
When the reset operation is complete, the menu returns to
the Printer Setup Reset Maintenance Count screen.
---- Option 2 ----
Maintenance page count
This counter is reset by the servicer after a 80 Scheduled Maintenance message displays
(300K copies) and a maintenance kit is installed.
To view the maintenance page count:
1. Select Maintenance Count Value from the Configuration menu.
To reset the maintenance page count to zero:
1. Select Reset Maintenance Count from the Configuration menu.
2. Pressing Select resets the maintenance page counter to zero.
Reset Maintenance Count Saved displays momentarily. When the reset operation is complete,
the menu returns to the Printer Setup Reset Maintenance Count screen.
Oct 19, 2010 | IBM Infoprint 1532 Laser Printer
Waste tray is full
Press OK.
Press Copy.
Press OK.
Press Stop/Reset.
Oct 19, 2010 | Canon PIXMA MP130 All-In-One InkJet...
How do i reset the maintenance count?
1. Select Reset Maintenance Count Configuration menu.
Mar 30, 2010 | IBM Infoprint 1532 Laser Printer
Reset maint counter
Page 3-17 of IBM's service guide
Mar 25, 2010 | IBM Infoprint 1352 Laser Printer
We have a 1025iF Canon copier. I'm trying to
hello.
the first counter 101 is total of the machine every paper that gets out of the machine(print,fax,copy,reports)and the 201 its only about copys.
Oct 27, 2009 | Canon Office Equipment & Supplies
Where do you find the counter on your Copystar system?
Depress the [Stop/Clear] key for 3 seconds. The Copy Count will be displayed on the No. of Copies display.
Pressing on the [Start] key while the Copy Count is
displayed will output the Counter Report.
Oct 19, 2009 | Kyocera Copystar CS-1620 Black and White...
Waste ink absorber nearly full. Canon pixma mp130/110. How do I empty it?
Canon MP110, MP130
1. Include the printer.
2. Press the button "Menu" , then "Scan" , "Copy" and once again "Scan" (all - fell into service mode).
3. The Arrow to choose "Counter access" , press "OK" .
4. The Arrow to choose "ABC-M DOT Count" (or "ABC-P DOT Count" - depends on that, evidences what from counter = 100 ) and press "Copy" .
5. The Button "-" throw the counter before "0" , and press "OK" .
6. For leaving from service mode to press "Resume" .Good luck! Cheat that you dispose of problems!
Sep 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
How to Stop the Counter
you can't stop or reset the counter.
May 19, 2009 | Ricoh Aficio 1035 Copier
Wrong count
FYI, if copy 1 side of A4, then is count as 1. If both sides, count as 2.
If copy 1 side of A3, then is count as 2. If both sides, count as 4.
That's the default settings on the MFP.
If u want to be copy 1 side of A3 and count as 1, u need to adjust the setting mode.
Press 08 and ON MFP, Enter 346, change "1" to "0".
Jan 28, 2009 | Toshiba Estudio 200L Copier
Toshiba E-Studio 202S Digital Copier Logo
32 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
