Question about Tablets & eReaders
My Lenovo a2109 idea tab is very touchy when charging.
It charges only when I have the cord in very specific odd positions. I checked the cord and it works in my galaxy s4 so that is not necessarily the issue. I read somewhere that the adapter needs a certain output and was wondering if that's the issue? If this is not the case then the micro USB must have a bad connection. If this is so then I would like to know what the best way to go about this would be
4 Suggested Answers
nashsaint
  • 172 Answers
SOURCE: I have been trying to
Most likely that it's faulty. Sometimes it takes awhile before it charges itself, specially it you drained. But if you left it plugged in for a day and still nothing happened then I think it's gone dead.
Try the following though and see if it helps.
1. Press and hold the power for about 10-15 seconds. or
2. Press and hold the power and the Volume up or Volume down at the same time for about 10-15 seconds.
If nothing happens then I suggest you send your tab for a repair.
Hope it helps.
Posted on May 06, 2011
JCCinema
  • 95 Answers
SOURCE: I bought my Samsung Galaxy
It sounds to me like you have an issue with your Galaxy Tab's charging port.
Fortunately it is still under warranty if you've just recently purchased it.
Take it back to the store or contact Samsung for a warranty replacement. They may be able to help you recover items from the memory.
Hope this helped!
Thanks!
Posted on Jun 13, 2011
Rocky 1942
SOURCE: Galaxy tab won't charge or
Hold the up and down button and Power on for10 seconds and that should cause the Galaxy 3 to reset. Work for me.
Posted on Nov 28, 2012
How do i fix a battery on a samsung tablet
The problem may be a frayed wire inside the charger cable right at the connector, or the charger jack may be worn or have a cracked solder connection. If it charges reliably with a different cable (such as a USB cable connected to the computer, it is probably the charger cable. If it has to be wiggled to get it to charge with a known good cable, then the charger jack should be replaced. This requires an expert technician; the solder connections are very small, and the circuitry requires special handling because it is easily damaged by static electricity.
Apr 28, 2016 | Samsung Galaxy Tab 2 7.0
Tip
DISASSEMBLING AND CHARGER CHECKING
LENOVO S5000-F - S5000-H
Checking the Computer AC Charger
When you use the computer AC Charger to charge the tablet but no power is charged, see the instructions in this topic to check the computer AC Charger.
To check the computer AC Charger, do the following:
1. Disconnect the micro-USB cable from the tablet.
2. Measure the output voltage across the connector marked B of the micro-USB cable. Refer to the following figure:
For more pictures and description check the link bellow. On search tab type Lenovo
www.electro-medical.blogspot.com/
google.com/+AjinGopakumar
on Mar 07, 2015 | Lenovo S5000 7" Android 1GB 16GB
Only have had 2 days little one knocked it down and the plug going into computer to charge broke off how can I get a new cord
Cords for most Apple products can be found at stores such as Wal-Mart and Walgreen's. You can also find them online at Amazon and other reputable e-tailers.
All but two android devices I've ever owned have used the standard micro USB plugs, also commonly available in many stores.
Odd cords for items like some of the previous samsung galaxy tab probably have to be ordered online, although I did manage to find one in an airport store once.
Apr 23, 2016 | Tablets & eReaders
How can I get the samsung tab to turn on
I'm assuming this is a new device for you. Do/did you see the battery charging icon in the middle of the screen when you plugged it in? If so, great. If not you are having a problem charging your tablet. Most likely either a bad cord, a cord that's pulled out a bit on either end, or an outlet that's turned off or not working.
If the icon was present and indicates a full charge, then simply press and hold the power button for a few seconds and the screen should start right up.
If it worked for you in the past, check your power cord. I've gone thru 3 on mine.
Aug 14, 2014 | Samsung Galaxy Tab Tablet PC
My tablet shut down and power button don`t work
try connecting to a PC using the usb cable. did you also charge your tablet ?
Oct 01, 2013 | Lenovo IdeaTab A2109
Okay when i switch my Tablet on it says android keyboard not working
check keyborad settings, go to play store and try diferent keyboard
Sep 03, 2013 | Lenovo IdeaTab A2109
Tablets & eReaders Logo
51 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
