Question about GE FQSLF Under Sink Water Filter Set 2 Filters
Replaced FQSLF water filters and the system does not work now
What is the best method for purifying water?
depends on where you are and when you want the water treated.
for camping and hiking , water purification tablets are quick and easy methods and one of the best ( used by the armed forces )
if you want it for home use
running the water through a ceramic filter then through an ultra-violet purifier will get rid of all the bugs
for larger volumes an osmosis purifying system as used by the water treatment works in council water supplies is best
so you need to specific as to when you want the water pure.
boiling water is ineffective as it concentrates the bugs and doesn;t kill them all, however distilling water by boiling off and collecting the steam back to water separates the bugs
Dec 26, 2016 | Air Purifiers
Water filter
Check to see if you turned on the water to allow water to flow again if thats not it check to see if you put the fillter in the correct way you may have put in upside down. Good luck
Apr 11, 2014 | Manitowoc SY-1204A/B570 Air Cooled 1,205...
There are 2 holes on underside of filter housing & when turn on filter water , out both holes, why I hate running it as you don't know if you are getting filtered water from both holes.Help
The main problems I'm seeing on these posts for this filter are design and operater issues. 1. I never run hot water through the unit in filter mode. 2. I never run cold water through the filter turned on high (pressure issues arise), it doesn't filter the water any faster. You just want enough flow to run through the filter. 3. The steel sleeve was a good solution (again pressure) but came up alittle short (ie my epoxy fix). 4. The light is powered by a chip batterey that is unreplaceable and may be bad. Try reinstalling the cartridge. I personally pay no attention to the lights other than a clue. I change my filter when the taste changes or there becomes a flow issue. 5.There are filter screens prior the filter that can become clogged if you live in a poor water area. 6. The filtered water only comes out of the spigot and no other leaks (something loose or pressure issue).
Sep 30, 2013 | PUR (FM-9500) Air Purifier
What can be done to repair a leak from a tiny hole on the bottom of PUR water filter?
I am having the same issue. I've just replaced the filter and it started leaking out of this hole, where it never had before.
I am thinking that maybe the filter isn't seated properly, and that's causing the leak. But I have attached a picture of the hole in question. Any advice would be helpful. Thanks!
Feb 03, 2013 | PUR (FM-9500) Air Purifier
Only one plate inside, it's glass edges are broken or deteriorate
I haven't seen an older Flair that I know of. There will be as many slots for plates as are required. The filter is definitely washable. Use an enzyme cleaner and rinse with hot water. The fan motor should be oiled every month or two. It should cost less than $100 to get it running in top shape.
Feb 08, 2009 | Ecoquest Flair Air Purifier
I have a PUR 200 water filter/hot and cold dispenser and the cold
I have the same problem as both stated earlier. The cold water is not working and the night light does not work.
Jan 21, 2009 | PUR Air Purifiers
Can't remove the filter from my Pur Flavor Options faucet mount water filter
When mine gets stuck I stick the handle of a fork or spoon into the hole where the water comes out and use that to unscrew it. Works like a charm every time.
Aug 04, 2008 | PUR (FM-9500) Air Purifier
Water filter
electronic circuit needs repair
Jun 01, 2008 | PUR (FM-9500) Air Purifier
Water Filter Leaks
Since you weren't very specific where it leaks or when it started (like after a filter change) it could be tough to troubleshoot this leak.
If it is leaking at the faucet connection try tightening up where it screws onto the faucet. Depending on your strength (or lack of) you may need to use pliers to get a tight connection. Don't go crazy tight or it will crack the plastic fitting. If it still leaks remove the unit from the faucet and check the rubber washer inside where it screws onto the faucet. Make sure it's still there and is centered inside the cup and seated properly. Then reattach the unit to the faucet and tighten it well.
If it's leaking from the main body try removing the filter and reinstalling it making sure you have seated the filter properly and screwed on the cover correctly, and all the way. When it is tight the water outlet will be exactly at the bottom of the unit. Sometimes it's tricky getting it tight enough especially with wet hands.
Finally, if the leak is coming from the filter on/off selector this could be tough to fix. I would try firmly pushing and pulling the selector knob in and out several times while in both the on and off positions. This may re-seat the leaking seal. I wouldn't be too hopeful about this fix though. You may need to replace the unit if this part is leaking.
Nov 18, 2007 | PUR (FM-9500) Air Purifier
GE FQSLF Under Sink Water Filter Set 2 Filters Logo
48 people viewed this question
Top GE Air Purifiers Experts
Are you a GE Air Purifier Expert? Answer questions, earn points and help others
