Question about Radio Shack Pro-97 Handheld Scanner
Pro-97 Scanner -- Screen Blinks every 2 Seconds
While I'm actively monitoring a station (clear audio coming across), the screen blinks every two seconds and the sound also blinks out at the same time. It's kind of annoying. Is this a transistor problem or a software problem?
No you have your priority function set
Posted on Feb 17, 2008
SOURCE:
How come my pro-84 scanner wouldn't hold the mrn frequency last weekend in richmond. Kept getting an error message. pressed hold, entered the station 454.000 and then hold again and kept getting error...
454.000 is not a station, but a frequency. it is 454 Mhz. or 454.000 Khz.
If no station is transmitting on that frequency, the scanner only will produce a hiss. Check the manual, to see how you can put in a frequency, just to monitor. Put the sq, so you just don't hear the noise and wait till any transmitter will use that frequency.
May 06, 2014 | Radio Shack Pro-84 Handheld Scanner
My monitor won't come out of sleep mode
Try unplugging the power cord from the monitor for 10 seconds and plugging it back in.
Jan 31, 2018 | Westinghouse Computers & Internet
Radio shack pro-96 scanner screen blinks and loss of audio
If the scanner's display locks up or does not work properly
after you connect a power source or install batteries, you
might need to initialize it.
This procedure clears all information you stored in the
scanner's memory. Initialize the scanner only when you
are sure the scanner is not working properly.
1. Turn off the scanner, then turn it on again. Multi-system
Trunking Scanner appears.
2. Press 0 while Multi-system Trunking Scanner appears.
3. Press 1.
4. Press ENT. Initializing please stand by. appears for about 5
seconds.
Do not turn off the scanner until the initalization is
complete. When the initialization is complete, M000
appears on the top line of the display. Bank 0 Ch 00
appears on the third line.
Notes
Notes
Jan 10, 2013 | Radio Shack Pro-96 Scanner
Mitsubishi WS-65908 will not stay on
Its a color convergence problem from description:
If green light comes on for a few seconds and goes off:
On the front of the set (not the remote) press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and release both.
Watch power light: it will blink a two digit error code, in your case I suspect it will be 2 blinks, 2 blinks and repeat several times.
Let me know error code and I will help.
Apr 16, 2012 | Televison & Video
White horizental lines across the LCD Monitor.
This is a high voltage horizontal output problem. Could just be a loose connection or an intermitant component failure. If you can get into it, check for any loose connections. Sometimes this can also be caused by a large accumulation of dust. Make sure you unplug it before opening it up.
Apr 04, 2012 | HP LP2465 24" LCD Monitor
Tv will not come on. stand by light blinks no
Sony Blinking Codes
Many of the later model Sony TV's have a built in Self- Diagnosis function. If
the timer/standby indicator is blinking, this could be an indication of the
problem with the unit. The diagnostic blinking will occur automatically with no
action required by you to engage it.
The timing of the blinking you see would be as follows: two to eight blinks
(depending on the fault) about a third of a second apart, then pauses for 3
seconds, then the two to eight blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the
number of blinks. The words in parentheses are those which you will see for
each of these faults on a diagnosis screen described later in this article.
Unit is dead and there are no blinks---Problem in the standby power
section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should
show open)
Continuous Blink Once A Second, No Pausing As Discussed Above---
No reply from the jungle IC301 (data bus is busy, shorted to ground or held
high), IK video path is defective.
ONE Blink--- not used for the self-diagnosis
TWO Blinks---B+ over current protection (OCP) , unit goes to the standby
mode then displays the 2 blink fault. Could be a short in the power supply of
any of the circuits.
THREE Blinks---B+ over voltage protection (OVP), unit goes to the standby
mode then displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single
horizontal line then the video signal muted. Check IC1509, Q1505
FIVE Blinks---AKB circuit (AKB), the timer/standby indicator blinks for about
30 seconds then goes to the self-diagnosis function. Something is wrong with
the video. Check video out, Q705, 732, 761 and other components on the C
board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking,
try turning up screen slightly.
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking selfdiagnosis
function immediately. Check C515 & 516 and the jungle IC, IC206.
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k
and the unit goes immediately into safety shutdown. Check power supply
regulation and horizontal circuits.
EIGHT Blinks---Problem with the audio (AUDIO), unit goes to standby and
blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
Intermittent problems ?? This is a great feature. You can also bring up
these fault codes ON-SCREEN to see a list of the problem numbers with the
abbreviation of the problem and the number of times this problem has
occurred. This is slightly different than entering the service mode. To see the
diagnostic screen, Press the following buttons:
Display, Channel, 5, Vol Minus, ( Not plus ) then Power. This brings up
a screen with a list of the problems and number of times they have occurred.
Each of the problem names is abbreviated as, "OCP", "OVP", "V STOP", ETC.
We have repeated them in parentheses in the text for the "Blinks" described
above so you can correlate between the diagnostic screen and the blink
codes.
So, now that you know about these self-diagnostics, how do you use them?
Say that you have a set with a black screen. You see that the LED is blinking
4 times....This would tell you that you have no vertical and that is why the
video is muted. If it was blinking 6 times, you would know that you have a
horizontal fault.
It's not a sure cure, but it's a little better than a poke in the eye with a sharp
stick.
IMPORTANT: after you repair the unit, PLEASE clear the values on this
diagnostic screen. These codes do not reset themselves after the fault is
corrected, so if you don't clear them, you'll be seeing "old" fault codes the
next time you enter this screen.
Clearing is done by going into the service mode ( display, channel, 5,
volume plus, then power ) then press 8 and Enter, which of course returns
everything to the factory preset condition.
Apr 25, 2010 | Sony KV-20S42 TV
Power light flashes four time
From the Web -- YOUR MILEAGE MAY VARY...
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter, which returns everything to the factory preset condition.
Many of the later model Sony TV’s have a built in self-diagnosis function. If the timer/standby indicator is blinking, this could be an indication of a problem with the unit. The diagnostic blinking will occur automatically with no action required by you to engage it.
The timing of the blinking you see would be as follows: two to nine blinks, (depending on the fault), about a third of a second apart, then a pause for 3 seconds, then the two to nine blinks about a third of a second apart again.
Here is a list of the problems that might have occurred indicated by the number of blinks.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
    • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
    • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
    • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
    Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
    Now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking four times. This would tell you that you have no vertical sweep, which is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault. It's not a sure cure..
    Mar 09, 2009 | Sony KDF-E502000 50" HDTV
    Sony TV
    Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article.
    Hope this may help;
    Regards,
    VOTIT
    Aug 30, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    Radio Shack Pro-97 Handheld Scanner Logo
    121 people viewed this question
    Top Radio Shack Radio Communications Experts
    Jason
    xxxxxx xxx
    Steve Allison
    Steve Allison
    Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
