Question about Exercise & Fitness
How to change fuse on blade z treadmill - Exercise & Fitness
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 163 Answers
Are you referring to the fuse on the controller? If it is, then you can remove it by hand
Posted on Jan 04, 2014
Fuse is blown = need to replace, what type of fuse should I use
How to Change Treadmill Fuses ' LIVESTRONG.COM
www.livestrong.com > Sports and Fitness
Sep 29, 2015 - If the fuse on your treadmill has blown, it's time to replace it. ... Thetreadmill fuses are located inside the elevation motor. If you don't have the ...
Treadmill blowing fuse. ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Sep 1, 2014 - I have recently picked up a second hand treadmill with an issue (York Challenger ... If I unplug the motor from the control board it will not blow the fuse, and will give ... Not sure yet, but i'll replace the IGBT's/power mosfet (I still don't know whats ... Treadmill goes high speed then blows the fuse
Nov 25, 2015
Treadmill blows fuse as soon as it starts
Sep 29, 2015
treadmill motor controller problem?
Aug 25, 2012
Treadmill Controller - No power to motor
Feb 11, 2012
More results from forum.allaboutcircuits.com
Jan 20, 2016 | Exercise & Fitness
I have a nautilus T914 commercial treadmill. What kind of receptacle do I plug it into? The motor is 230 volts.
Depends on which plug blade is horizontal and which is vertical.
You know that on a standard 2-blade plug, one blade is wider than the other. The wider one is the common and the narrower one is the hot wire. If the hot wire blade is the one turned sideways, then the treadmill is a 20 amp 220v appliance. If its the common blade that's turned flat or sideways (the wider one), then it's a 20 amp 125v appliance.
The fact that the motor is rated at 230 volts doesn't mean much in this case. The motor is a DC motor and the electronics may provide varying voltages for it for different running speeds. The motor likely may also run on pulsed DC.
Sep 13, 2014 | Nautilus T914 Commercial Series Treadmill
Where to buy replacement fuses for z16
Often these devices use the same style fuses ("blade style") as modern cars. YOu may find what you need at the automotive section of WalMart.
Apr 23, 2014 | York Fitness Z16 Treadmill
I have star trac elite it have fuse bits failed problem I also change the fuse it still have fuse bits failed problem
Then you have a short. Will need to track down the source of the short and fix it before the fuses stop popping.
Apr 11, 2013 | Startrac Fitness Products Star Trac Pro S...
Healthrider s300i treadmill does not turn on
Check the fuses under the lower hood. One should be a 10 amp fues, the other should be 15 amp fuse.
Replace them if blown. If they should blow again, move the treadmil to an outlet closer to the fuse box/breaker box of the house. the house wiring where you have the treadmill may not be adequate for the treadmill.
Jan 24, 2012 | HEALTHRIDER Exercise & Fitness
Everything works. but the treadmill motor won't start when I press the on button.
If you press start and the belt will not turn, but your incline is working, the time is counting and the speed #'s change. The problem would most likely be the lower control board. It could also be your motor. Have a professional test the motor with a DC voltage source. If it tests OK the problem is almost certainly the control board. Depending on the brand, some control boards have a fuse. Have the fuse checked and if it is bad replace it and try starting the treadmill again before you buy a new control board.
Nov 23, 2010 | Proform CrossTrainer Treadmill
Where is the speed sensor connection for a blade z
their is two place any of the treadmill either on the frame by the front roller/ pulley or on the motor itself by the fly wheel or the opposite end.
May 13, 2010 | Bladez Ion 9.9 Fold-up Treadmill
The speed sensor is under the motor cover next to the front roller on the user left side.
Mar 22, 2010 | Bladez Ion 9.9 Fold-up Treadmill
Exercise & Fitness Logo
23 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
