Question about eMachines W3611 PC Desktop
Monitor says no signal when turned on
Tower beeps three times when turned on
    Sergeant:
  • 395 Answers
Check the memory cards are inserted correctly (remove and reseat)
Posted on Dec 27, 2013
  • Steve Si
    Steve Si Dec 27, 2013
  • Steve Si
2 Suggested Answers
  • 84 Answers
SOURCE: worked fine last night, discovered it this morning
the beeping is coming from the cpu.
1 unplug pc
2 pull out ram chips
3 use an eraser to clean the gold, yes thats gold
what happens is the gold on the ram oxidizes and does not connect properly and can go bad but cleaning it with an eraser sometimes works. take a cpu that is working unplu it pull the ram and you will see the same thing your other pc is doing.
4 reinstall ram (correctly)
5 boot up cpu
6 please vote.
Posted on Dec 13, 2010
Gateway 2005 gx7022e pc was running fine and now out of no where when I turn it on it beeps three times and monitor says no signal and goes black. The tower itself is running very loudly
1)check weather the ram is properly installed on board or not
or reconnect it
2) or clean the ram with eraser n check it out
3) if still its not working den remove the ram from board n switch on the pc n check for beeps if u r getting beeps then motherboard is ok n ram has problem den replace the ram
Nov 17, 2015 | Gateway Computers & Internet
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
Emachines el1200 will not start up. When power button is turned on...it will blink shortly after ( no beeps ). It will not turn on monitor
As mentioned that when you turn on the system the lights on the system turns on and the monitor goes off, unplug the VGA cable from the system tower and turn on the monitor and check if you get signals on the screen if it shows you some color bar or a massage, that means your monitor is good. IF not then there is problem with the monitor . get it repaired or replace it. If that is not the case you would need to unplug all the external devices connected to the tower and try, IF not then you need to open the tower and check for the green light on the motherboard if it comes on or you can try reseting the memory card or if you have an video card, then you will have to remove the card and try the build in one .
Regards
Samson ved
Oct 21, 2013 | Computers & Internet
When I turn on my pc it beeps three times and there is no signal to the monitor. What do the beeps mean?
hi,
please write your beep description
ex: one long beep two short beep
repeating short beep
Sep 11, 2010 | Gateway 838GM (RB838GM) PC Desktop
Monitor not connecting to tower. it is plug in to the tower. but shows that it is not connected.
three things can be the issue here:
1. No signal from the tower (VIDEO CARD)
2. Bad cable or bent pin on the d-sub 9-15 pin vga connector.
3. Bad signal board inside the monitor itself.
Things to try:
1. another computer.
2. check the signal cable for bent pins.
3. check the video card in the tower.
Before you "think its a bad monitor" you always want to assume the computer first as computers are 9 times out of 10 why the monitor is not coming on such as BIOS errors, Bad video card, bad power supply etc etc.
PLEASE BE CONSIDERATE! When rating and leaving positive feedback for your free answer today.
May 27, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
My monitor does not light up but just clicks
if ur monitor is not coming up... check uplugging the monitor cable from the tower.... if u receive a msg on screen "No input signal" or "No VGA Signal" then Monitor is working fine... if not received monitor is not working properly.
if Monitor working... open the tower and remove memory (RAM) and switch on the pc... u should get beep codes.. if u dint get it.... Motherboard gone bad....else... try inserting RAM in other slot... even then its not lighting up...RAM problem or RAM solt problem..
Aug 20, 2008 | Computers & Internet
Black screen
The beeps are probably BIOS beep error codes. Through a series of long and short beeps the computer communicates computer problems that occur early in the startup processes. It's likely the problem isn't your monitor but something in your computer box itself. If you can tell us what the pattern is we can start diagnosing your problem. We'll also need to know the manufacturers name, the specific model computer you have and what operating system you are running.
Feb 04, 2007 | Microsoft Realsync DS771 17 Black LCD 8ms...
eMachines W3611 PC Desktop Logo
Top eMachines Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
