Question about Pool & Spa
Hot tub pump running unexpectedly
My hot tub control turns on low speed while on the off cycle. It runs for about 5 seconds and then turns off. It continues to do this every minute or less.
  • 1 more comment
  • Colin D Howard
    Colin D Howard Dec 27, 2013
    Nu Wave 2000 spa pack older model
  • Colin D Howard
    Colin D Howard Dec 29, 2013
    When it turns on unexpectedly the low pump light does not turn on, when low pump is running
  • Colin D Howard
    When it turns on unexpectedly, the low pump light is not on. when it runs normally the light is on. All functions work fine when running off of timer and air switches.
  • 3,103 Answers
Check the heater setting.. it may be the heater demanding cooler water to go through..it will cycle as needed by the heater..
Posted on Jan 11, 2014
4 Suggested Answers
  • 990 Answers
SOURCE: Motor is hooked up correctly according to
You have 220v running into your motor, the red and the plack are in most cases the same 110v line and what your calling a white netural is a common line. In other words the second half of your 220v line. If your red and black are the two opposing 110v lines that make up your 220v and they are put on the motor and turned on they short aginst each other and blow the breaker. One of your 220v lines should come into your hi -low switch and then split to your high and low on the pump. The other half of your 220v line will go to the common or what your calling nuteral. The difference is a netural completes a 110v circut and a common completes the 220v circut it will take to run the motor. One of the splits will complete the low speed circut and the other will complete the high speed circut. You need to check your voltage comming into the spa, the way the spa is wired (110v-220v), and how the motor is wired (110v-220v). For your spa this will be in your owners manuel or on a scematic inside a panel or door and is quite often a plug you change from one spot to another. On your motor will have a scematic on the back of the motor that will tell you haw to adjust the wireing already in place on the wire board of the motor. This may sound deep but if all your voltages are set the same and your high and low are the same leg of power, this should fix your problem.
Posted on Oct 31, 2009
  • 366 Answers
SOURCE: I have a 2004 great lakes hot tub with a balboa
check to see that the flow switch is working properly, it may not have enough flow on low speed to allow the heater to turn on. Make sure your filter/s is/are clean. If you have a pressure switch instead of a flow switch, it may need to be adjusted or replaced.
Posted on Feb 09, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: Intermittent jet problem on Spa form hot tub
Hmm, that's an odd one. It could be either a fault with the PCB or the pump.
The first thing to check is the voltage to the twin speed pump. If that's ok the motor is probably the cause of the fault.
As always, with anything electrical you need to be very careful with what you're doing and if you're unsure seek professional help.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 17, 2010
Just purchased a used Dream Maker X400 hot tub. It holds the water during the filtration cycles but if we attempt to use the hot tub by turning on the jets there is a major leak. Is this from one of the...
Have you opened the equipment access door and looked in it while it is running. I would look at the pumps to see if one of the seals are leaking. They will leak more on high speed and if you have a cir pump that runs the filter and an additional pump for high speed jet action it would make sense why it is leaking more while you are using it.
Oct 03, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Balboa VL700S control panel jets 1 not working
Your problem is going to be in the circuit board in the spa control box under the skirt.
You have a bad relay.
Rod
US Parts Center
Jun 25, 2013 | Pool & Spa
Aqua Flo Flo Master won't start on low speed
Water flow error on hot tub means low water flow. This is not enough water flow to turn the system on.
Some motors do have a start capacitor on them. you can certainly check that or take it to your local motor repair shop and they can check that for you.
Rod
US Parts Center
Jan 13, 2013 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
I have a GE two speed motor/pump for a hot tub that I have adapted for a type of therapy called underwater pressure massage (all of the hot tub jets are channeled through a single hose for the high...
Disconnect both hot leads from the breaker at the box. Using an ohmmeter measure the resistance to ground or the neutral bar in your box. If the resistance is LESS than about 50 K you have excessive leakage current. It is unlikely the motor is the problem. I would check the wiring and switching for the leakage. Now to the second problem: If you switch between speeds while the unit is running, the GFI will LIKELY trip. This is normal as you create a massive transient that the GFI PROBABLY can't handle. There are a couple things to try: One is using a two pole control switch and turn off the pump before "switching gears" ... as an electrical engineer I can't explain this unless you can understand electrical transients AND capacitive coupling between the windings and the case of the motor. I realize you may have a combination speed and on off switch so you MIGHT have to add a switch. Ideally I would want a relay for on/off near the breaker that momentarily disconnected before shifting gears. The next fix possibility involves a trick we use to control transients in electronics. This involves noise control by using a toroid around the pair of hot wires. This MIGHT take several turns through a good sized ferrite toroid with both the hots in the same direction, side by side. This forms what we call a "Bi-Filar" choke. Look that up on Google to understand the principle... it essentially helps balance the currents in the hots and isolates them from ground for transients.
May 08, 2011 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
Hello,I have an old jacuzzi vectra II hot tub (1988) 120 volt.the gfci on the unit trips every time the pump is on low speed with the thermostat calling for heat. there is no trip when there is no demand...
hi,
ok so when the pump is on high and the heater is running it doesent trip? you didnt say if it did. undo the heater leads so the pump is isolated completely. run the pump on the control centers gfci and see if it trips. if it does then try wiring directly - with an extension cord to a plug with a gfci in your house and see if it trips the gfci in your bathroom. if no trip inside house then bypass tubs gfci and run it with heater and pump through your bathroom gfci. if no trip then try and replace the tubs gfci, it gets pretty humid in the control center and gfci's have a semiconductor which which do fail after years of rough duty like that. if it trips the gfci in your house with the heater again it has a cracked heater element. craigslist always has old hot tubs and parts. you might have to buy a whole used old hot tub but that may be cheaper than a new heater box.
later
jm
Feb 22, 2011 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
QCA Dream Series, Mystic SPA. Drained, cleaned and re-filled. Following power restore (and 5 min or so prime cycle), the the pump runs continuously at low speed - it NEVER stops. Everything else works fine...
After refiling a spa, typicall the water is below 50 degrees F. Spas have a freeze protection in their programming so that when the water is that cold, the pumps run constantly to keep it from freezing. It will correct itself
Aug 09, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
I have a 2004 great lakes hot tub with a balboa controler. My hot tub heats up fine when the pump runs on high but the temp light never comes on when the pump runs in low.
Feb 04, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
We bought a house with a hot tub and do not have the instructions to it. We have a Manatee Electric spa heater made by Tropic Air Products, Inc manuf. 4/1997 model E-11 11 KW AMPS. We would love some...
I just looked at the exploded drawing for the Manatee. It looks like a very simple heater. The heater will simply come on whenever the pump is running and the thermostat says that the tub is not hot enough. So, for the heater, set it and forget it.
The adjustment you can make is by setting the low-speed pump timer. There should be a timer on the control box, somewhere. Generally, you set the timer to come on for a couple of hours, twice a day. During those times, the pump will come on low-speed and the heater will come on as needed.
Keep in mind that the tub will only heat when the pump is running so you will want to set the timer so that the tub has been running for at least an hour when you will be ready to use it.
Most controls will also allow you to put the pump on thermostat control, usually with a switch (timer/ t-stat). By running on t-stat control, the low-speed pump and heater will turn on whenever the temperature drops a couple of degrees.
Timer control is usually more efficient for two reasons:
1. The tub doesn't heat water when you don't need it (like while you are sleeping or at work).
2. The pump isn't cycling on and off all day and night. Cycling is not very efficient.
Tip: If you want to soak when the tub isn't hot, just turn the pump on for 10 minutes or so before you get in. That is a pretty big heater, and unless you have very poor insulation or a worn-out cover, the temp shouldn't drop too fast.
Another tip: The best way to save money on a tub is to maintain your pH. Check it EVERY WEEK! Incorrect pH will shorten the life of your heater and seals. One service call would have paid for a lot of electricity.
Please feel free to post follow-up questions.
Dec 16, 2009 | Kitchen Appliances - Others
My LG washer, model wm2277hw gives me the OE on the display. I have cleaned out all the possible areas where it could be clogged around the pump, but still makes a bad noise when it gets to the rinse...
You may have a broken pump impeller - you will have to order the whole pump (the filter on this machine allows BIG stuff through and it can ultimately damage the impeller)
Have you run this through diagnostics and determined if it is the drain or recirculating pump?
To run diagnostics:
Press and hold the "Spin Speed" and "Soil Level" buttons at the same time - then hit the power on the button
All lights should display - Press the Start Pause button throught the following cycles:
1 - Tumble clockwise
2 - Low speed spin
3 - High speed spin
4 - Prewash inlet (let it run for a few seconds to put some water in the tub)
5 - Wash Inlet
6 - Hot Water inlet
7 - Bleach inlet
8 - tumble counter clockwise
9 - Heater
10 - Circulation pump (see if your noise occurs here)
11- Drain pump (let this run until the tub is empty)
12 - Power off, finished
Once you figure out which pump, order the correct replacelement
Apr 27, 2009 | LG WM-2277HW Front Load Washer
Pump is running ever 5 minutes. The heat in the
Sounds as if the 'mode' for the tub is set to sense the temperature of the water. see if there is a setting on the control box to a 'timed' setting for filtering and heating instead of controlled by the temperature setting. the problem is the the control box is away from the water and when it calls for heat it is because the water is cooler there than in the hot tub. so when it calls for heat and the water starts to circulate it gets the hot water from the body of the hot tub and then shut down because it senses the 'hot water'. make sense?
Feb 23, 2009 | Blue Wave Aruba 15' Round 54" Resin Pool...
Pool & Spa Logo
62 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
