Question about Toro Garden
How to change drive belt
How to connect idle wheel spring
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Is this a lawn mower or leaf blower ??? model number would help us, help your faster and better...
Posted on Dec 30, 2013
Is it possible to tighten a loose belt on my cub cadet RZT-54 ZERO TURN RIDER.model number 17AFCACK009
HI,
I assume you are reffering to the mower deck pulley...however, the belt that drives the two hydraulic motors work the same way as deck pulley system.
First, there is no manual adjustment on the pulley system. Rather there is a spring loaded pivot arm to which an idle pulley is fastened to. The spring pulls the pivot arm in such a way the it forces the idle pulley to keep the belt tight at all times. The same setup is used on the ground drive belt.
Sometimes these springs become disconnected or break so that no tension is placed on the belt to keep it tight.
Check the tensioner spring to ensure that it is connected properly and applying tension to the belt. Otherwise, you may have the incorrect belt installed, the belt is routed incorrectly or the belt may be stretched out and need replacing.
Here is a diagram to clarify, the spring is the dark black item;
Here is a link to a large diagram that is easier to read;
Lawn Mower Parts Small Engine Parts Much More PartsTree com Briggs MTD...
Jul 14, 2014 | Garden
WALK BEHIND SELF PROPELLED MODLE NO. CC997ES.THE DRIVE CONTROL IS SET AT #1. IT TRAVELS TOO FAST. WHEN I RELEASE THE DRIVE LEVER, SOMETIMES IT CONTINUES TO MOVE FORWARD.\r\nDIFFICULT TO BACK UP, REAR...
I have the same issue. Just tore into it and found the return spring on the transmission idler pulley is broken. Without the spring the idler pulley arm keeps the belt engaged and wheels turning. The spring is attached to the idler arm just below the belt pulley. Looks like the trans has to come out to get to the spring. I just found the P/N for the spring. MTD 932-0849A (replaces 732-0849A) Extension Spring. Your price: $2.62
Jun 27, 2011 | Sears Saws
Mower starts, but won't move forward. I found torn belt underneath. I'm assuming this is a drive belt (are there two--one for each wheel). How do I change it out. (Best way to lift a zero turn?).
First, wedge something in front of the front wheels (when you lift the back, there's no brake action). Get the jack from your car and position it to lift the rear of the mower chassis. Jack it up then put blocks under the rear wheels - you may be able to do both at once, or you may have to alternate - then lower onto the blocks. Get enough space. You'll have to take off the mower belt and remove the PTO clutch anchor (two bolts) and may have to take off the wires connected to the PTO clutch (connector may be above the chassis). Then pull off the spring that tightens the idler arm, remove the old belt (if it's still there) and install the new one. Refasten the spring to tighten the idler, replace the anchor and mower belt, and mow away. Good luck! Please rate my answer if helpful, thanks.
Jul 05, 2010 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
How to remove a drive belt from my mercedes 560 sel 1989 I am trying to change my alternator belt, because it is broken and I need to remove the drive belt first
Not familiar with your Merc. This is general info. My porsche has a mecanical belt tensioner down low under the engine off the ground. Toyota has a spring charged piston pushing a belt tensioner wheel. Most other cars I've worked on had a pivoting alternator. If your car has a flat serpentive belt then it probaly has a spring loaded tensioner. If it has Vee belts then something sets the tension mechanically at install. Good luck!
Mar 17, 2010 | 1989 Mercedes-Benz Mercedes Benz 500 Class
How do you change belt in gilson snow blower?
a. remove belt guard
b. remove springs from idle wheels
c. remove belts from idle wheels
d. remove from drive pulleys
e. loosen belt finger (at bottom edge of top opening)
f. tip up
g. remove bottom cover
h. take belt off pulleys
i. slip belt between pulley and disk
j. reverse process to install
this is assuming it uses a friction disk
Feb 10, 2010 | Montgomery Ward (223600UP) Heater
Changing the drive belt
remove plastic belt cover
remove the guard,belt/pulley
work in the right side first:
remove the rigth-side wheel
remove the screws of the bumper
remove 2 screws on bracket/transmission assembly
pull the bracket
install the new belt
reinstall the right side screws and wheel
do the same in the left side
Ps: remove the belt guide, and reverse return spring
http://www.partstree.com/parts/?lc=troy_bilt&mn=21A-634K766+7HP+FRT+Roto-Tiller+(2005)&dn=0079200009
Apr 12, 2009 | Troy-Bilt Pony Garden Tiller
REMOVAL OF THE SERPENTINE BELT AND THE FAN BELT
you should look for spring loaded tension pully .in this pully you will find a square hole put a 1/2 inch drive ratchet (no socket) into this hole & apply pressure until belt loosens don't forget remeber the way belt came off
Jan 06, 2009 | 1995 Nissan Maxima
Fitting tumble dryer drive belt
Looking from rear of dryer,one spring on motor is for tension,therefore put belt around drum(groove to the drum surface).Then rotate the motor firmly clockwise tensioning the spring,take belt from right of drum over tension wheel then put grooves of belt on shaft of motor.Release motor to tension spring,job done !!!!!
Mar 28, 2008 | Dryers
Changing drive belt
ensure that the tensioner pulley wheel is also part of the belt loop and that it is properly sprung to take up slack. sometimes, this pulley looks good mounted in reverse, giving no tension to belt. try it the other way, against the spring force.
Sep 23, 2007 | Dryers
Garden Logo
23 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
