Question about Element Electronics PLX4202B 42 in. Plasma TV
Power supply regulator board
How do you fix
I HAVE A 42 IN ELEMENT PLX4202B IT SHUT OFF NOW I WONT TURN BACK ON RED INDICATOR LIGHT IS ON SO I KNOW ITS GETTING POWER BUT NOTHING HAPPENS CAN SOME ONE HELP ME
Posted on Oct 05, 2016
I replaced my LED board on my vizio tv and fixed my black screen issue. This was until today which was about 2 weeks after replacing the board. Is it possible my power supply board is bad?
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Feb 26, 2017 | Vizio Televison & Video
How to fix sansui sv 4230 images
The main power supply regulator section fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Jun 30, 2016 | Sansui Televison & Video
How to fix toshiba 39l350u that had a power surge? Anyone have an idea of what to look for when trying to fix myself?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 20, 2014 | Toshiba Televison & Video
How to fix a westinghouse dwm40figi that does not power on
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and precious time.
Aug 29, 2014 | Westinghouse Televison & Video
How to fix a sharp tv that dosent comes on?
It will be best to replace the power supply regulator board as card basis.
Aug 06, 2014 | Sharp LC-32SB24U 32 in. LCD TV
How do I fix flickering
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit.Contact any service technician.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.
Aug 04, 2014 | Sylvania Televison & Video
My tv will not turn on. How can I fix this?
Jul 30, 2014 | Emerson Televison & Video
Virea tv has just stopped working. Whilst watching it has switched itself off and there is no standby light or anything. All power cords and supplies are fine but it won't switch back on.
Good day!Follow this D.I.Y procedures to find the exact problem of your TV.
  1. Remove the back cover of your TV.
  2. After that,find the power supply board.
  3. If you already found the power supply,plug-in your TV and power it ON.Check the input voltage of it,using multimeter (AC range).If the power supply have no input voltage the problem could be the power cord.Replace it.
  4. If the power supply have the input voltage,try to test the output voltage if have 5vdc for the system and logic supply,12vdc for the sounds and 24vdc for the back-light inverter.Use your multimeter tester (DC range) to test that.
  5. If the power supply have a voltage outputs such as 5vdc,12vdc and 24vdc and the problem is still there.The problem could be the main board.Replace it with the same type and model # because the main board is no very difficult to fix and its very sensitive.
  6. If the power supply have no output voltage or the voltage is too low,just ignore the step # 5 because the problem is not on the main board,its on the power supply board.
Check the following to fix the power supply board:
  • Fuse: Check the fuse if it is busted or blown.
  • Power transistor (regulator): Check the regulator if it is shorted or leak.
  • Resistor: Check the resistors specially the one that have a low resistance that near the power regulator.
  • Capacitor: Also check the capacitors if it is leak or bulging top.
NOTE: If you found any defective parts or components that mention above replace it with the same value,type and ratings.
I hope this solution will be helpful.Thank you and good luck.
May 29, 2011 | Televison & Video
I plug in my tv with a 125v cable my tv and nothing happens.
May 29, 2011 | Polaroid TLA-04011C 40 in. LCD TV
HAVE A PHILIPS 15" WITHOUT
Good day!
Actually if your TV have problem like that it is not on the inverter.That problem could be on the power supply or the system board.
Apr 28, 2011 | Televison & Video
Element Electronics PLX4202B 42 in. Plasma TV Logo
78 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
