Question about Husqvarna 41 141 41 136 36 Recoil Pull Start
Starter cord will not pull
Cord will not pull out to start the motor. It appears jammed.
    Problem Solver:
  • 11 Answers
The pull cord or rope works on a tight spring just under the cover that the rope is in. Usually three to four small bolts on the edge of the cover to remove to repair/replace either the spring or the rope. First I would try to turn the motor manually with your hand on the flywheel, it should move around either direction freely with no effort. If it does not the motor itself maybe stuck not the rope. Then you have a seized engine and a different problem to deal with.
Posted on Dec 27, 2013
  • 376 Answers
SOURCE: Husqvarna 51 from 1991 too much resistance to starting attempts
It sounds like it's sorta gummed up from old gas residue. You could spray carb cleaner in the spark plug hole and into the carb while holding the throttle open and pull the cord several times and then follow that with penetrating oil to re-lubricate the engine. You're probably going to have problems with the carb also. I would have it rebuilt or, better yet, purchase a new one
Posted on Jul 01, 2009
dontbother10
  • 2220 Answers
SOURCE: wont start - bucks the pull as if out of time
Jan 1990 Special 50 IPL (example may not be you saw)
http://weborder.husqvarna.com/order_static/doc/usa/1990/I90000/I9000020.PDF
Operators Manual (example may not be you saw)
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS1982/HOUS1982_O8200003.PDF
Unfortunately there is no phone number. I suggest you stop by your local Husky dealer (ask for a repair estimate while there $10-20 applied toward an actual repair probably $60-80), they should be willing to provide you with the correct links or a phone number where you can get them.
It is old (88 or 98) enough I doubt there is a decompression valve or purge bulb.
Please tell me you are not trying to drop start this. Read and follow the procedure "STARTING THE CHAIN SAW" from the manual. If you want to attempt a repair I think this is too deep for this forum. Please try here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
This is a collection of chainsaw enthusiasts with a few professional chainsaw mechanics thrown in. Here you can post a question and get an immediate response. You can have the chainsaw at your elbow and your helper a click away. If you make a good connection and are willing you may be able converse by phone. We can't do that yet.
I would like you to do this first:
Run Lean:
Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)?
  • Remove the spark plug wire and plug. Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
  • Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
  • Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
This repair will most likely exceed replacement cost. Use your best judgment HTH
Lou
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Posted on Nov 28, 2009
  • 4088 Answers
SOURCE: I have a huskvarna 254XP and I contiue to break
The cord ends need to be melted somewhat, then an overhand knot tied to retain both ends. If the cord is breaking along it's length, the cord may not be heavy enough--check with a local saw service shop for the correct cord and buy about 1-meter of length to make sure that you are not reaching the end of the cord when pulling on it. Make sure there is nothing that the cord passes over to damage the cord causing failure. Hope this helps!
Posted on Nov 12, 2010
  • 4088 Answers
SOURCE: Compression in cylinder too strong to pull starter
We have a Husky 435 that does the same thing. Found that the engine is trying to fire after first pull. Try setting the choke at 1/2 after first pull, but don't bump the throttle which will release 'fast idle'. This process seems to limit the 'kick back' effect. It also helps if you have a strong arm. Good luck!
Posted on Nov 25, 2010
plink_plonk
  • 1807 Answers
SOURCE: Saw starter pulling too hard to start.
Check piston rings. Sounds like you have a seized engine.
Posted on Feb 21, 2013
The manual recoil starter I pulled starter slowly two or three times and then cord was loose no resistance what is the problem?
Sounds like the starter drive is jammed. Look for a large cog azt the back of the starter cord on the motor, manually push it in the opposite direction to the spin created when the cord is pulled.
Dec 29, 2015 | Garden
130BT Blower can't pull start cord.
Can be a couple issues. The obvious is seized. The other is a broken jammed connecting rod. I would put some oil down the plug hole and let it sit overnight. Then after a day or so...try again with the wratchet. In both directions, forward then backward just to try and free it.
Nov 22, 2015 | Husqvarna 130bt 130 Bt Gas Powered...
Ryobi petrol chain saw jammed, prior to this it happeningit was not running on idle so I thought was the problem and tried adjusting the idle screw but it made no difference...undid cowling and put a
I'm not sure what you mean by jammed. If the engine was hard to pull the cord then you probably tripped the chain brake. Most chainsaws all you do is pull back on the hand guard to reset the brake. If you are adjusting the idle you will need to have it running then turn the screw until you have the desired engine rpms.
Feb 12, 2014 | Ryobi Garden
Hello I have an echo pb-500T, my cord won't pull.
Remove the impeller and check for loose motor mount screws. With the impeller off and the spark plug removed and the pull start functioning properly; if it still wont pull then its likely internal and due to be replaced.
Oct 24, 2012 | Garden
Very hard to pull cord
Hi Marco:
You're not alone with that problem. My 266 will barely pull over after sitting for a few days. After a couple of pulls it loosens up and starts fine. Hot starts are also easy. It did not completely solve the problem BUT THIS SURE HELPED. I took the starter assembly off the saw. The narrow reel that the pull cord feeds into had spread which allowed the cord to wedge in against itself. I replaced the reel and here's the important part, MAKE SURE YOU USE A LARGE DIAMETER PULL CORD. That way the cord will lay on top of itself and will not wedge the reel apart.
Gotta love those old Husky's!
Mar 15, 2012 | Husqvarna Models 61-66, 266, 268, 272
Pull start mower, starter cord jammed
Remove the top cover to your engine and any attachments. Check to see if the cord has jammed into it's reel. Also is the cord to long, or damaged. You may need to replace your cord. You should be able to find your problem. GOOD LUCK.
Jul 08, 2011 | Garden
Starter cord jammed on my mcculloch cabrio 433l strimmer, only pulling a few inches
First remove the spark plug and see if the starter can be pulled without the plug in place. If it cannot, any job that involves a recoil starter is a messy frustrating job, and if you had to put a price on the hassle that it is, it is probably better to pay somebody else to do it. That said, remove the starter cover with the cord and pulley inside. If there is a plate holding down the cord pulley, remove it and carefully lift out the pulley, try not to dislodge the recoil spring as this is where the frustration part comes in. Check the cord is not off the pulley or is frayed and caught on something. See if the starter will operate when it is removed from the motor.
If you need to renew the cord, insert the new cord end into the hole and copy the old knot - pass the other end of the cord through the eyelet in the cover. N.B. At this time take note of the direction that the recoil spring coil is orientated. Wind about 3/4 of the cord around the pulley and attach the start handle to the outside end of the cord. Carefully fit the pulley over the spring and place the cord into the cutout in the pulley. Wind up the pulley so that it engages in the curl in the inside of the recoil spring and further wind up the pulley in the opposite direction of the normal pulley start pull, holding the cord in the little cut-out so that the cord does not wind up as you wind the spring. It probably takes about 5 extra turns on the pulley to get the recoil tension right. Always hold the pulley in place to prevent the spring from jumping out. Release the cord so it can retract and replace the retaining plate. This is all if the spring does not jump out - which it so often does.
If the spring jumps out, hold it by the inside portion and start winding it up, pulling it tight to keep the coil small enough to fit back into its receptacle, . Once the spring is wound up and will fit into its position the problem starts. I found that gripping the spring with an alligator jaw vice grip will allow you to replace the spring and carefully release it without it going wild again, engaging the outer hook in its retaining slot or around its peg. Trying to feed the spring into position coil by coil seldom works, it has to be wound up outside and then inserted, especially on a small motor.
This procedure is as difficult to explain as it is to carry out. I have done many cord replacements and always dread the next one. If you have any problems, feel free to come back to me.
May 26, 2011 | Garden
The pull cord on my homelite weedeater is jamming and not able to pull it all the way... can't see anything that is jamming it and does not appear broken.
Sounds like the cord is caught in a slot on the side of the pulley the rope recoils into. The cover will have to be removed and maybe some additional things but it can be fixed fairly easy with some patience.
Jun 09, 2010 | Homelite Garden
Weedeater gas blower FLI500E. The pull cord has become jammed. How can I un-jam the rope pull? I have removed the bottom of the blower and can get the rope pulled out, but it will not retract properly or...
You have to find a way to push the starter. It normally gets all stuck due to grease. One push with a screwdriver on the actual starter (The thing the rope turns) should wind the whole cord up. If not, clean it. Alot of oil/chunky-ness gets trapt when your using it.
Apr 27, 2010 | Poulan Weed Eater Electric Blower/Vacuum...
I have this Toro trimmer/edger.Can't pull the starter cord
you must take apart the cord recoil and rewind the pull string,inspect string make sure its the same thickness through out if not replace it, not too hard i believe you can do it.
Apr 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Husqvarna 41 141 41 136 36 Recoil Pull Start Logo
364 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
