Question about Watches
Instructions for setting skechers watch
Sttmr-007 setting instructions
Instruction manual for skechers quartz model number sr6103
Try Googling (skechers)(sr6103)(manual) without parens.
Apr 14, 2018 | Watches
Skechers SR2011 watch reset instructions
Try Googling (Skechers)(SR2011)(manual) without parens to get reset instructions.
Mar 10, 2018 | Watches
How do you set a Elgin Sportsman GF010-007 watch
Not familiar with this watch, but try this other FixYa answer :-
rfhutchinson
SOURCE:Elgin Sportsman How do I set the time?
Simple..there are 4 buttons on this watch. Right?...All four buttons push in...no kidding....HOWEVER the button at the five(5) oclock postion...PULLS OUT...this is the key..because this only button, pulls out, i
The digital display starts to flash....just experiment with pushing any button, BUT the five oclock and you should be able
To figure it out. After its set, then push the five oclock back to its origanal postiton...
Nov 20, 2017 | Elgin Watches
Where can i buy a strap for my skechers watch?
Check this place out they have both the watches and the bands.
http://www.lazada.com.ph/catalog/?q=sketcher%20watch%20band
Apr 28, 2017 | Watches
How do you set a womens sketchers sr6007 analog-digital watch?
I think you mean SKECHERS. Try Googling (SKECHERS)(sr6007)(manual) without parens.
Aug 29, 2016 | Watches
Need instruction manuel for elgin fg010-007 sports watch
The movement in this Elgin is made by Citizen. After you change the battery, you need to reset the hands so that the watch functions properly. Select chronograph function with lower-right button. Then pull-out the same button. Push the upper left button to select the UTC, hour, and minute hands. Then use lower-left and upper-right buttons to make sure everything is aligned to 12:00 position. After setting the hands to 12:00, push in lower right button. Now you can set the time by selecting the SET using the lower right button. Pull out the same button and choose your time zone to set.
Feb 28, 2009 | Elgin Watches
Left hand side winder
The crown on the left side is HELIUM VALVE and is designed for compensating and keeping the right air pressure inside watch case if it is used for diving purposes.
If you will try to set something using this crown, nothing will happen, as it has special springs, gaskets and bars built into it, but has no any connection with watch movement.
Do not forget to rate, please.
Jan 29, 2009 | Omega Seamaster James Bond 007 2220.80...
Watches Logo
702 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
