Question about Pioneer Audio Players & Recorders
Display axx7107 My display can inkt low
2 Suggested Answers
SpideRaY
  • 687 Answers
SOURCE: I`ve got the message on the display print
Check out my Borther DCP-340CW Fixya Tip here
http://www.fixya.com/support/r4065602-dcp_340cw_machine_error_46_photo_capture
Posted on Mar 14, 2010
Kan de handel rechts niet optillen? Zijn er meer mogelijkheden?
In de hoop dat dit helpt . U moet de printer op om verandering inkt / head . Je kan hebben om te gaan door de printerinstellingen en vertel het om inkt te veranderen .
Jan 15, 2015 | Canon Office Equipment & Supplies
Tip
BOSE RADIO CLOCK/STATION DISPLAY DARK
This problem is caused by two tiny burnt out bulbs behind the LCD display thay are soldered to the circuit board behind the radio LCD display and can be replaced, this requires the radio be removed and the housing taken off and the front display un-clipped, you will need a low temperature solder pencil and thin strand solder the bulbs are available from Radio Shack, the part number is 272-1092, this is a 2 pack of miniature 12 Volt 60Ma bulbs. This radio display bulb is used in may car models, this bulb also repairs climate control displays as well as other low light displays like switches
on Jan 31, 2010 | Chevrolet Corvette Cars & Trucks
My computer on my Schwinn Airdyne's numbers are only half showing. Is it low ink
the displays use LCD in the display not ink it sounds like the battery(s) are low see about replacing them and the display should return to normal if the batteries are new the display might be damaged due to age, heat, or physical contact with the display i.e. pressing the display, hitting it, something fell on it
Jun 04, 2014 | Schwinn Original Airdyne
Een dikke zwarte streep op de achterkant van het papier, bij eerste afdruk na opstarten van printer
Mijn 4 jaar oude Canon MP500 begon ook een brede zwarte streep te trekken aan de onderkant van het papier. Dat gebeurde na iedere reiniging van de koppen, de eerste paar velletjes kregen een zwarte streep en daarna was het meestal goed totdat de printer zijn koppen weer reinigde.
Bij het reinigen van de koppen wordt met een soort pompje wat inkt door de kop gezogen. Deze inkt wordt via een slangetje afgevoerd naar de ruimte tussen de bovenste plaat en de bodemplaat van de printer. Een groot deel van de bodem van de printer is gevuld met een soort vilt dat de inkt kan opnemen. Zolang het vilt inkt opneemt is er niets aan de hand, maar bij mij was het vilt rondom de uitstroomopening van het slangetje helemaal verzadigd met ingedroogde inkt. Daardoor kon nieuw aangevoerde inkt alleen maar omhoog tot aan een aandrukrol voor het papier. Dit aandrukrolletje bracht de inkt keurig over op de onderkant van het papier.
De oplossing is de printer uitelkaar halen en de overtollige inkt in het binnenste verwijderen. Dat is een vies werkje waar je echt even voor moet gaan zitten, en als je niet handig bent kun je er beter niet aan beginnen.
Trek alle kabels (vooral de 230V) uit de printer en zet hem op een goed toegankelijke plek waar je een dikke laag kranten op hebt uitgespreid. Eerst verwijder je de zijkanten door 2x2 schroeven los te draaien. Het lipje aan de voorkant moet je vervolgens (een beetje) naar voren trekken zodat het los komt. Aan de achterkant is een schroevendraaier in de naad handig, de zijkant komt dan los en kan naar beneden toe worden verwijderd.
De veer van de scanunit krijg je los door aan de voorkant twee lipjes opzij te buigen. De scanunit is nu vrij, maar is nog verbonden met de printer met 3 massadraden, een connector met 4 draden en twee flatcables. Die moet je met moed en beleid loshalen, en noteer even wat waar zit. De draden loshalen is geen probleem, met de flatcables moet je heel voorzichtig zijn, zo dicht mogelijk bij het connectortje vastpakken (daar is de flatcable iets dikker) en voorzichtig er uit trekken.
Nu kun je de kap loshalen (4 schroeven).
Dan kan het printermechaniek worden verwijderd van de bodemplaat door 4 schroefjes te verwijderen. Om bij de vierde te komen moet je de voeding loshalen: een connectortje bovenop losmaken en aan de onderkant twee lipjes opzij buigen. De voeding komt dan naar onderen uit de printer.
Maak alles enigszins schoon, verwijder in ieder geval alle dikke lagen inkt. Dan weer alles in elkaar zetten. Als je geen magnetische schroevendraaier hebt, kun je ook tijdelijk een dun draadje om de schroefjes wikkelen om ze op de goede plek te krijgen. Denk er aan om de schroefjes die in kunststof worden gedraaid, eerst even de verkeerde kant op te draaien. Je voelt dan een klein klikje waardoor je er zeker van bent dat de schroef precies in de oude draad komt. Doe je dat niet, dan heb je een grote kans dat je het schroefje dol draait. De flatcables hebben maar aan een zijde contactjes, dus steek ze juist om in het connectortje.
Als alles weer in elkaar zit doe je een schietgebedje , sluit de printer aan en testen maar...
Feb 07, 2011 | Canon Pixma MP500 All-In-One InkJet...
Code 0xc05d1281 inkt problem
Hi there ok
The "Ink System Failure" error is causes by air in the ink feed tubes.
I hope this helps, If so please rate our solution.
Please perform the following steps in order:
1. Press and hold the “*” key.
2. Press the “#” key and release both keys.
3. Display should say “Enter Special Key Combo”
4. Press and release in sequence the “1”, “2” and “3” buttons.
5. Screen should say "support" R0631M"
6. Press and release the right arrow button until the display says “System Configuration Menu”.
7. Press and release the “OK” button.
8. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
9. Press and release the “OK” button.
10. Display should say “Hardware failure status: Clear. Press OK to clear”.
11. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
12. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
13. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
14. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
15. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
16. Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Feb 07, 2010 | HP Photosmart C6280 Printer
DISPLAY LIGHTS NOT WORKING
If the display is burnt out then the low voltage board will have to be replaced.
Feb 02, 2009 | Viking 48 in Built In Professional...
Canon MP180 Ink Problem
lads ye're all I work in an 'ink place' and the u051 fault is a fault indicating that the offending cartridge is electrically dead, this is caused by the clever little program in the canon machine that writes info to the cartridge to make it'dead' so it cant be re-used ! possible solution is to get refilled before printer thinks it empty !!
Feb 09, 2007 | Canon PIXMA MP170 All-In-One InkJet...
117 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
