Question about Bosch Power Tools Bosch 4100-09 Worksite Tablesaw W/ Wheeled Stand
Blade on table saw will not raise
Blades lowers fine but is hard to raise
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 75 Answers
Typically this is a thrust washer issue. need to look at the play between raise and lower..also ensure trunion is cleaned and lubed.
Posted on Jan 13, 2014
How do I raise and lower the saw,.
if it is a table saw, there is a crank on the front that raises and lowers the blade. there should be another on the side that angles the blade.
May 26, 2015 | Saws
I can't raise my table saw blade when I crank the handle
My DeWalt Table saw does this,and for me its cleaning with a air compressor and nozzle. I cand seem to prevent it though. I tried grease on time and it just plugged up faster. I want to try a gravite lube next. To me it seems to be a desiegn flaw and I just clean the spline thead shaft that lowers and raises the blade. So far I just settled into a maintance air spray and it seems to work well enough.
Apr 07, 2014 | Ryobi Bt3000 Bt3100 Dual Slot Miter Table
How to raise and lower saw blade
You raise and lower the table plate, NOT the blade. There is a knob to lossen and tighen the tension on the table plate and you can adjust the blade height by lowering the plate and vice versa.
Jun 20, 2011 | Dewalt DW364 7 - 1/4'' Heavy Duty circular...
I can no longer raise or lower the blade on my 10" sears table saw' model # 113.298032.
After some use the threads on the raising mechanism can become clogged with sawdust and resin.
UNPLUG the saw and look underneath up inside the box. there is a rod that runs from the wheel you turn to raise and lower the blade into the actual mechanism. Brush it clean and give it a good douse of WD40 to help clean it. That rod must turn freely so look for any obstructions that will prevent that from happening
Jan 18, 2011 | Craftsman 10" Table Saw
I cannot easily raise/lower my blade on my Craftsman 10 inch table. I've cleaned out the say thouroughly and nothing appears to be obstructing mechanism to raise/lower the blade, but yet, it takes two...
mine did the same and i sprayed WD-40 on the assemblys or large screws and keep working it until free. but, check things over because some had a lock so the blade wont move after the hieght is set.
Dec 19, 2010 | Craftsman 10" Table Saw
My 10 inch saw is 20 years old. It is very hard to raise and lower the blade. Everything is clean yet it is very hard. Any ideas?
over the years the yoke nut the screw goes through has built up grit . Spray the screw with WD 40 as you raise and lower the blade , also look to see as you turn if screw is bent.
Oct 27, 2010 | Craftsman Saws
Raising and lowering the blade is really tight.
what I do is turn it over and using compressed air blow out as much of the dust as you can and then find a dry silicone type lubricant to thoroughly spray the threads and the slide portion of the saw. let dry and then move blade up and down a few times, you might have to repeat this but it works.
May 23, 2010 | Dewalt DW744X 10" Portable Table Saw
MAKITA #2703 table saw 10'' to rise and lower blade it
i would say the table is twisted then, strip it down first and if you need to "bend!" it back so it works
Mar 27, 2010 | Makita 2703 10" Table Saw, Electric Brake
How to change the saw blade
Adjustments
LARGEHEXWRENCH
TO REPLACeTHE BLADE
See Figures 43 - 45.
 Unplug the saw.
 Lower the saw blade, raise the blade guard, and remove the throat plate.
 Make sure the bevel locking lever is securely pushed to the left. Raise the saw blade to its full height by turning the height/bevel adjusting handwheel clockwise.
 Using the smaller hex wrench, insert the flat open end into the flats on the arbor shaft.
 Insert the closed end of the larger hex wrench over the hex nut. Holding both wrenches firmly, pull the larger wrench forward to the front of the machine. Make sure the blade nut is securely tightened. Do not overtighten.
Check all clearances for free blade rotation. See To Set the Scale to the Blade. In cutting operations, the scale will be set to the side of the blade where the cut will be measured and made.
To replace the blade with an accessory blade, follow the instructions provided with the accessory.
To install a standard blade:
 Place the new blade on the arbor shaft (the teeth must point down toward the front of the saw to work properly).
 Place the blade washer and the blade nut over the blade arbor. Be sure the dome side of the blade washer faces out from the blade and that all items are snug against the arbor housing. Tighten securely.
SMALLHEXWRENCH
Fig. 43
Blade
Bladewasher
arbor shaft
Bladenut
Fig. 44
BLADEGUARD
THROATPLATE
spreader
BLADE
Fig. 4535
ADJUSTMENTS
 Rotate the blade by hand to make sure it turns freely.
 Lower the saw blade and reinstall the throat plate.
NOTE: Securely tighten throat plate screws. Do not allow the throat plate to bow up above the table surface.
Sep 18, 2009 | Saws
Bosch Power Tools Bosch 4100-09 Worksite Tablesaw W/ Wheeled Stand Logo
188 people viewed this question
Top Bosch Power Tools Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Power Tools Saw Expert? Answer questions, earn points and help others
