Question about JVC LT-42E488 LT42E488 42 inch 720p Flat Panel LCD TV
JVC LT42E488 Color Issue
The color on the screen is very yellow. I was told it may be the color tube that went out and I may be able to fix it by replacing the main board. I need to know what I do to fix the color so that I buy the right part!
  • JVC Master
  • 9,639 Answers
If you have a flat screen LCD TV then there is NO color tube. Somebody is blowing smoke. Don't deal with him. The main board in conjunction with the screen controller board are the places to look.
Posted on Jan 06, 2014
5 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: NEED A 42 INCH JVC
Here is a link to a website that sells the original stand that came with the TV. : )
http://www.retechtv.com/products/jvc-lt-42e488-tabletop-base-pedestal-stand
Posted on Jul 26, 2011
SD Tech
  • 14553 Answers
SOURCE: Its a 2004 48in JVC Flat screen the color red is
look anything like these
Posted on Apr 10, 2012
gopakumarg43
  • 74243 Answers
SOURCE: Color is Messed up on my JVC PD-42V485 There is More green then any other Color Help!!!!!
There are many reasons for this fault, that occurs with a plasma display. Without seeing its present screen, nothing can be adviced. If you wish to get more details about these faults to Plasma Displays, check this link. http://electronicshelponline.blogspot.com/ . It has screen shots to many faults that can occur to a plasma display, and measures to taken to rectify it. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Posted on Jun 26, 2013
Testimonial: "I posted a pic of what the T.v is doing"
rjpoirier_nb
  • 166 Answers
SOURCE: Power supply board not the problem- need further input please
Typically if one inspects the boards in question you may find evidence of heating and damage. Sometimes with newer solder having no lead, hot spots tend to leave cracks around the joints of parts heating and cooling and once they arc they fry components. One can usually smell a burnt component altho hard to describe the smell. I would look for burnt fuses on the power board where the power first enters the back of the tv, and some fuses are covered with a plastic sheath and looks like another type of component. A tester comes in handy... I suggest that you look more at the board that gives the high voltage to the TV screen, as there are step up transformers (square blocks) that give a lot of trouble and the transistors surrounding those blocks, usually 4 transformers. I would test for continuity around these areas but the transformers should be pulled from the board for a more accurate test. Inspect transistors (black with three prongs) usually has an aluminum heat - sink attached to it for cooling, anything more than 3 prongs is probably an IC or integrated circuit chip. These are more difficult to test. A diode will allow power one way but not the other so reversing the polarity tester tips will give you a voltage or nothing in reverse. Transistors are similar to a diode in that you can test it one way but it shouldn't be a reading the other to try to keep things simple. Typically when a transistor goes it will burn a hole in the face or on top. A capacitor looks like a mini soup can and swelling on top a hole on top or liquid stain under it is an indicator that it's bad. Typically the top is swelled and the plastic coating bares most of the top of the capacitor. If one inspects other capacitors in that area you can notice the difference even though indicators are slight at times. I would at very worse put the screen part away until you found a suitable tv model with a broken screen perhaps on kijiji. Typically it is a capacitor that has blown but may only lead to a partial solution to the problem if several parts are gone which is usually the case, a capacitor or two as well as a transformer or a transistor; and one must also inspect and test other components in that same area for success and to inspect the circuits for cracking around components especially where the hot areas are and one can usually see these hot areas due to the discoloration of the board in these areas. These hot areas are usually the problem. One overall solution is to build a big fan into these tv's lol and put surge protector bars on all your expensive electronic components.
Posted on Dec 05, 2013
THE COLOR WENT OUT ALL OF A SUDDEN
If the model listed here is correct--tell me if different-- it is a problem related to the picture tubes this model uses.
Apr 28, 2012 | JVC AV48P776 48" CRT TV
My sony plasma fwd 42-pv1 color tube has broken how do I go about fixing it?
If some kind of color smearing or pixels doing that this set has not color tube and only boards that can be purchased and tried for the issue--could even be the power supply board in the set--too vague a description for more of an answer--ie: does it do it all the time or on rear inputs etc---sound not important with this issue.
It sounds like the repair center was giving you a story.
If you call Sony with the model number and describe the issue (you want to talk to a tech) they will know from their database if this is a known issue or not.
Mar 29, 2012 | Sony FWD-42PV1 42 in. HD-Ready Plasma...
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Dropped tv and now i only get purple and yellow as the tv colors
hi..It sounds like your tube Shadow Mask may have got
magnetised and need to be degaussed.turn off your TV
at the mains and unplug it for at least two three hours,
after that time power up your TV it should degauss the
tube at power up.
try this out..
thank u..
kindly rate my response..
May 06, 2009 | JVC AV-36260 TV
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
JVC AV_48WP30 Screen loses color, everything is in like negative color
Sounds like shading, caused by convergence IC or bad solder connections in convergence circuit. Check the CONVERGENCE GALLERY for shading.
JVC design is generally reliable. It is extremely unlikely that you would have 2 unrelated failures.
If you are in Canada, email me.
easyab
Oct 27, 2008 | JVC AV-48WP30 48" Rear Projection...
Dell 5110 cn
Your problem is not fully explained above as to which color you are having difficulty with, however, the explanation below will more then likely apply to your issue as well. Simply substitute "yellow" for the color you are having an issue with. This is the explanation I gave to another user who was having problems with "yellow prints lite".
If you let the yellow ( or any other color ) toner get to the point where the toner cartridge was totally empty, there is one thing you can try which may help. From the "menu", select "maintenance", then go to "clean developer" and choose the ( which ever color ran low ). The machine will then churn for a few minutes. What happens is there is a tube that moves the toner from the toner cartridge down to the developer unit ( which is behind the imaging drum). If the toner was allowed to totally run out, there is an area of the tube which may have little or no toner in it. Each time you print, there is a spring auger within the tube that draws the toner to the developer. By running the "clean Developer" it turns the auger and re primes the tube.
If this does not fix the issue, and you have replaced the imaging unit, then the (insert color ) developer is defective and would need to be replaced.
This involves quite a bit of work and is not considered user replaceable.
Sep 13, 2008 | Dell 5110cn Laser Printer
42 inch hitachi projection tv. green tint told it might be color wheel
sounds like your picture color tube may have went if the tv can not be adjusted with the remote or on the tv itself did you try every color or picture button on the remote and the tv itseff and if it is old i would get a new one if not have it fixed , sincerely john
Aug 01, 2008 | Televison & Video
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
Open Questions:
See all JVC LT-42E488 LT42E488 42 inch 720p Flat Panel LCD Questions
JVC LT-42E488 LT42E488 42 inch 720p Flat Panel LCD TV Logo
133 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
