Question about Refrigerators
Have GE side-by-side and am replacing white door panels and would like to replace white ice/water dispenserwith black one. GE no longer makes the parts. Can you locate? Refrigerator model is ZISW42EMD. Part nos. are WE38X5413 (door trim); WR55X20 (control panel) and WR2X7891 (grill)
  • breiter May 18, 2009
    the response I received had ABSOLUTELY NOTHING to do with the question I posed
    Novelist:
  • 130 Answers
You will not get the exact same part with that same number but yes
you will get the same type of compitable parts at
www.repairclinic.com
or at
www.partselect.com
check out
thanks.
Posted on May 18, 2009
  • 483 Answers
I've replaced this part in 5 minutes on my side by side without removing the door or unplugging electrical wires.
1- Pull off the vent grille at the bottom of the fridge.
2- At the lower left, disconnect the tube that is coming from the freezer door.
3- Push the LOCK button to prevent water from comming on to your face. Remove the screw at the water spout.
4- Pull the water spout and the connected black hose out of the door.
5- Thread the new hose and spout through the door, then reconnect at top and bottom.
Project DONE!
Provided i am talking about an older version ,, ?
Fame !
Not making ice cubes
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Ice and Water not dispensing. Light button not working
http://www.repairclinic.com/0100_1.asp
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Jul 04, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser is not working.
replace the filter.
if tht dosent work replace the water valve....
Apr 10, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
GE no water through door
I would look for a clogged strainer on the incoming water line, or a chunk of mineral buildup somewhere in the door water circuit.
This assuming of course, that water came through the line when you replaced the water valve.
Jan 21, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GE side by side with ice and water in door
This is a problem with my GE side by side also. It only happens occassionally and there doesn't seem to be any fix. I've had GE repair service here more than once. It seems that the insulation in the door is insufficient to keep the water line from freezing up. Small wonder GE is part of this awful financial mess.
Dec 17, 2008 | GE 23.1 Cu. Ft. Side-by-Side Refrigerator...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
INSIDE THE DISPENSER ASSEMBLY IS A SEPARATE ELECTRONIC BOARD THAT CONTROLS THE DISPENSER.
OCCASIONALLY, THE DOOR SOLENOID OR THE CUBE ICE SOLENOID WILL SHORT OUT CAUSING A BURNOUT OF THE DISPENSER CONTROL BOARD. CHECK FOR A BURNT SMELL COMING FROM THE DISPENSER HOUSING. IF YOU SMELL IT, THE BOARD AND/OR SOLENOID NEED TO BE REPLACED.
Apr 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I had GE come out and look at it. I wasn't home to ask questions. The repair man basically said it was a 'loose connection' in the back which is where the motherboard is for all the electronics. It took him less than 5 minutes to fix and he was gone.
Thankfully - it cost me zilch. I told a small white lie and said we were still under warranty and they didn't ask to verify. Can I get an Amen!
Oct 20, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
