Question about Elements Of Design Hot Springs Polished Brass Mini Bathroom Faucet -
Need "exploding diagram" of the plumbing around my hot tub!
I am trying to find an "exploded" type diagram of the plumbing in our 1995 Hot Springs Sovereign Hot Tub. We have a huge leak and know what is where around the hot tub, would be a great help in trying to trace and fix it! I pick washing machine expert because it was the only one dealing with water! Can you please help anyway?
  • 34 Answers
Contact them I put a link below....I don't haveone but I was told when they called me back that they could email or fax one to you. It only took about an hour before they called me back.
http://www.hotspring.com/Hot_Tub_Customers/service_request_form.html
Posted on Oct 28, 2010
6 month old jacuzzi hot tub has started leaking intermittently , any help here to solve this problem
remove front panel visually inspect pumps to see if leaking if ok check by control box remove cover inspect where plumbing runs through keep eliminating thing until you find it
Sep 02, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Nordic hot tub
All the plumbing on these items are accessed from the outside. You will have to remove the siding/skirt. Dont just cut a hole in it. Plan this out so that you can cover it with trim. You may end up making a large slice in the siding.
Nov 24, 2013 | Plumbing
Delta T2738 Deck Mount on Jacuzzi Tub. Hot Water side leaking.
With the detailed part number you have, I would just walk into stores like Home Depot or any plumbing store and they will give you the exact parts you need. They are not expensive and a lot of them are standard parts and come in kits.
Good luck.
Apr 08, 2013 | Delta T2738 Lahara Deck-Mount Two-Handle...
Danze UPC tub/shower valve leaks constantly at tub spout
shut off water and pull cartridge...go to lowes or plumbing supply and match up cartridge and replace...you may also just replace seats and springs if cartridge is ok....cheaper...but if not sure just replace whole cartridge...make sure hot is on left...
Aug 15, 2011 | Danze Home
There is a leak on my 4 person Dream Maker hot tub at the pumps connection to the other plumbing. I'm wondering if it needs a new gasket or what? The leak is taking out a couple inches every couple days....
  • I used to teach plumbing.
  • I honestly have not worked on This unit.
  • I would like to SUGGEST using some Plumbers Tape--not puddy to start with. This might fix it w/o a new gasket.
  • If That Does not fix it, go to your Local Plumers supply store (I would NOT go to home depot or lowes; I would go to the old fashioned shop) and get the gasket for the pump, as you are pondering about.
May 11, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
I have a 2000 Sovereign Hot Spring hot tub that quite heating, I checked filters they are ok, I have no air lock, The jets and light work fine. Inside the control box on the circuit board all 3 led lights...
Check for a bad heater controller board or burnt wire connection going to the heater. You can check for voltage across the white and black leads going to the heater from the heater controller board (upper left corner of the black control box
Mar 31, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
From your description it sounds as though the wet end faceplate gasket needs replacing. Where are you from? If you're from the UK I may be able to help you. Feel free to contact me: http://hotub.synthasite.com
Regards,
Ian.
Mar 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Exploded view of Berings and washer HELP ME!!! GE WSM2700W
Go to appliancepartpros.com and type in your complete model number. There are some excellent exploded view diagrams of your entire unit, complete with part numbers. Another source you can try is searspartsdirect.com. I hope this helps you.
May 29, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
How do you put springs back on a laundray tub door
Get online and do a search for your brand and model number. Try and locate a contact number for the company and sometimes you can download a service manual for the unit that might have the info you are looking for. Otherwise you just might have to have a service professional come out and repair it. Good luck!
Apr 05, 2009 | Crane Plumbing 24 In. x 22 In. Laundry...
Leaking pipe in a jacuzzi hot tub
The only product I know of which will do what you ask is an item called Plast-Aid Acrylic and PVC repair kit. Google it and you will find the website. It is about $20. and it works like a charm. good luck
Jan 10, 2009 | Home
Elements Of Design Hot Springs Polished Brass Mini Bathroom Faucet - Logo
3,998 people viewed this question
Top Elements Of Design Plumbing Experts
Paul Carew
Tom Chichester
Are you an Elements Of Design Plumbing Expert? Answer questions, earn points and help others
