Question about VuPoint Solutions VuPoint Photo Cube IP-P10-VP
Not printing the photos, just lines
Have tried 3 times to print photos from my S3 and it will only print lines on the paper? help?
When I print on regular paper, the color prints look fine. When I print on photo paper, I get a consistent quarter-inch vertical orange line on the prints and the colors look washed out. Time for new...
Hi
Basics first (which you may have already considered).
Explore the Canon Printer software settings.
You need to adjust the Printing Preferences when switching from paper printing to photo paper printing.
Also look at the Print quality and colour saturation settings and try to print in Fine or High Quality when printing on photo paper
If none of the solve the problem, check if something is not stuck in the paper input tray and pressing the photo paper to close agasinst the scanner.
Make sure the paper is properly centered and cradled with the addjusble paper guide on the In Tray.
If tall new none of this works, install new cartridges and conduct Nozzle Check and Print Head Cleaning maintenance and then test print again.
I hope this helps.
Aug 24, 2011 | Canon PIXMA MP510 All-In-One InkJet...
The printer works OK but it prints two lines clearly but every third is feint almost half the writing is ommitted
Set the print quality to normal or best.
Clean the printhead
Run a calibration.
The Kodak EasyShare AiO performs a calibration every time you install or replace a printhead. However, you can run a calibration if you are seeing changes in the image quality. Calibration aligns the printheads and performs a nozzle health check to enable high-quality prints.
1 Load the main tray or photo tray with photo paper.
IMPORTANT: If you don't have any photo paper, you can use plain paper, but photo paper is highly recommended for calibrations.
2 Press and hold Photo and Cancel together to make a calibration print.
3 Follow the instructions on the calibration print to calibrate the printer.
Feb 11, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
My Brother HL1230 printer prints with whole lines of text missing several times on a page and gets worse by missing more lines if printing several pages. It has a new toner cartridge. How can I sort this...
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 28, 2010 | Brother HL 1230 Laser Printer
Prints only blank pages
Good Luck
RK
Jan 06, 2010 | Brother HL-2040 Laser Printer
When printing lines are running through the sentences.I have a brother mfc440cn printer
Good Luck
RK
Dec 09, 2009 | Brother MFC-440CN InkJet Printer
Lines thru photos
Try to clean the nozzles with the printer troubleshooter. It will force all the nozzles to print at maximum quality and will clean the clogged nozzles. If the procedure fail, then try again. This happens when you are not using the printer for long periods of time. If cleaning nozzles will not be helpful, then remove the color cartridge from his place and put it with the printing head in warm distilled water for 30 minutes.When the water is coloured by the ink, take the cartridge and touch the printing head with a soft paper towell. If a clear line of colour is printed on the towell, then is OK, put it back in the printer and print a test page. If is not , try again with patience.
Apr 14, 2009 | Office Equipment & Supplies
I865 flashing 3 times
That's a "paper jam" error that can be fixed by removing all paper and pressing the resume/cancel button. Then replace the paper in the feed chute.
The printer can straighten out a crooked feed to a very limited degree. The photo feeder attachment can interfere with a really full 8x11 feed. The i860 is very susceptible to overfilling the 8 1/2 x11 feeder without notice until you try to print. I usually remove the photo feeder until I need to print photos, and keep the regular paper feeder no more than 3/4 full. I pull out the regular paper when printing photos.
Feb 24, 2009 | Canon i860 InkJet Photo Printer
My printer makes lines through all the pictures i try to print
Make sure your quality options is set for best photo, also change paper to glossy photo paper. Under the maintenance button try to clean the print head and then try a print head alignment. I hope this helps you........Hutch
Dec 20, 2008 | Epson Stylus CX3810 All-In-One InkJet...
My photo prints have lines across them?!
the glossy paper you are using (hp) is smearing the ink... there is now ink on the feed rollers and you need to get in there and clean it all up with alcohol...also run epson matt paper for a few prints to get the color to lay down ..good luck
Oct 08, 2008 | Epson RX620 All-In-One InkJet Photo...
Red line on last quarter of photos
I assume that the red line is not on the photos themselves (make sure this is the case - if they're scanned photos, it might be a scanner problem). If this is a 4" by 6" paper, set it in the printer after bending it in the opposite direction. 1) Set a sheet of paper on the printing side of the paper to be printed on. (If the print surface is touched by hand, the print surface may be soiled by skin oils, and the print quality may deteriorate.) 2) To bend the paper, hold the paper in a rounded shape for about 10 seconds. 3) Remove the paper not to be used in printing, and confirm that, when laid flat with the print side up, the center of the paper to be printed on is raised between 2 to 5 mm (0.2 in.) . 4) The curled paper to be printed on should be set in the printer, and printed, sheet by sheet. Canon recommends using Photo Paper Pro PC-101S 4" x 6" sized paper. When using PC-101S, printing is performed at the center of paper and streaks or uneven printing is avoided. If this is an A4 sized paper, try using Photo Paper Pro PR-101 paper, and make sure that the printing quality is set to "high" or "fine". If nothing helps, I would suggest trying a new ink cartridge. If you still have this problem and nothing solves it, call a repairman.
Apr 09, 2006 | Canon BubbleJet i560 InkJet Printer
VuPoint Solutions VuPoint Photo Cube IP-P10-VP Logo
77 people viewed this question
Top VuPoint Solutions Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a VuPoint Solutions Office Equipment and Supply Expert? Answer questions, earn points and help others
