Question about Whirlpool duet Washing Machines
I have an arrow code f 26 on my duet washer
I have an error code f 26 on my Whirlpool Duet washing machine. I have tried jiggling the door, adjusting the door latch, resetting the washer by unplugging it from the wall. I have also pushed and pulled on the latch button and ran diagnostics 3 times. The error code is still there and will not go away. Do I need to replace a part?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 129 Answers
Drain pump triac failure This error code is displayed when the main electronic controller fails to detect the triac that controls the outlet drain pump during the wash cycle.
  • Check pressure switch contacts and connectors
  • Failure of the pressure switch or level sensor can also give rise to this fault code
  • Run test program
  • If failure persists after test and verification of pressure switch, replace main controller
Posted on Dec 27, 2013
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: washer door wont latch ghw9200lw duet
Pulling the door open during the wash cycle meant that it was pulled open with the latch in the locked position. The door cannot be opened in this manner while it is operating. If the door now does not latch, it has probably been damaged and needs to be replaced. The following link explains how to replace the door latch:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
A replacement latch can be purchased on line at appliancepartpros.com. Just type in your model number and look under Section 5, for item number 7. The door latch is listed as part number AP3837611.
If you have questions, please let me know. I hope this helps you.
Posted on May 19, 2009
How can I unlock the door to my Whirlpool Duet washing machine?
try this link..Pull down on the bottom panel and pull it away from the washer. Reach through the open panel and up to the door lock. Find the release ring below the locking mechanism. Pull down on the ring to unlock the door.
How to Unlock a Whirlpool Duet Washing Machine ' Home Guides ' SF ...
homeguides.sfgate.com/unlock-whirlpool-duet-washing-machine-68645.html How can unlock the door to my Whirlpool Duet washing machine Google Search
Dec 12, 2016 | Whirlpool Washing Machines
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
I have a whirlpool duet washer with an f du error code. do you know what that means
That's a door unlock error. The machine will display that code when after trying 6 times to unlock the door, it still won't unlock.
Oct 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer duet is flashing after adding garmet. Will not return to washing
April 8 2002 DIV 26 SOURCE 110 KENMORE ELITE HE3 & HET WASHERS "ADD-A-GARMENT" INDICATOR LIGHT ON DOOR WON'T UNLOCK WHEN PAUSE/CANCEL BUTTON IS DEPRESSED.
MODELS: See additional page for Kenmore model numbers
COMPLAINT: Due to a Microcomputer Machine Control software error , the ADD-A-GARMENT feature becomes inoperative.
CORRECTION: The Microcomputer Machine Control must be replaced with a service part that has been reprogrammed to prevent ADD-A-GARMENT feature loss.
PARTS: Order electronic control listed on this service flash by model from Division 26 , Source 110 following normal ordering procedure.
MERCHANDISE CODES: WASHER Service Flash - Model Nurnbers for: Kenmore Elite HE3 & HE3t Washers: "ADD-A-GARMENT" indicator light on door won't unlock when Pause/Cancel button is depressed. Kenmore models with serial Numbers beginning with CSL23 through CSM04 11042822200 11042824200 11042826200 11042832200 11042834200 11042836200 11042922200 11042924200 11042926200 11042932200 11042934200 11042936200 Electronic conrrol p/n 8181900 Electronic control p/n 8181899
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 29, 2010 | Whirlpool GHW9300 Duet Washer
Whirlpool duet f13 error code
hi there
i read your report heres the site for your codes
Whirlpool Duet Washer Error Codes Topic: Whirlpool Duet Washer Error Codes (Read 5660 times) ... Whirlpool Duet Washer Error Codes " on: September 13, 2008, 10:38:25 PM " Logged. John Pahl ... appliancejunk.com/forums/index.php?topic=1785.0 - 81k - Cached
ty for writing to fix ya
best regards Richard
Dec 01, 2009 | Whirlpool Washing Machines
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
F 26 Code that won't go away
The F26 error code on the Duet washer is a door switch error. The button inside the door opening might be stuck so that it doesn't register as being opened and closed. First press the pause/cancel button to clear the error display. Next push the button inside the door opening a few times and pull it so that it pops out completely. That should solve the problem.
Dec 29, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
103 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
