Question about VMware Computers & Internet
Cannot open file "C:\ProgramData\VMware\dndlogs\dndlog.conf": The system cannot find the path specified.
Won't open
djnick989
  • 1067 Answers
SOURCE: cmd.exe file nit working
repair your windows maby cused by bug too run a spyware cleaner see if it gets anything sumtimes bugs will disable it u could back it all up redo it also
Posted on Jan 25, 2008
early1234
  • 871 Answers
SOURCE: cmd not working in my computer
this will fix your problem.
http://www.processlibrary.com/directory/files/cmd
  • 9 Answers
SOURCE: Windows cannot access the specified device, path, or file. You may not have the appropriate permission to access the item
It is simple ...... u got to be an administrator to install any software ..or you should be given Rights to Install any thing in the machine ...
Till then u will recive this msg on the screen
Posted on Apr 24, 2009
mgroomsn002
  • 76 Answers
SOURCE: folder delete
the file is locked by something. download unlocker and try to delete it again. Unlocker will pop up asking what you would like to do. simply select unlock and click on delete
Posted on Jul 05, 2009
SOURCE: file folders from my usb
Try to right click the drive and go to properties. On the drive properties window, click on security tab then change the permissions from there.
Hope this helps.
Posted on Jun 27, 2011
Why do I keep getting this message on my PC
This a text that was saved in the HDD/Programdata in a form of text. Written in notepad or a software like it.
It could be a read file for a software that you probably installed. It can be clean if you want by following the path (C:\Programdata\{7BE69325-2B64-42A3-9AE2-32214A60E1AF}\2.0.1.9\rafo.txt".
This mean clicking in My PC/C:/Programdata> and here you will see a folder with numbers starting with 7, delete that folder.
Also you can use the windows cleaner, which is a native software for Windows, and choose this folder to be clean or delete.
You can also use Cleaner.
Jul 13, 2016 | Cell Phones
Tip
Chkdsk.exe
check hard disk health
Check Disk - check and repair disk problems
goi to run type cmd in run, open cmd as administrator
TYPE
CHKDSK [drive:][[path]filename] [/F] [/V] [/R] [/L[:size]]
Key
[drive:] The drive to check.
filename File(s) to check for fragmentation (FAT only).
/F Automatically Fix file system errors on the disk.
/X Fix file system errors on the disk, (Win2003 and above)
dismounts the volume first, closing all open file handles.
/R Scan for and attempt Recovery of bad sectors.
/V Display the full path and name of every file on the disk.
/L:size NTFS only: change the log file size to the specified number of kilobytes. If size is not specified, displays the current log size and the drive type
(FAT or NTFS).
/C Skip directory corruption checks.
/I Skip corruption checks that compare directory entries to the
file record segment (FRS) in the volume's master file table (MFT)Example:
on May 20, 2010 | Computers & Internet
Tip
Vmware enable SSH
If you want to do advanced features in VMware ESXi you will need to go into the core of ESXi to do this you can use Secure Shell or SSH. SSH is simplar to telnet but the data is encypted.
To enable SSH on VMware ESXi you need to enter an the ‘unsupported’ mode.
Step 1. At the physical console of the ESXi server press the Alt+F1 key combination.
Step 2. Type ‘unsupported’ and then press <Enter>. Note that nothing will appear on the screen whilst you type.
Step 3. When prompted enter in the ‘Root’ password and press <Enter>.
Step 4. You will now be presented with a prompt on the console. From this prompt type the following command
vi /etc/inetd.conf
Step 5. vi (the file editor) has now opened the inetd.conf file. Using the direction arrows scroll through the lines until you reach the line that has ‘#ssh’ and remove the hash (ie: #). This is effectively un-commenting this line so that the ssh service can be started.
Step 6. Now that you have made this minor file you want to save this change and exit out of the editor (vi). To do this press the ESC key (to put vi back into Command Mode) and then type ‘:wq’ *Note: If you want to exit without saving any changes to the file then just press the ESC key (Command Mode) and then type ‘:q!’.
Step 7. With the SSH service now un-commented from this file we need to restart out ESXi box to do this type in Reboot.
on Mar 31, 2010 | Computers & Internet
Unable to open file:// insufficient permission to access
Right click on the file and click properties, click security, click edit, click add ,Click advanced button and click find. Find your user in the list and double click it. click ok. Highlight your name, and in the box below click full control. click ok again. Make sure you are signed onto your computer as Administrator to do this.
Oct 10, 2015 | VMware Computers & Internet
Quickbooks error 3371
When you register or open QuickBooks, you see one of these error messages:
  • Could not initialize license properties. Error 3371: QuickBooks could not load the license data. This may be caused by missing or damaged files.
  • Could not initialize license properties. [Error 3371, Status Code -11118] QuickBooks could not load the license data. This may be caused by missing or damaged files.
  • Could not initialize license properties. [Error: 3371, Status Code -1] QuickBooks could not load the license data. This may be caused by missing or damaged files.
Important: This issue can occur if your product is hosted by Right Networks and you access QuickBooks with WebConnect and then select to open the file without saving. If you use QuickBooks Enterprise and your product is hosted by Right Networks, you must save the file and then import it.
How to fix it:
Before proceeding, ensure that your copy of Microsoft Windows is up to date.
If the latest Windows updates are not installed, the QuickBooks installation can fail or become damaged. To install the latest updates in Windows, click the Windows Start or Logo button, choose All Programs > Windows Update. Once started be sure to install any updates marked critical.
You may need to re-install your software. Have your license number and product number for your version of QuickBooks ready.
Try these steps in the order shown. If the first one fixes the problem, you do not need to do the other steps.
Re-create damaged EntitlementDataStore.ecml
  1. Close QuickBooks if it's open.
  2. Open the entitlement data folder for your operating system and version of QuickBooks.
    1. On your keyboard, press Windows + R to open the Run window.
    2. Enter (or copy and paste) the following information, and then press Enter
      • QuickBooks 2014 and Enterprise 14.0: C:\ProgramData\Intuit\Entitlement Client\v8
      • QuickBooks 2013 and Enterprise 13.0: C:\ProgramData\Intuit\Entitlement Client\v8
      • QuickBooks 2012 and Enterprise 12.0: C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2011 and Enterprise 11.0: C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2010 and Enterprise 10.0 : C:\ProgramData\Intuit\Entitlement Client\v6.0
      • QuickBooks 2009 and Enterprise 9.0: C:\ProgramData\Intuit\Entitlement Client\v5
      • QuickBooks 2008 and Enterprise 8.0: C:\ProgramData\Intuit\Entitlement Client\v5
      • QuickBooks 2007 and Enterprise 7.0: C:\ProgramData\Intuit\Entitlement Client\v3
  3. Right-click the EntitlementDataStore.ecml file and select Delete.
  4. Click Yes to confirm you want to delete the file.
  5. Open QuickBooks, open your company file, and follow the instructions to register the application.
Jan 30, 2014 | Computers & Internet
Error 1320 when installing checksoft
Error 1320 the specified path is too long: example C:\ProgramData\Documents\Checksoft
Create a folder such as C:\Checksoft then when installing tell it to install in that folder.
Jan 23, 2014 | OnDemand Avanquest Checksoft Home and...
Can't Open Facebook. Error : file:///C:/ProgramData/pbtmp245.html
not open thi fb login web showing this error code
;file:///C:/ProgramData/pbtmp245.html
Jan 28, 2013 | Facebook Social Network
The Windows Search service stopped working on my Win 7 machine. Said indexing was not turned on. I used event viewer and found the following error message: The Windows Search Service has failed to...
1) Insert your flash drive
2) From the Start Button, type "services.msc" in the "Search programs and files" box
If prompted for Admin Access, answer yes
3) Scroll down to the "Windows Search" service, select it, and click Stop.
4) From the Start Button, type "regedit"
5) Browse to [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows Search]
6) Verify that the values DataDirectory and DefaultDataDirectory are set to %ProgramData%\Microsoft\Search\Data\
7) Remove the flash drive
8) Reboot (or restart the Windows Search service)
Jul 26, 2011 | Microsoft Computers & Internet
Computers & Internet Logo
107 people viewed this question
Top VMware Computers & Internet Experts
John Hong
John Hong
Bill Boyd
matt
matt
Are you a VMware Computer and Internet Expert? Answer questions, earn points and help others
