Question about Ricoh Aficio 2045e 2035e Copier Postscript3 Type 2045
I have ricoh my problem paper jam in side Dram, but remove paper the problem still, iam format hardisk and retain lazer, it is work about copy 50 paper and also paper still
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 90 Answers
Check paper feeder roller
Posted on Dec 28, 2013
M2Tech1
  • 313 Answers
SOURCE: Ricoh MP 5000, says it has a paper jam, but I
if the jam still shows when you turn the machine off and on then you will have to look first to see which tray you were using at the time take the tray out and look inside the frame to see if paper has stuck by the feed rollers then open the side paper path guide to check non is on teh way up from there the next is reg transfer and fuser sections also pull the duplex out to make sure its not under the travel plateand last is to check betweent ehfuser exit and finisher opent he dooor on finisher if you have one and lift the plate at top right had the paper can sometimes be hidden there... failing that the sensor for the paper exit from fuser to duplex can sometimes jam a small bit there...if you know how to get into the sp modes you can go to data log 1 there you have the jam counters and jam history look at latest and the area will show up where it could be last. good luck A..
Posted on Jun 26, 2009
newport74
  • 58 Answers
SOURCE: paper jam message, remove the paper from drum
Try cleaning the feed rollers with soap and water and a damp cloth and see if your situation improves. sounds like the machine is missfeeding but your description was a little vague.
If it does improve youll need new rollers.
Also try flipping the paper over to see if improves.
Lastly does the paper size displayed on the screen match what is actually loaded? if not... correct as nessesary
Good luck
Posted on Apr 19, 2010
  • 59 Answers
SOURCE: im using ricoh 2045..Paper jam occurs at point A1
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Posted on Jan 27, 2011
santosj27
  • 263 Answers
SOURCE: I have a Ricoh Aficio
This jam problems are always very difficult to solve without seeing the machine!
Because i need to see the jam location or take a report to see where the paper jams.
you say that it is on the Point C, but that just helps a little.
I can tell you that you have a problem in the duplex door (but you already know that). It could be several things like; transport rollers, gates, solenoids... well, the best help i can give you is to advise you to call your technical support.
See you!
Posted on Apr 30, 2011
Testimonial: "thanks for the help you could give! ill have to have a look to see what i can do"
joel_baleta
  • 155 Answers
SOURCE: the paper gets jammed every time i copy... my unit
cleaning those rollers is just a remedy and i think they are worn out and they need to be replaced once the problem comes back again.
Posted on May 22, 2011
Ricoh 6123 b copy printer paper jamming in feeding section frequently.
store paper in dry conditions. check any rollers for being worn out
Jan 03, 2015 | Ricoh Office Equipment & Supplies
Grinding noise coming from right side. having trouble printing and copying
Remove all paper from unit and carefully check in corners for a paper jam or staple/Paper clip
May 28, 2014 | Ricoh Aficio 1018D All-In-One Laser...
Paper jam sign appears after first copy
if jam indicated but no paper is found. clean the roller that feeds paper out of the paper tray.also make sure paper guides are touching paper front rear and left side.
Feb 23, 2014 | Ricoh FT5832 Copier
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
9. now fix it all
Jan 27, 2011 | Ricoh Aficio 450 Copier
Keeps showing follow instrctns in right cover to remove. Unable to copy
ther is a paper jam in the machine, open the side cover and remove the paper jam, if the paper is not visible then there is a small piece stuck somewhere.
Nov 17, 2010 | Ricoh Aficio 2015 Copier
Paper jam message, remove the paper from drum
Good luck
Apr 18, 2010 | Ricoh Office Equipment & Supplies
Jamming
Hello sir; Go make a copy let paper jam again, do not remove the paper, check the jamming paper area see there have any paper chip stuck in the paper path, clear it, otherwise cleanup roller with alcohal.
Jul 20, 2009 | Ricoh Aficio MP1600SPF Copier
Ricoh copy machine 3025 paper jams every time we try to print
Make sure the paper that is in the drawer matches the orientation and size indicated on thje Op Panel Display, If NOT, MAKE IT MATCH.
Mar 31, 2009 | Ricoh Aficio 3025P Black and White Copier
Ricoh Aficio 2045e 2035e Copier Postscript3 Type 2045 Logo
104 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
