Question about Garden
Free john deere manuals
Remove spindle bearings from JD 316 blade spindle.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Probably not servicable... check with the dealer and see if they have parts or complete spindle assy's
Posted on Dec 28, 2013
  • 657 Answers
SOURCE: john deere model 14sb lawn mower repair
Check for bad bearing in clutch immediately, Remove belt, try and turn the clutch pulley if it is hard to turn or feels rough, replace the bearing in the clutch. If you do not replace bearing immediately you will be buying a $300.00 clutch very soon. I know from experience. You possibly have been hearing a loud unusual roar from engine area for awhile and wondered where it was coming from. As these bearing will usually squall a cry for awhile before they die.
Posted on Mar 28, 2009
brado83
  • 106 Answers
SOURCE: need diagram for installing mower belt for blades
Hey if its a 42" cutter deck this should be the one:
http://i876.photobucket.com/albums/ab330/Brado83/JDDeck.jpg
It may be a 48" in that case it would be different
Brad:)
Posted on Sep 16, 2009
  • 78 Answers
SOURCE: blade belt diagram for John Deere LX178 Riding
Remember the belt rule, V of the belt goes in V pulleys.Flat pulleys that are stationary or move get the back of the belt. You can figure it out. Its not rocket science. Remember at some point there has to be a tensioner,usually gets the back of the belt if its a flat pulley. U may have to remove the spring and then reattach the spring after the belt is routed.
Posted on Oct 29, 2009
nova2nv
  • 197 Answers
SOURCE: how do we service the blade / brake clutch
No serviceable parts,you can only buy complete clutch.To replace you remove blade and blade adapter.Use a very large vise-grip to remove spring and then you can remove bolt holding clutch arm.Disconnect cable from top side of machine.Remove engine mounting bolts,have another person pull engine away from frame while you slide clutch off.Going back together you may have a tuff time getting large spring back on hook under deck.I've been working on these for some time and have yet found an easy way to get large spring back on.
Posted on Nov 15, 2009
SOURCE: where can i find free owners manual for my john
http://manuals.deere.com/cceomview/OMGX22058_F5/Output/Index.html?tM=HO
This is a manual for the John Deere 111. Hope this helps ya.
Posted on Sep 05, 2010
What is a deck for a JD L110 mower?
Yes. The deck is the metal housing that holds the blades, spindles eyc. The entire unit is a deck assembly.
Oct 13, 2016 | John Deere L100 Series
How to remove transe axcel john deere x300r
Try you tube Go to site. On the line Remove transaxle from JD------------
Sep 04, 2016 | John Deere 300 / 316 Hydrostatic Tractors...
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
Mower blades stops running
check bearings in the spindles and check belt tensions.
Jun 15, 2013 | John Deere Garden
My JD LA105 was running fine, and then I started to hear a rattling noise about an hour into cutting lawn. The next thing I knew, the blades were chopping up the ground every 10 seconds or so... any...
Hi Krissy, either a blade has come loose or bent or a blade spindle has collapsed, a look under the mower deck will tell you, regards Phil.
Oct 09, 2012 | John Deere Garden
Mower blades froze up
Have you greased the bearings on the mower deck recently? Is there something jamming the blades?
Remove the deck and see if you can move the blades by hand. If you insist on not removing the deck to do this ... make sure the belt that drives the deck is not on the drive shaft of the motor to prevent accidental starting of the motor and instant mangling of your hand. If you can move all the blades, look for a faulty or worn out pulley on the deck. If the blades are frozen in their bearings, get replacement towers at your John Deere dealer or from a FixYa.com advertiser. If one is faulty or rusted ... replace them all ... as they are probably at or near the same condition. Do this job one time and do it correctly.
Thanks for your support.
Thanks for your interest in FixYa.com
Please evaluate this response.
Thanks
Good luck with your repair.
Jul 05, 2010 | John Deere 24HP VTwin Hydrostatic 48"...
The pulley to run the mower will not turn on my john deere rider
99 PERCENT OF THE TIME YOU HAVE A FAILED SPINDLE BEARING CAUSING THE SPINDLE TO "LOCK UP" SPINDLES CAN BE PURCHASED ONLINE AT A FRACTION OF THE COST OF A JD DEALER....HOPE THIS HELPS GOOD LUCK
Nov 22, 2009 | John Deere Garden
I have a JD 160 with a 38" mower
check out john deeres web site,they can help you find a local dealer or info on your model,and order parts.
Sep 13, 2009 | Garden
I have trouble starting my 316 JD tractor. When I
I do not have answer I will like to have an answer for my 316 JD no power no lights on dash battery new and was running shot off and wont stared again.Thank You
Aug 15, 2009 | John Deere New Tractor Starter w/ 317...
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
