Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Idle goes up high by it self - 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
    Champion:
  • 239 Answers
VACCUM LEAK USUALLY
Posted on Dec 27, 2013
Ford 1986 tauruas idle reves high by it self try to put in gear then dies
Idle air control motor. Clean it or replace it. Check for vacuum leaks. If it still dies, look at the transmission. Valve body or TCC solenoid.
Mar 18, 2015 | Ford Cars & Trucks
Chainsaw runs fine than goes full throttle all by its self and cannot shut it off with switch.
Kill switch is broken or disconnected. Throttle linkage is broken or disconnected or idle is set way too high.
Oct 26, 2013 | Craftsman 2.5 Turbo Chainsaw Throttle...
I have a 1999 ford contour 2.5 v6 high idle excessive noise from iac and goes away on accel
I have teh same vehicle/engine and had the same problem. I replaced the IAC and have not heard the noise since.
Jan 29, 2012 | Ford Contour Cars & Trucks
97 2.2 cl high idle, self rev, overheat, started same time
i cannot specifically point out what the problem might be, but an overheating car---never a good thing. check everything related to cooling. fans, radiator, hoses, waterpump, coolant overflow tank(see if its got a brownish color or looks like there is oil), and check your oil while your at it...
Jan 17, 2010 | 1997 Acura CL
Idles really high after changing the bag and hitting rock
You may have partially sheared the flywheel key when you hit the rock and this will change the timing.
Good Luck
Bart
Jun 11, 2009 | Troy Bilt 5.5hp Self Propelled Mower
High idle battery lght
found out that motor mount was missing bolt and other was loose which affected alternaror belt tightness alternator wasnt spinning at high enough rpm onceit goes under 1400 it will triger light to come on
May 18, 2009 | 1994 Honda Civic
Idle problem
turn the idle screw down on the carburater
Feb 17, 2009 | 1988 Honda Accord 4 Door
Idling to high
Hi jmach,
There is nothing wrong with your vehicle and no need to have anything repaired.... The high idle speed is controlled by the on board ECU...(the Electronic Control Unit).... When starting the vehicle from cold, the automatic enrichment of fuel increases the idle speed... Depending on the ambient air temperature.... the colder the weather, the longer the engine will take longer to return to normal idle speed. Thats how it's designed to operate.
Regards Johngee10
Jul 12, 2008 | 2004 Toyota Matrix
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
15 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
