Question about Fuji Finepix S3280 14mp Hd Digital Camera 24x Zoom 720p Video 3 Lcd Black
Won't Power On
This camera has only been used approximately 3 times. It won't even power on. Tried new batteries but still doesn't work. Can't believe this camera failed in this short of time. The camera looks like brand new but I guess it is just a piece of junk.
t00nz
  • 4738 Answers
SOURCE: Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 17, 2008
SOURCE: battery life
Try buying very high quality recharable batteries. You might have low quality batteries and the camera eats the battery up quickly.
Posted on Mar 24, 2008
  • 225 Answers
SOURCE: camera won't turn on
Either your camera board is dead, or you are not using the right batteries. There are 2 types of AA batteries on the market today. One type is the normal 1.5V batteries. The other is the special lithium batteries that run a slightly higher voltage, usually about 2V. Many camera owners do not know this fact.
Posted on Nov 13, 2008
draggy58
SOURCE: fuji A850 will not power up
I had the same problem, same camera. So I checked to see if other digital cameras had the same problem, and some did. Seems to be with the batteries. I took out my memory card, and reinstalled the batteries that came with my camera, I've only had it a few days. Turned it on and it worked, so I took a pic, and then turned it back off and reinstalled the memory card, and made sure it was formatted. Turned the camera back on and it worked, and took another pic with no problems. The batteries I have right now are Panasonic Alkaline for Digital. They seem to be a heavier battery, because the cheaper ones are lighter and didn't work. So I say try that brand or make sure the batteries are for digital purposes. Hope this helps.
Posted on Apr 11, 2009
  • 244 Answers
SOURCE: The camera FujiSD8000 i have won't turn on. Used
Check the memory card or battery door for the tab that activates the cut out switch. It ,or the switch, may have sustained damage. I'm not 100% on this model but if it's like the S5700/ S5800 models then the memory card door has a tab for the cut out switch to prevent card removal whist powered up.
Posted on Apr 08, 2010
Canon 600ex-rt speedlite won't turn on with new batteries
I was having exactly the same issue with my 600EX-RT. This is what solved the problem for me. With the power turned off. Hold down the 2 clear buttons for approximately 5 seconds, then turn the power on and hopefully, you should have a fully operational Flash.
Apr 14, 2013 | Canon Speedlite 600EX-RT 5296B002 Norman...
My fuji finepix s5000 has lost power
see this causes and proceed . God bless you
If the camera won't turn on, check the batteries, or connect the camera to an AC adapter. If that doesn't work, remove all batteries, disconnect the AC adapter, wait a minute, reinsert batteries and reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Oct 16, 2012 | Fuji FinePix S5000 Digital Camera
I have put new batteries in my FinePix A360 camera but it doesn't seem to power on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Nov 10, 2011 | Fuji FinePix A360 Digital Camera
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
My Power Shot SX130 IS wont turn on... I dont know why, yesterday was working and all the sudden today I tried to Power On and doesn't do anything. I changed the batteries .... HELP!
Jul 11, 2011 | Canon PowerShot SX130 IS Digital Camera
I was having trouble with the "low battery"
If you used a voltage 3 times the required voltage then you have probably damaged the camera beyond repair. There may be a protection fuse on the circuit board inside but locating and fixing this would require an experienced electronics technician. i wouldn't hold out too much hope of getting this camera repaired.
May 24, 2011 | Samsung Digimax A7 Digital Camera
Cannon Speedlite 270EX doesn't turn on and I put new batteries in
Try cleaning out the contacts where the batteries touch. Make sure the battery door is completely flush with the body and see if you've inserted everything correctly. The type of battery you use also effects the flash recycle time and how it operates too. Have you tried using different types of batteries? Try using NI-MH instead of Alkaline and see if the speedlite will power. There's a test button on the flash and also an off-on switch you can try toggling around. The flash itself is very simple so if it still won't power on after all of that, you should contact customer support.
  • http://www.usa.canon.com/cusa/consumer/products/cameras/speedlite_flash_lineup/speedlite_270ex#ServiceAndSupport
May 17, 2011 | Canon Cameras
Olympus camera: battery empty
OK, here's the answer. You won't find it anywhere else, but here it is.
If you use rechargable batteries, you MUST use ones with a respectable capacity. 2000mah are probably not enough. You need 2400mah at least. Yes, it doesn't make much sense, in the the battery capacity is supposed to reflect how long they'll last. But the wimpy batteries just won't let this camera turn on.
I have some experience with different battery capacity in this camera, and it took some aggravation to figure this out. But I'm pretty sure this is the answer.
The higher capacity batteries are more expensive, and their hold time is probably not as good. But I get a reasonable amount of usage with them.
Jul 20, 2008 | Olympus FE-210 Digital Camera
Fuji Finepix S3280 14mp Hd Digital Camera 24x Zoom 720p Video 3 Lcd Black Logo
16 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
