What year was fisher and Paykel washer made model number GML11US
fanny
  • 146 Answers
SOURCE: fisher paykel washer
The drain pump is jammed. Switch off and remove the plug from the wall socket. Tilt the machine back so you can look under it. On the right you will see a motor which looks like it is upside down. This is your drain pump. Remove the wiring harness from the pump and turn the pump clockwise while pulling back the little white plastic clip which holds the pump in place. Clean thoroughly and replace pump.
Posted on Nov 03, 2007
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
canbruce75
  • 1776 Answers
SOURCE: Received error message fault 37 on my wonderful
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Look for anything clogging the pump (like the occasional stray sock) and check the pump impeller for damage. Look for any broken/missing blades and make sure the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line or pump. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 01, 2009
  • 343 Answers
SOURCE: what is error code 136 on a fisher & paykel IW...
136 fault is 'motor stall'...Quite often this is a broken wire to the motor. However it could also be a Motor fault, or Rotary Position Sensor problem. Water damage can cause this fault as well. After a visual check for broken wires or water damage, and if your machine is in good condition, you should consider a tech....Good luck...Nomess
Posted on May 24, 2010
  • 713 Answers
SOURCE: Fault code 00XX000X on GW612 washer
Hi just read your posting.This fault code indicates you have a COLD WATER VALVE FAULT.The lights you marked with --x-- are the ones that are lit.Is this correct?What you need to do is to test the valve coil for OHMS resistance.It should be around 60 to 63 ohms.The water valves are located under the top panel.Please reply to tell me how you got on or if you need further assistance.
Posted on Jun 27, 2010
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
I am looking for a manual for a Fisher-Paykel washing machine. (Just rented an apartment and trying to figure out how to operate this appliance). Peter
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 04, 2011 | Fisher and Paykel Fisher & Paykel Washer
I still need help with my previous issue. My F&P
Hello, one off the first things in order to help would be the model number this way we are able to see which type of washher you do have. If this were a smartdrive type unit we could use something like this service manual click this link http://www.docstoc.com/docs/25379715/Fisher-_-Paykel-Washer-Diagnostic-Fault-Codes in which on this type of fisher and paykel washer you would count from left to right the 8 lights and list which led's were lit on the unit. There are of course other service manuals depending on which model you do have. I await your reply to the model number of your machine and if I dont see your response this evening I will look forward to answering any further questions you may have tomorrow. Thanks
Rick
Aug 25, 2011 | Fisher and Paykel Fisher & Paykel Washer
We need a new pump for our Fisher&Paykel washer, Model #GWL11, tried order through a repairman, but did not come in. Where can we order one.
http://www.expertappliance.com/fisher&paykel-washer.html
Enter your model number and the part needed.
They claim to have it in stock.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Our Fisher Paykel washer shuts off during wash cycle and makes a beeping noise that intermittently comes and goes. There is also a small leak at the right front part of the washer.
Hi just read your posting.I need to know the model number of the machine.Also when it beeps do any lights light up or any error code appears on your display if you have that model.Please reply and I can help you rectify this problem.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Apr 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
