Question about Panasonic Phones KX-TG5571
Were is the hook button - Panasonic Phones KX-TG5571
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
In the back
Posted on Dec 27, 2013
Norstar phone is automatically sending hook flash (or conference transfer) signal through active calls. Places outside caller on hold and can only reconnect by using feature 71. How can I avoid this?
Could be a sticky button that is programmed for F71
Do F*0 then press all buttons and look at display until you see Link or F71 on the display. Try to un stick that button or erase it via F*1, press that key and press OK instead of entering digits.
or the spring on the grey hook switch is sensitive, this where you hangup the phone. To do a hook flash when no flash/link key you would tap the hook switch very quick to do a hook flash (link).
Send set in for repair in this case.
Oct 23, 2012 | NorStar Meridian M2250 Console Phone
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Weedeater, 18cc, replaced fuel line & purge button, the purge button will draw fuel into the fuel line but the purge button will remain colapsed.
You may have accidently hooked the lines to the purge button wrong. The purge button (primer button) should have a short stem and a long stem. The short stem is the suction side of the primer button and should be hooked up to the return on the carburetor. You actually s*uck gas through the carb and not from the tank. The carb should have two hook ups. If you hook the fuel line up to one of the lines on the carb and the button is hard to push and doesn't return to normal, hook the line up to the other one. When you push the primer button gas should be pulled through the carb. The other line on the carb goes back to the fuel tank.80a09a6.jpg
Apr 18, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Cant seem to get started. everything is hooked up. hoew do i start the game.
there is no button for it it should just pull open from the top downwards
Jun 03, 2009 | Sony PlayStation Portable (PSP) Console
Our builtin mivrowave open button in jammed
just pulled out the button and saw a hook broken inside.
removed the hook and put the button back and it works
May 07, 2009 | Whirlpool MH7140XF Microwave Oven
Off Hook and on Hook How do I switch from off hook to on hook
Offhook and Onhook are for faxing. You can press onhook to hear dial tone to make sure your fax connects. I don't believe a speed dial setting can be saved to that button unless you have to press a function button before accessing.
If you want to change destination you should be able to browse the machine via internet browser by typing IP address of copier.
I.E. internet explorer type 192.168.1.20 no http no www
the address I typed is just an example you need to get your IP address of your copy machine.
Once you access the admin page there should be a place to enter/edit your address book and you can reassign your speed dial/email destinations.
Hope this helps,
TankMurdock
Apr 27, 2009 | Konica Minolta Office Equipment & Supplies
Spacemaker II door latch problem
Most microwave ovens have catches that are shaped like hooks, these hooks catch on a fixed bolt or a raise in the frame of the oven.
The next time you get the oven open check these hooks to see if the springs are working in a strong positive manner, or if you have to push a button on the model check to see that the button releases the hooks.
Hope this helps.
Feb 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
On hook dialling
on hook is for dialing out some machine you push this button and dial the number to fax out.
there should be a off hook or stop button to release it
Aug 11, 2008 | Sharp Office Equipment & Supplies
Stereo hook up no sound
After all connections are completed correctly - Press the RESET button. The RESET button on the housing must be activated with either a ballpoint pen or similar pointed object. The RESET button is to be activated for the following reasons:
• Initial installation of the unit after all wiring is completed.
• Some the function buttons do not operate.
• Error symbol appears on the display.
Jul 10, 2008 | Virtual Reality Sound VR3 CD Player w/ USB...
Panasonic Phones KX-TG5571 Logo
65 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
