Question about Autodesk AutoCAD 2004 for PC
ACAD R14 will not print with Vista.
When I try to print an R14 drawing in windows Vista I get the following error ''Configuration file may be locked by another process or been set as read only''. I then get kicked out of R14. I greatly apprciate any help!
Thanks.
2 Suggested Answers
  • 13 Answers
SOURCE: autocad 2004 and win vista
Apparently, autocad is not compatible with vista.. Might as well, go back to wndows xp.. Please see the required specs to run autocad 2004
Posted on Mar 31, 2010
Error opening AutoCad file
This error can have a variety of causes....corrupt drawing, a program corruption, or a problem with your system configuration.
There are several ways to troubleshoot the problem: try opening another drawing ,uninstall any antivirus or desktop locking programs or update your graphics driver. If it useless so your file is damaged. In this case you can try to recover it with the help of https://www.fixtoolbox.com/autocadfix.html
Feb 21, 2017 | The Computers & Internet
How do i fix autocad? Please help!
You can fix this problem in two ways.
First: follow these steps
- Open the Registry Editor by typing "regedit" in the Windows 8 Search charm and selecting "regedit" from the Apps section of the search results.
- Navigate to the "HKEY_LOCAL_MACHINE\Software\Autodesk\AutoCAD\R15.0\ACAD-1:405\AdLM\Type" registry key.
- Right-click on the registry key and click "Export."
- Choose a name to save the license registry key file as, along with a location where you want to save it, and then click the "Save" button.
But if it useless try the second way- DWG Fix Toolbox. http://www.autocad.fixtoolbox.com/
Dec 23, 2014 | The Computers & Internet
Hi FixYa, I am running AutoCAD2009 (also 2008 before) on my Vista Ultimate edition system. I found the application fairly smooth but there is only one thing that always bother me. Whenever an ACAD file...
Ok Dan a usb flash drive is theoretically a hardive external I believe your problem lies in one the virus protection that I never use or Vista isn't compatible with the autocad . Check to see if your running 64 bit vista or 32 most programs don't run well at 64 bit.I run xp pro no anti virus an no problems.
Oct 12, 2010 | Microsoft Windows Vista Ultimate Edition
Acad 2004 failed to start because ac1st16.dll was not found.
Just visit this site...
http://www.fix-all-dll-errors.com/ac1st16.dll/
this will help in case of missing or downloading dll's .
helped in my problem. :)
Jun 11, 2009 | Autodesk AutoCAD 2004 for PC
AutoCad R14 to Vista - bab-Mem-Pointer error message
You are still using AutoCAD R14? If you are that might be the problem. If you are running Vista, then AutoCAD R14 might be too old of a version to run. You will probably need to upgrade to a newer version of AutoCAD. I know this isn't a solution, but I am just trying to look at it from a different point of view. You can also go to autodesk.com and join their discussion groups. It is free and you can post questions. You usually get a fast response with an answer that really helps. I will do a little more research and add more when I get a chance. Good luck and I hope that I helped.
Feb 22, 2009 | Autodesk AutoCAD LT 2008 - Upgrade for 5...
Job Status Window Interface has stopped working.
The issue usually occurs if you are using windows xp drivers on a vista machine. It's strange that the error does not come up when printing from internet explorer 7.0.
There is a file on support.dell.com that you can run to remove any xp drivers and then run the vista installation file. that should take care of these error messages from the operating system.
you can copy and paste the following links to download and run the files :
Patch file to remove xp drivers:
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=224499
Driver for vista
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=203951
Feb 17, 2009 | Dell A960 All-In-One InkJet Printer
I keep getting the same message while using autocad 2002lt
There are a few things to try. I'd try this first: Start ACAD and use the Recover command (File menu) to open your drawing. If that doesn't you can insert your drawing into an empty drawing as an exploded block and/or purge your drawing.
Dec 17, 2008 | Autodesk AutoCAD LT 2002...
Network printing error
vista is not a good o/s to use with networking pcs
Jun 12, 2008 | Samsung SGH-D900 Cellular Phone
Side-by-side configuration
The "side-by-side" component is associated with the Vista Windows Resource Protection (WRP). You may have a corrupted file in the SxS folder.
To resolve this issue, use the System File Checker tool (SFC.exe) to repair these files.
To do this, follow these steps:
1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow/Continue.
2. Type the following command, and then press ENTER:
sfc /scannow
(The sfc /scannow command scans all protected system files and replaces incorrect versions with correctMicrosoft versions.)
This may take some time to run, so be patient.
Hope this fixes the problem.
Apr 07, 2008 | Acer Aspire 3680 Laptop
Windows Vista and Autocad r14
try this thread from autodesk it is having solution
Feb 02, 2008 | Microsoft Windows Vista Ultimate Edition
Autodesk AutoCAD 2004 for PC Logo
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
