Question about Jabra BT2010 Bluetooth Headset
No power light
Seems to me its not charging
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
New bulb
Posted on Dec 27, 2013
My laptop indicator light doesn't come on when plugged in and battery does not charge.
problem is with your motherboard-section for power switch and charging battery,probably IC for power control,charging...
Sep 12, 2014 | Computers & Internet
Black screen
The power cells may be defective and thus the battery will no longer accept a charge. Replace the internal power cells.
Feb 27, 2014 | Motion Computing M1400 Tablet PC
Lightmates power series model 348695 sensor blink red no light
Had same problem on my unit and temporarily removing the battery and charging it for 24 hours with a modified 7.5 volt 200 ma. power adaptor seems to resolve the issue. Lamp is now working, hope this fix will last. Seems the solar panel does not charge the battery fully. Tried locating a replacement battery to no avail. The battery is 8V3.5AH, no other model information. Battery is 3.75" H x 3.5" W x 1.75" D
Mar 15, 2013 | Televison & Video
My john deere la125 seems to be drawing power wile shut down, it take a week for the batter to go dead, i've pulled the batterer and it stays charged up , I've checked the charging unit and i
What you do is power off the machine, and disconnect the negative battery cable. Put a test light or volt meter between the battery negative terminal and the disconnected negative battery cable.
You will likely have a light or voltage reading...Then you start disconnecting things....I suggest the alternator.
When you have the correct component disconnected and the test light or volt meter shows no current.
If this component is the alternator, they have diode sets inside (or somewhere else in the charging circuit) Typically one diode fails and this causes the draw that you describe. The system often still charges, but at a slightly lower capacity with the failed diode.
Doc
Nov 23, 2012 | Garden
I have an "old" phone of that is a gift from
A red light indicates not enough power for turn on, the battery is either completely depleted or dead. If the light does not change to amber after a few minutes of charge, the battery needs to be replaced with a new one.
Dec 26, 2010 | T-Mobile Dash Smartphone
It seems like the battery is dead, but am I supposed to see any lights to indicate that it is charging in any way? I bought a replacement battery but still see no indicator that the battery is receiving...
It seems you have isolated the issue. This is a possible power adapter that charges the
battery.
Yes, you should have a green light that shows that your battery is charging or charged.
In the windows task bar should also show that you are either connected to a charger or
a battery.
You will need a power adapter replacement.
Contact the technical support for your PC unit get a replacement.
Oct 05, 2010 | ASUS Eee PC 1000H Laptop
My Aspire 5520-5043 began showing trouble to start: no power ligh
thats mean the charging system is faulty and sometimes there are breakages at the edge of the power cable where the pin is.try another power cable if it shows the same signal then the fault is on the laptop board.
Aug 02, 2010 | Acer Computers & Internet
Blinking power and charge lights
The power plug on the laptop seems to malfunction. Or the Jack is loose.
Oct 12, 2009 | Compaq Presario Notebook
New - but will not charge up (no light on earpiece).
probably the wire from the charger is bad. Try to replace the charger
May 20, 2009 | Plantronics Explorer 340 Wireless Headset
Jabra BT2010 Bluetooth Headset Logo
61 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
