Question about Innovative Technology The Ultimate Film And Negative Scanner itns-500
Itns-500 fail to register read
What is calibration sheet,and where do i find one?
Hi, the calibration sheet being referred to was sent with the printer, it's a piece of cardboard ( white with one corner missing). Please check the packaging if you still have it, otherwise borrow one from a friend. All the best.
Oct 15, 2014 | Innovative Itns-500 Film, Slide, Photo &...
ITNS-500
Hello the homepage is here:
http://www.ithomeproducts.com/support
But it seems to be that here no software for a mac only for pc.
Good luck
Dec 17, 2012 | Innovative Technology The Ultimate Film...
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
What is ITN?
ITN is the abbreviation of insecticide treated nets. Newer, longer lasting insecticide nets are starting to replace ITNs in many countries. ITNs are estimated to be twice as effective as untreated nets, and offer greater than 70% protection compared with no net.
Aug 07, 2012 | Camping, Backpacking & Hiking
S10 stalls when stopped
Run a full fuel pressure test.
Hook up a fuel pressure gauge and drive it untill hot or when itn does it.
Post back fuel pressure reading and readings when it stalls.
If fuel pressure is up to specs when it stalls then check for lose of park to plugs.
Try to do these once.
Car Projector Headlights
Aug 01, 2012 | 1994 Chevrolet S-10 Blazer
I need an Canopus ADVC-500 Service Manual to reset the unit.
I read that one person had a problem that sounded just like this; it was due to a dip switch that was inadvertently flipped.
Apr 22, 2010 | Canopus ADVC-500 A/D Converter: ADVC-500...
Uniden 2080
I have same problem
Nov 16, 2009 | Lands Phones
Help
Panasonic wants you to register with their site before you get access to their drivers.
You can register here and then you should be able to download your drivers from them.
Nov 15, 2007 | Panasonic Toughbook 48 Notebook
Innovative Technology The Ultimate Film And Negative Scanner itns-500 Logo
Top Innovative Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Innovative Office Equipment and Supply Expert? Answer questions, earn points and help others
