Question about Amsco M70WC-EL Warming Cabinet
Bottom of cabinet temp is around 90 F. What should bottom temp be if temp setting is set to high?
Tip
Sink Cabinet Replacement Bottom
IF your sink cabinet bottom is water damaged and in need of a replacement, this video gives step-by-step how to information for fixing it. This video was created by a cabinet professional who specializes in fixing Formica kitchen cabinets.
It is very informative for the person who likes to do it yourself" when it comes to repairing things around the home.
Tools and materials needed:
Saber saw
Diagonal cutters
Hammer
New sink cabinet bottom
Caulking
Caulk gun
Clorox Bleach
Three Support Struts
L-brackets
Finish nails
How to do the Repair:
Take the doors of the kitchen or bathroom cabinet off.
Remove the water damaged sink bottom by cutting it in half from front to back. You may need to use the hammer at this point. Just be extremely careful to not damage the plumbing.
Break off the staples with the diagonal cutters.
Clean the mold with the Clorox Bleach.
Install the struts designed to support the new sink cabinet bottom. Use L-brackets if necessary for attaching the center piece.
Install the new sink cabinet bottom replacement board. Attach it with finish nails.
Clean the inside of the kitchen or bathroom vanity cabinet.
Caulk all interior areas of the sink cabinet bottom.
Replace the doors.
Every sink cabinet is built differently. Make sure to examine how the cupboard was built to determine the best method for replacing the bottom of the cabinet. If you have a center style, you will need to cut it out and reinstall it using L-brackets.
on May 26, 2010 | Home
What is the best way to display my china in my china cabinet?
If done correctly, your china cabinet can be a work of art. When designing your cabinet divide it into three sections - left, middle and right side. Most china cabinets come with three shelves and it is a good idea to coordinate each shelf with similar groupings. If your cabinet has a light on the inside at the top, I recommend displaying your crystal items on the top shelf. The middle of the second shelf is your focal point. I recommend displaying a complete place setting of your china. On either side display other items that match your place setting. On the bottom shelf, place a few key pieces from your china set - such as a gravy boat or a set of salt and pepper shakers.
Here is an image of a well-designed china cabinet -
Sep 02, 2012 | Acme Furniture
Waterleaking from front right lower corner out of small opening in bottom. Stops for days then starts again for an hour then stops dripping for days
Don't know where you are located but there are a few possibilities
1. Is the unit sited in a warm high humidity area, if so you must ensure that the doors are kept closed as much as possible. Very warm areas with high humidity will produce excess water, you may just have to live with this.
2. Are you putting products in the cabinet that are not sealed (film wrap), open product loses water to the cooling system and can produce excessive condensate.
3. Is the cabinet set too cold, factory setting is 2 deg C (36 deg f) to 4 deg C (40 deg f) this makes the cabinet work harder and produces more water
4. Are the door runners etc clean, this can misalign the doors and let warm moist air into the cabinet
5. Is the condenser clean, this is the small radiator on the end of the cabinet, clean it gently in line with the fins with a soft brush and vacuum cleaner, if this is dirty it will make the unit run longer and produce more water.
Hope this helps
Gordon
Apr 12, 2011 | Delfield 7048-M Refrigerator Commercial
MOdel 110.92579110 leaking water out bottom of
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.92579110
LEAKING:
See the Sears site sub-components for the agitator, basket and tub. It's possible that one of the gaskets or seals has worn over time.
I'd also pull off the cabinet and check the hoses leading to and from the pump. It's also possible that the pump is leaking.
See the following for how to remove the cabinet.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
The illustrations also show how to remove the transmission.
OIL
The black oil / fluid that you see is likely coming from the transmission.
Since it seems to be "spraying" around the inside of the cabinet, I'd assume that it is leaking from the top seal between the transmission and clutch.
See the following for a parts breakdown of Whirlpool top load direct drive washers.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
If you look at page 15, you'll see a Seal, Gearcase Cover. It is possible that that is the cause of your transmission leak.
The rust on the bottom of the transmission may (hopefully) be simply caused by the water leak.
I'd remove the gearcase cover (8 bolts) in order to check the gearcase cover seal, and to check the oil level. The Whirlpool transmission takes about 15oz or 80-90 weight oil.
Oct 17, 2009 | Kenmore Washing Machines
Roper refrig compressor or fan will not come on when plugged in
I will need a little more information to help you solve this problem.
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Make sure that I can get the exact numbers so I can see if your refrigerator has other features like defrost timer, circuit boards, ETC. Let me know, Thanks, Sea Breeze
Feb 27, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Water in the frig
Check to see that the drain tube going from the evaporator down to the bottom of the cabinet to the drain pan is clear and not plugged. Also check your thermostat. Make sure it is not set too cold. cabinet temp should not go below 34 deg's. Hopefuly this will help.
Jan 29, 2009 | Refrigerators
UP RIGHT FRIGIDAIRE FREEZER AUTO DEFROST 11CF I THINK
This could be normal for the summer. This is the right temp to keep it at. Some units are meant to run 80 - 90 % of the time. Turn it all the way up and check the temp. Most units when working properly can get below 0. Check the condensor underneath for dirt and to see if the fan is running under there. (smaller units don't have anything underneath) Some have coils in the rear and the smallest units just use the sides of the cabinet to disperse the heat. Check the gasket see if its sealing properly or maybe the door is warped and not closing at the bottom.
Jun 28, 2008 | Frigidaire 11.6 cu. ft. / 328 liter...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
Greetings bkbkbt,
Many times this behavior is an early indicator that your unit either needs freon or might have a compressor issue. I would advise contacting a repair person before this problem gets worse.
Thank you,
Dorothy
Go Ahead. Use Us.
Jun 24, 2008 | Refrigerators
Amsco M70WC-EL Warming Cabinet Logo
134 people viewed this question
Top Amsco Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you an Amsco Science and Laboratory Expert? Answer questions, earn points and help others
