Question about Vizio VR2 Remote Control
Trying to hook my remote up to my dvd player - Vizio VR2 Remote Control
Codes for bp59-00016 samsung remote to hook up a rca dvd player
Try the code 002 for an RCA DVD player for the BP59-00016 remote. This is the only code given for RCA DVD players for several Samsung TV universal remotes (BP59-0007 and the BP59-00016A). A manual for a TV with the BP59-00016A remote is here: http://downloadcenter.samsung.com/content/UM/200303/20030325191047000_L62A_ENG_1210.pdf .
You may need to check the age of the remote. The codes in a universal remote generally only control those devices released 6 months or more before the remote was programmed. If your RCA DVD player is newer than your remote, you may need a new remote.
I hope this helps.
Oct 12, 2011 | Samsung BP59-00016A Remote Control
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
Sep 19, 2010 | Panasonic DVD-S29 DVD Player
Trying to hook up memorex dvd player. esa's menu
you should see a button marked "av" on the remote, press that and you will find the dvd on the av socket you connected to.
alternativly, scrolling down with the ch down button sometimes allows you to goto the av channels.
Jan 30, 2010 | Televison & Video
How do I hook up a DVD player without a remote?
You can buy a universal remote philips are rca and that would work with your dvd player rca mot rcu404
are philips sru3003wm/17
Dec 09, 2009 | Emerson EWF2703 27" TV
Trying to get my TV can't find manuel or remote
Press the "Input" or "Source" button on the television while you have the DVD player on. Press it repeadly until you see the DVD picture on the screen.
Basically, just try changing the input on the TV to the input that the DVD player is hooked to.
If this doesn't work, you may have to get the original remote, or get a universal remote to control some of the television's features.
I hope this helps :)
Best Regards,
James
Jul 21, 2009 | Televison & Video
Can't get my Sony DVD player to work.
I was able to solve the problem by trying every device available on the TV set's Menu until I got it to work.
Dec 01, 2008 | Sony RM-Y128 Remote Control
Durabrand Tv.
If the TV has a tv/video button on the front
panel you can switch to video and just
operate the DVD with the DVD remote
If there is no TV/VIDEO switch then you
will need a universal remote with TV/VIDEO
menu,PIP etcIf you dont have a remote for
the dvd player the solution is basically the
same a universal remote howerver you can
operate the dvd player from the front panel
Nov 20, 2007 | Durabrand DWT1905 TV
Dora Tv & Dvd
How are you connecting the two? A/V input jacks? Are you selecting that input (line 1, line 2, etc...)?
Sep 12, 2007 | Emerson Dora The Explorer DVD Player
Looking for DVD-1002 remote code
on the dvd player it should say what the make it is try looking on there website and buy the remote
Aug 12, 2007 | Durabrand DVD-1002 DVD Player
Vizio VR2 Remote Control Logo
13 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
