Question about Home
SLOW IN FILLING TOILET TANK (UBERHAUS TOILET)
    Habit-Forming:
  • 31 Answers
There are a lot of things that could cause this problem. You'll probably want to make sure you aren't having any problems with leaks or water pressure first. Other than that, it could be a clogged pipe or something else in your plumbing backing things up. The best advice I can give you is to hire a professional. The last thing you need is to go without a toilet if you mess something up, and a professional would be able to keep that from happening.
Posted on Jan 26, 2016
  • 7 Answers
SOURCE: Toilet tank not filling
shut the water off to the toilet .Remove the toilet supply from the tank end.slowly turn the valve on to see if their is any water coming thru the supply.If water is coming thru the supply than you know you need to change the ballcock.This is the part in the tank where the water comes out of.
Posted on Feb 02, 2009
  • 54 Answers
SOURCE: when toilet water tank is filling water is
Take the top off the water control valve(shut water off first) You will see a diaphram. Replace it.
Posted on Sep 14, 2009
  • 31 Answers
SOURCE: toilet wont stop filling
adjust the over flow
Posted on Oct 01, 2009
  • 652 Answers
SOURCE: My toilet is filling up very slow....
Adjust the float in the tank of the toilet.
Posted on May 22, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My Kohler toilet tank is
Change out the ball **** and float assembly and flapper valve to one of the newer types...
Also you can set the level of water in the tank by an adjustment screw located at the top of the ball ****.
The Flapper valve on the bottom of the tank also needs replacement, that is causing the tank not to drain properly.
This is a free answer, please rate me
Posted on Oct 13, 2010
Uberhaus canada
Usual issue is a worn or misaligned flapper. Could also be worn parts in the fill valve.
Jul 17, 2014 | Home
I have a uberhaus dual flush toilet. I turned off the water supply in the house to work on a sink and when I turned it back on the toilet won't fill anymore. If I fill the tank or the bowl it will flush...
You will have to disassemble the fill valve and clean it. When you shut the water off and on to work on the sink it dislodged dirt and scale in the water piping which clogged the toilet fill valve. Check your lavatory sink areators too they may also be partially plugged. Hope this helps.
Bob
Jun 09, 2014 | Home
Why my uberhaus dual flush toilet does not flush properly
Perhaps it is taking a long time to fill the cistern, take top off and see if it's filling after flushing, if it's slow and pressure is ok it is likely to need a new diaphragm in the filling valve.
May 12, 2014 | Home
Uberhaus dual flush toilet power-assisted
buy a simpler toilet less problems and you will sleep at night
Jul 18, 2013 | Home
Uberhaus dual flush toilet keeps running
The flapper may not be seating properly after a flush. Even though you say the toilets are brand new, something may be askew in the flushing assembly or may have been affected during installation
May 27, 2013 | Home
May 20, 2010 | Home
New KOHLer toilet, worked great 2months... now
On top of the valve in toilet it has a cap that you can remove. It may have sometime obstructing flow.
Also on top it will have a screw for adjustment you could try to run it in a little. This is for valve 's with arms that extents float ball in tank. Just make sue that it is not touching any where in tank, causing it to hang up and run.
May 12, 2010 | Plumbing
Toilet does not flush down contents.
This seems to be a case of blockage within the toilet. Check the
Flushholes under the inside-rim of the toilet. they might be partially blocked by debris or deposits. If so, a Wire-Clotheshanger will help.
If the Blockage is in the drain, a Handauger might be helpful to push
blocking objects through or retrieve.
Waterlevel in the Toilet-tank could be too low. It should be about 1"
below the top of the Drainvalve in the middle of the Tank.
Aug 23, 2009 | Kohler C3-200 K-4709-96 Biscuit Elongated...
Feb 01, 2009 | Kohler Santa Rosa K-3323-0 White Compact...
Home Logo
245 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
