Question about Pioneer MJ-D707 Personal MiniDisc Player
SIO error when I turn device on it comes up with SIO error, the manual says to turn off at mains and switch back on and this will resolve issue, yet it doesn't. Can you advise any more info on how to fix this problem please Thanks Matt
Konica Minolta biz 600 error c-6708 plz help
exposure lamp or CCD issue. both located under the big glass. The CCD is the large black device on the right. The scanner is device on left that lights up scan a document though the Doc feeder or main glass.
try this reset
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the destroy the lamp or CCD
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly
Apr 21, 2017 | Konica Minolta Office Equipment & Supplies
Error solve ?
MFP board (MFPB) not receiving SIO receiving port...ADF ADF (Document feeder) not talking to main board.have tech come out might need to be re-flashed worse case both board need to be replaced
Sep 23, 2016 | Konica Minolta Bizhub C360 Color Copier...
Communication error epson printer
To help you troubleshoot the issue with the Epson Printer for communication error, please follow the steps given below:
- Make sure that the switch is turned on or plug another electrical device into the outlet to check whether the outlet is operating properly.
- Turn off the printer and check the power cord connections between the printer and the electrical outlet. Then turn the printer back on.
- Make sure that the printer is selected in your application software.
If issue persist, please follow the communication error troubleshooting link given below, which may resolve the issue:
https://files.support.epson.com/htmldocs/r800__/r800__rf/trble_1.htm#error%20indicators%20b
If issue persists, it is recommended to contact Epson Customer Support Center
http://www.epson.com/cgi-bin/Store/jsp/Landing/about-epson_contact-us.do?UseCookie=yes
GuruAid.com
May 04, 2016 | Epson Office Equipment & Supplies
ERROR E733-0000
E733-0000
Error code : Printer communication error Communication error between the Engine Controller PCB and the Main Controller PCB occurred.
Try turning off the device, unplug power cable and turn on to flush the memory. Change the power cable as well. If this doesn't resolve the issue, probably something is loose in the board. Contact your support.
Nov 20, 2013 | Canon Imageclass D1350 Multifunction Fax...
Hi, We have a G638 plus and have it connected to the cold water tap. When we press start, it fills the machine with water and once the machine has been filled, the program doesn't start and after 2-3...
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Aug 16, 2011 | Miele 24 in. G638 Plus Free-standing...
GOOD AFTERNOON, AFTER THE EXCHANGE'S BLACK AND MAGENTA TONER PRINTER HP COLOR LASERJET 2600N 55.1 HAS THE ERROR AND EVEN BACK TO THE ORIGINAL CARTRIDGES and update the firmware the error persists.
55.1 Error DC controller error.
The device has experienced an internal hardware error.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it.
Plug the device directly into the wall socket. Use the power switch to turn the device on.
Check the engine (DCC) firmware version.
Update if needed. Replace the DCC if a firmware upgrade does not resolve the issue.
Jul 13, 2011 | HP Color LaserJet 2600n Printer
Intake/Drain light is flashing and dishwasher won't do anyhting. I gve cleaned the filetr and still nothing
Hi
Daniel
Jun 08, 2011 | Miele 24 in. G638 Plus Free-standing...
Manually how to solve the system error c:32:01 in sony H20 camera when opening video mode
The C:32:01 error code displayed on the Camera screen indicates the internal malfunction happened in the Camera. Try turning off and on the Camera to check if it works. If the issuer persists, perform the following steps:
Performing a manual power reset may help:
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Reset the camera to factory specifications to try resolving the issue.
Thanks for resolving the issue.
Feb 20, 2011 | Sony Cyber-shot® DSC-H20 Digital Camera
WHEN ZOOMING IN WITH MY CAMERA IT TELLS ME TO SHUT OF POWER - VERY FRUSTRATING
The Turn off and on again error message displays when there is an internal malfunction or a malfunction with the Lens. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Main Settings 1 Menu of the Camera to OK. (Home-->Settings-->Main Settings--> Main Settings 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa
Jan 18, 2011 | Sony Cyber-shot DSC-W120 Digital Camera
I get a an error 55.1 " turn off and on??? I t was working just fine this morning. Need a little help
From the service manual:
55.1 Error: DC controller error. The device has experienced an internal hardware error.
Solution:
1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn the device on.
3. Check the engine (DCC) firmware version. Update if needed. Replace the DCC (DC Controller) if a firmware upgrade does not resolve the issue.
Jun 17, 2009 | HP Color LaserJet 2600n Printer
154 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
