Question about Arris Dct6416 Phase Iii Dvr Digital Cable Receiver Box Dct 6416
Set a default channel on startup - Arris Dct6416 Phase Iii Dvr Digital Cable Receiver Box Dct 6416
How to change boot for cd or hd in ibm lenovo
Start you computer and hit F1 every second until the Bios screen comes up. Then follow these instructions:
To view or permanently change the configured startup device sequence, do the following:
1. Select Startup.
2. Select Startup Sequence. See the information displayed on
the right side of the screen.
3. Select the devices for the Primary Startup Sequence, the
Automatic Startup Sequence, and the Error Startup Sequence.
4. Select Exit from the Setup Utility menu and then Save
Settings or Save and exit the Setup Utility.
Note : If you have changed these settings and want to return to the default settings, select Load Default Settings on the Exit menu.
May 17, 2012 | Lenovo Thinkcentre M55e 3.4 Ghz Pentium-d...
Default password
Have you tried pressing F8 right before the splash screen of windows,keep on tapping it until you get to see the advance boot menu and select safe mode?
Nov 11, 2011 | Samsung N150 Plus 101inch netbook
Wont let my wii on my wifi error code 50200
The Wii is not connecting or finding your wifi because of a firewall issue with your wireless router. Your wireless router is set to broadcast on channel 6. The Wii wants a certain channel though. I had this same issue when I set up my Wii.
Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6.
The following link will give you a default settings page for each brand of routers. Select your brand and model and it will give you a url to get to the settings. The information you need is found in the "Broadcast Channel:" area.
http://www.nintendo.com/consumer/wfc/en_na/routers/index.jsp
Jun 09, 2011 | Nintendo Video Game Consoles & Games
How to use dual band on router?
You can only use it in the 2.4 ghz mode or the 5 ghz mode:
1. Log in to the Router by going to http://www.routerlogin.net or http://www.routerlogin.com
and entering the default user name admin and default password password, or using whatever
LAN address and password you have set up.
2. Select Wireless Settings under Setup in the main menu to display the Wireless Settings
screen.
3. Select the region in which the wireless interface will operate.
4. Set up the 2.4 GHz wireless network:
a. Enter the SSID name. The default is NETGEAR.
b. Select the operating channel for the wireless mode. The default is Auto. When Auto is
selected, the router finds the best operating channel available.
If you notice interference from nearby devices, you can select a different channel.
Channels 1, 6, and 11 will not interfere with each other.
c. Leave the wireless mode set to the default setting of Up to 145Mbps for 2.4GHz.
5. Select security options for the 2.4GHz wireless network.
The wireless Security Options are set to None by default. NETGEAR strongly recommends
that you use wireless security. You can select a different Security Option and a different
passphrase for each wireless network. For the highest performance of the 2.4GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK as
your security option.
6. Set up the 5GHz wireless network:
a. Enter the SSID name. The default is NETGEAR-5G.
b. Select the operating channel for the wireless mode. The default channel is 36. If there is an
Auto option in the channel list and you select it, the router will find the best operating
channel available.
c. Leave the wireless mode set to the default setting of Up to 300Mbps for 5GHz.
7. Select security options for the 5 GHz wireless network.
passphrase for each wireless network. For the highest performance of the 5 GHz wireless
network and the most secure encryption, NETGEAR recommends that you use WPA2-PSK asyour security option.
8. Click Apply to save your changes.
please rate it and give a testimonial for my response
Thanks, Joe
Feb 02, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
My digital camera accidentally switched to German. How do I get it back to English?
Go under the menu and see if you can find something like "Sprache" (language) or "sprachen" (languages). Then find the one that says something like "Englisch" (English). Depending on your camera, the last part might even say "English". I hope this helps! Der Strom
Oct 12, 2010 | Kodak EasyShare M550 Digital Camera
TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Apr 17, 2010 | Sony BRAVIA KDL-46V3000 Television
Change default channel on cable box
Called the cable provider, Time Warner, and used the "settings" menu to navigate to power on channel, where I selected the default channel.
Nov 13, 2009 | Atlantic Scientific Network connector
How do i disable programs from startup or goto default startup?In a Toshiba Satellite A85 Win XP
Type
MSCONFIG in the run box, go to the startup tab
Set as you wish here
Regards
Richard.
May 19, 2009 | Toshiba Satellite A85-S107 Notebook
Changing the default channel
I believe you will have to have a tv tech. do this adj. , this is set in the factory service menu which he or she can access.
Nov 27, 2007 | Zenith H27E35DT 27" TV
Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Sep 04, 2007 | Akai LCT3201AD 32 in. LCD Television
Arris Dct6416 Phase Iii Dvr Digital Cable Receiver Box Dct 6416 Logo
16 people viewed this question
Top Arris Computers & Internet Experts
Jerry
Jerry
Suddenlink Help
Level 1 Expert
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
