Question about Toys
Fuel pump troubleshoot
Fuel pump in tank unit staying on car wants to fire but wont any tips
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Change fuel pump and sender unit
Posted on Dec 27, 2013
Gas gauge staying at empty when tank is full
Spencer, Check all fuses ,plugs and grounding at the tank.The sending unit module, inside the GM's gas tanks were notorious for going bad in this err, when you changed it did you use a quality part? Also the fuel pump sending unit plug/wire harnesses were known issues, so much that replacement pumps would often come with replacement plug to splice into existing harness. Check the attached links,instruction and guides on how to trouble shoot fuel gauge/sending unit, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
General Motors Fuel Gauge Troubleshooting American Autowire
GM Defective Gas Gauge Leaves Owners Guessing
Fuel Gauge Tech How To Properly Diagnose Faulty Fuel Pump Sending Unit
GM Fuel Pump Level Sensor Diagnosis Testing
Aug 27, 2016 | 2000 Oldsmobile Alero
My furnace wont stay running we have changed the pump nozzle and filter the tank was tipped 2weeks ago and has never been the same since
Have the fuel delivery people pump the water off the bottom of the tank and add fuel conditioner to the tank.
Topping off and pumping off both stir up debris in the bottom of the tank. You may have to change filter and nozzle again.
Jan 31, 2015 | Heating & Cooling
I put a new fuel pump in rear tank and fuel filter but not starting.im getting fire at fuel pump but no fire from relay .i put new relay still nothing
Fuel pump will usually only run when on Crank. When engine fires up then it stays running. This is so it won't pump in a crash.
Jan 31, 2015 | Cars & Trucks
03 vue sometimes wont start. every once in awhile it just turns over but wont fire try it couple times then starts. the problem has got worse to turning it over several times to where its draining the
Several components help a car start: 1) Starter, 2) Battery, 3) Camshaft sensor, 4) Crankshaft sensor, 5) Fuel pump, 6) Coils/Plugs. Start by testing each of those to ensure spark is reaching plugs on a consistent basis. If u can hear fuel pump - and you are sure fuel is in the tank (sometimes the fuel sending unit goes out, making you THINK fuel is there...). Cover each of those, and it should start...if the security system isn't being signaled to stay activated...security can also prevent a start... :-)
Sep 20, 2014 | 2003 Saturn VUE
Car will turn but wont turn over
Combustion engine = 3 elements, fire, fuel, oxygen is it out of gas? its cranking but not ignite? i think its fuel related start at the carb or tank and go along the path from tank, pump then filter then lines dont ever sit there and crank your car for a long time if its not firing up because the starter will fry as well as the battery so check the fuel pump and filter
Jan 23, 2014 | LeoVince Kawasaki ZX-6R Ninja 2011 Carbon...
How change fuel pump on neon 96
With the vehical jacked up and supported, inspect the front side of the fuel tank, it has a plastic ring going around the place where all the wires and fuel lines connect to the tank. Unscrew this ring and the gauge sending unit and the pump are connected to it. You should drain off most of the fuel before you take it aprt to avoid fires and the spilling of fuel. make sure the battery is disconnected to avoid sparks that may start a fire. If it does catrch fire get away as the fires like this are hard to put out and need to be avoided. stay away from other things that burn ( Buildings < other cars, wooden floors as they burn good too if splashed with spilled fuel. If you don't feel you can do it right have a professional do the work as they have the right equipment to do the job right.
Mar 01, 2011 | 1996 Plymouth Neon
Where is a fuel pump located, for 1994 villager mercury
In the tank!!!
Removal
CAUTION Observe all applicable safety precautions when working around fuel. Whenever servicing the fuel system, always work in a well ventilated area. Do not allow fuel spray or vapors to come in contact with a spark or open flame. Keep a dry chemical fire extinguisher near the work area. Always keep fuel in a container specifically designed for fuel storage; also, always properly seal fuel containers to avoid the possibility of fire or explosion.
The fuel pump and fuel tank sending unit are removed as an assembly.
  1. Remove the fuel tank. Please refer to Fuel Tank, Removal and Installation for the procedure.
  2. Clean the area around fuel pump.
  3. Remove the six fuel pump bolts.
    WARNING The fuel pump and fuel tank sending unit assembly must be tilted to remove it from the fuel tank. Do not lift the assembly straight out of the tank, or damage may occur to the sending unit.
  4. Lift the fuel pump and fuel tank sending unit assembly from the fuel tank and discard the gasket.
Apr 18, 2010 | 1994 Mercury Villager
Rolling over and it fires but wont stay running
If you are getting "fire at the plugs", then it is probably a fuel delivery problem. It is very common for the fuel pump to fail in these vehicles, particularly if the truck is run below 1/4 tank of fuel very long. Slide under the truck at the tank and have someone turn on the key. if you don't hear a humming noise then your pump is not running. Check fuses, fuel pump relay, and sending terminals for bad connections. Replace the pump assembly.
Aug 24, 2009 | 2000 GMC Jimmy
Wont start or stay on
From the info you provided, it seems like it is not getting constant supply of fuel. I think that don't have a carburator. It has a TBI(Throttle Body Injector. You should hear a faint humming noise at the back coming from within the fuel tank when you turn the key on. Thats the fuel pump. Your fuel pump may have gone out.
Jun 28, 2009 | 1993 Chevrolet Suburban
Car wont fire
check fuel pump its in the petrol tank acessable from under the back seat through a cover
Dec 07, 2008 | 2000 Ford Focus
Toys Logo
64 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
