Question about Astra Car Alarm And Remote Starter, 4000rs2w1
Started for hyndai scoupe 1993 no working
Replace started I need diagram
Still back firing though plug wires renewed
Backfiring equals pre-ignition caused by an engine that is out of timing. Shop work!.. backfiring can cause major problem with the valves.
Nov 08, 2013 | 1993 Hyundai Scoupe
22RE TOYOTA 1993 PICKUP BASE MODEL 4WD 4CYI 5 SPEED MANUAL
its located on transfer case rear end near propeller shaft , have 3 wires plug
Jun 27, 2017 | 1993 Toyota Pickup
I have a 1994 hyundai scoupe and it is not getting any power with a new battery
Will it start and if so do you need to boost it every time you need to define no power
Jan 08, 2013 | Hyundai Motor 1994 Scoupe
2002 Hyndai Accent occassionally will not start
check your starter sometimes the solenoid gets stuck if this is the case you will need to replace the starter.
Feb 18, 2010 | 2002 Hyundai Accent
How do i fix a hyundai scoupe starting problem? someimes when i go to start my car i have to turn it over several times before i get anything. and then other times it will start just fine. we replaced the...
If you have a national auto parts chain store near you (autozone, advanced auto parts, pep boys,etc etc) Have them hook up an obd2 tester to your car and see if any codes come up(they do this for free!!!). If nothing then I would check the ignition switch module inside the steering column, it may be energizing the starter motor but not sending a signal to the ecu that the car is trying to be started.
Jan 20, 2010 | Hyundai Motor 1991 Scoupe
Can't find where the fuel filter is.
sorry i don't have books that far back but a 1993 scoupe had the filter located next to the windshield wiper motor. held on by a strap and 1 bolt there is a gas line on the top and bottom of the filter,with a banjo fitting on the ends.hopes this helps.let me know.
Oct 31, 2009 | Hyundai Motor 1991 Scoupe
Car wont start
yes, replacing this fusible link will correct this issue. it seems to have a short of some sort.
Mar 09, 2009 | 1995 Hyundai Scoupe
Astra Car Alarm And Remote Starter, 4000rs2w1 Logo
15 people viewed this question
Top Buck Vehicle Parts & Accessories Experts
xxxxxx xxx
andy148814
Level 1 Expert
Rocguy
Are you a Buck Vehicle Part and Accessory Expert? Answer questions, earn points and help others
