Ariston AVXD109 error F08 - Washing Machines
What does f8 Mean?
F08: Resistance Missing or Pressure Switch stuck on Full Found
  • Overhaul CN1
  • Overhaul Resistance Connection
  • Overhaul Pressure Switch Connection
  • Replace Resistance
  • Replace Pressure Switch
  • Replace Card
Dado
Jan 11, 2015 | Ariston Technologies AWD120 13 lb. Washer...
What is F08 error means in Ariston washing Machine
You did not specify model!
F08 - Heater relay cannot be activated
  • Check wiring
  • Check pressure switch and connections
  • Tap relays as they can jam on new boards
  • Check electronic control PCB
  • Check heating element
Dado
Jun 21, 2014 | Ariston Technologies Washing Machines
Aqxxf 129 What has to be done to correct an f-08 error?
  • Check wiring
Dado
Oct 02, 2013 | Ariston Technologies Washing Machines
Ariston a1435 error 8 flashes what does this mean folks?
For most Indesit (Hotpoint and Ariston) models 'F08' means 'heater relay (possibly) stuck'. 'Check power supply connections to the heater, wiring and module (i.e. PCB) connections' (apparently poor PCB connections are often the cause).
So- if you are not electrically confident and competent yourself, which you may be, you need to employ the skills of a partner, friend or service engineer ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 10, 2011 | Washing Machines
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Mar 09, 2011 | Washing Machines
F-08 ERORR
Error code F08 indicates a sticking heater relay.
Check pressure switch- heater- and control module connections.
Worst outcome is you will have to replace the control module.
Please rate my solution.
Thanks.
Nov 20, 2009 | Ariston Technologies Washing Machines
F-08 is on the display
Error code F08 indicates heater relay stuck.
  1. Check pressure switch connections.
  2. Check heater connections.
  3. Check module connections.
  4. Check and clean pump and or pump filter.
Thanks.
Nov 15, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Stops near end of cycle and on/off light and drying high heat light flash
error code f08-htr relay stuck-ckeck htr not open citcuit-connections on board are clean especialy botton connecters-if still throws error then req new board
Nov 12, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Error messages on my Ariston AVXD109
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Sep 07, 2008 | Ariston Technologies AWD121WH
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
