Question about Tablets & eReaders
Hipstreet Atom is fully charged, yet won't start up properly
I just got a Hipstreet Atom tablet for Christmas. The battery died, so I plugged it in to charge. This morning I tried to turn it on, but it got stuck on this loading screen for nearly two and a half hours. I've tried numerous times to start it up, but nothing is working.
    New Friend:
Take it to geak squad.
Posted on Dec 27, 2013
  • 24 Answers
SOURCE: does not turn on under battery power
Battery may be faulty, perhaps you can swap with another user to rule this out. Do the battery charge level lights on the back of the battery show a full charge? (Press the rounded square button on the back of the battery itself and note whether the 3 green leds light up or not) Has the battery been calibrated? (You will need the "toaster" style or the DT533A charger to do this). I assume that your battery is secure and properly seated, but try taping it down from the back side just to be sure it is snug. Don't use duct tape, just regular scotch style tape or blue masking tape. Also try laying on your back to hold the unit upside down and power it up. Check the small metal fins that mesh with the battery. They are right above the right side of the windows cert of auth sticker when turned as you would to read it. They are NOT all the same length, do not push or pull them, but if one is bent you may try to straighten it VERY carefully with very small tools.
What happens if you unplug while up and running?
How does the power jack feel when you insert or remove it? any looseness may indicate your trouble. A good tech can repair your trouble. Are you sure that you are not under warranty? HP still sells extended warranty for these machines. My original warranty expired in Sept and I bought extended warranty for another year. I'm in central MO if you are close by at all I would meet up and swap a batt for a minute for you. Also, you may get a lil more usability with a car cord if the problem cannot be resolved at all.
Best of luck! I love my tc1100 and the older brother tc1000 as well. I have several of each.
Posted on Apr 05, 2008
SOURCE: Nokia N800 Tablet
I had the same problem with the n810. I was using a non-oem battery and the connections were a loose fit causing the battery not able to charge.
If you take the battery cover off, hold the battery firmly in place. Connect the charger and make sure battery is charging, then press the boot button. If it boots and stays on, then shuts off when you stop holding the battery. Then you probably have a loose connection or a bad battery. Also try cleaning the connector with a pencil eraser and alcohol.
I had to wedge tthe battery in place. You can find a spare battery with a desktop charger on Ebay for around $10US.
Posted on Dec 09, 2008
  • 119 Answers
SOURCE: hp tc4400 doesn't seem to charge
please bring it back to where you purchased it and let them see the problem..
Posted on Oct 18, 2009
  • 846 Answers
SOURCE: non responsive (battery is fully charged). Screen has frozen up.
There is a reset button at the bottom (insert paper clip in pinhole). If all attempts trying to unfreeze it fail, you may have a logic board issue. Are you sure the Kindle powers up? Try to power up your Kindle with a different battery. If that fails, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Posted on Jun 08, 2010
  • 846 Answers
SOURCE: The kindle screen is frozen on the sleep mode, the
Try a different charger. If that fails too, you have a logic board issue. Amazon2_bing.gif should give you a replacement. If you're out warranty, you can get the part at Kindle Repair and there is a guide that shows you how to open a kindle and install parts at Kindle Repair Guide.
Posted on Jun 09, 2010
Can I buy a power cord that charges while you are using the tablet?
all tablets can charge while you are using them, on rare occasion the battery will completely discharge and will need to be charged to the minimum before operating the tablet.
Feb 06, 2016 | Hipstreet Flare 2 9 inch Tablet with 8GB...
My tablet will not turn on or charge at all!
Are you using the supplied Samsung charger? Many times if your not using it, the tablet won't truly charge.
Aug 10, 2015 | Samsung Galaxy Tab 4 8.0 3G T331 16GB GSM...
My tablet won't charge.why???please help!!
Is your battery removable? Try removing the battery and then plugging in the tablet. If the tablet runs on only the AC power, then your battery is shot.
Dec 29, 2013 | Dell Latitude XT2 Tablet PC
Hipstreet titan android tablet
Try to boot to fastboot and REflash a stock firmware.
Jul 02, 2013 | Tablets & eReaders
I have had my kindle fire since christmas 2011. i went to go turn it on saturday and it is just dead... the battery was 3/4 full just a few minutes before so i know it wasnt that. i went immediately to go...
Will it charge when connected to your computer then recover your data. Open replace the battery with a fully charged one to see if the charge circuit is at fault. Buy a new one
Apr 03, 2017 | Amazon Kindle Fire
My Nextbook 7 won't turn on
Every tablet has a button sequence, the reason being for a fresh restart. Either you unplugged it before full recharge, or didn't use proper charging adapter or cable.
There is a solution to avoiding this but first get tablet started by:
Hold power button and volume up button for eight seconds, release and hold power button again, tablet should turn on.
If not, do the opposite hold power button, volume down for eight seconds, then power button. You need to do this with proper adapter and charger you tablet came with plugged in. You may also need to do this more than once.
Once your tablet has started up, the way to avoid this is to swipe right on screen until you see settings app, should be round looking similar to a sprocket, or clock gear.
Open settings / display / sleep. I set mine for 30 mins.
Now you no longer need to power off you tablet manually, thus skipping the button sequence process.After unplugging from charge adapter you will still need to press power button to start.
Hope this helps I have yet to have this problem again, and remember to always let your tablet fully charge before disconnecting.
Jan 11, 2012 | Tablets & eReaders
Tablets & eReaders Logo
320 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
