Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
EP719 DVI port stopped working
DVI stopped working today after the display told me to use YpBpr because DVI was compromised. I can get it to come on for a few seconds but then the display just turns off. Tried factory reset with Power, left, left, menu, still no luck. Calling optoma was useless as it isn't supported.
  • Troy Dec 29, 2013
    I have replaced this capacitor an a few occasions ( i
  • Troy Dec 29, 2013
    I have replaxed this cap a few times (I have many in stock) but only due to the fact that the display won't come on at all. I don't think it is the cap this time due to the fact that I can use rca to get a picture; as well, I do get a pic for a few seconds with DVI before it cuts out. If your pro opinion is still the cap then I will do it, I can do it in about 20 min now! lol
  • 5 Answers
SOURCE: optoma ep719
There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Bellow you can check in the picture where the capacitor is located.
Notice that in this picture I have already took the bad capacitor out and replaced with two small cords to reach the bottom and test the new capacitor.
To reach this place is not fast, several layers of plastic and metal must be removed, but is not a hard task to take the capacitor out and replace it for another.
It works just great! Now it is back on track with awesome image.
Posted on Oct 03, 2009
  • 5 Answers
SOURCE: optoma ep719 will not power up
Try this:
SOURCE: OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
Posted on Mar 29, 2010
SOURCE: Optoma EP719 lamp does not come on
I have the same problem. The 10V 3200uf capacitor is bulged. Can't find one on the web. Where did you get yours?
Posted on Apr 18, 2010
SOURCE: How do I access service menu to reset lamp timer for Optoma H56?
In order to reset the bulb counter you need to access the Service Menu:
To access the Service Menu:
Turn on and warm up
press the following sequence:
Up
Up
Left
Give it a few goes, it took me 5 minutes to enter with the right timing. The Service Menu will appear, highlight factory reset and the counter goes to 0. Job done. Cheers, Matt.
Posted on Jan 28, 2011
Link ASUS laptop to Sharp Aquos LCD TV
No, a DVI to VGA adapter will not work. (The TV is looking for the digital signal from a set top box. This is different from the analog signal on the VGA cable.) You need a converter. Your best bet would be a VGA to component video converter. (I am assuming that the Sharp TV has a component video input.) This page has some examples: http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215.html?sorter=productname-en-asc . Note a VGA to component video cable will not work. The VGA to component cables are for projectors that read the RGB signal. The component video signal is YPbPr.
Connect the VGA cable to the converter and the component video cable to the TV and the converter with the computer and TV off. Turn on the TV first and set it to the component video input and then turn on the computer. Then (assuming the VGA port is enabled - adjust in the BIOS if needed) set the computer's video output to the VGA port. (On my Windows 7 laptop, this can be done by right-clicking on the desktop. Choose Graphics Properties and set the display to the external monitor or both. Click Apply and then confirm the change (on the external monitor if using the single monitor). (VGA to Composite video converters also exist if you do not have an available component video input on your TV.)
If your computer is fairly new, you may have an HDMI port. Your TV may be able to read the signal with a DVI to HDMI cable. (It depends on the TV. Not all of them will read the computer's signal on the DVI port. Check the documentation for your model. TVs without a VGA port are less likely to support this feature.)
I hope this helps.
Nov 28, 2011 | Televison & Video
Optoma EP719 Projector "Pulse"
It is one of the fan, it is bent or out of place and cause reptead disturbance at cyclic intervals. The projector must be taken apart and examined on the inside
Jul 22, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
My HP L2335 Monitor wont display anything. I can literally turn it on (the led power light comes on and it turns green if plugged in and I can tell the backlight is on), but nothing will display no...
why not try a dead display on 2 machines 2 PCs
using only 1 data cable at a time why try to confuse it????????
the OSD must work, or the display is bad or the power supply to it is dead.
easy as apple pie.
the monitor has a tiny computer inside it (micro)
on mine, the data lines dead shows NO SIGNAL in the screen
every time you I power up my monitor with data cables pulled off.
best is to read the book for your monitor, and run all the tests it
tells you there,
Mar 13, 2017 | HP L2335 23 inch Monitor
I have an Optima Model EP719 Projector. Suddenly I am getting white vertical lines and can't find a solution for removing them.
I would try switching out the DVI cable first. It could be faulty. This would be the easiest and cheapest solution to check.
Jun 09, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optima EP719 won't power on - when power button
check that the lamp is on securly and that the cover is on securly too.
Feb 02, 2010 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma DLP EP719
Try this: There is a stuffed 10v 3300uf capacitor on the power board. You need to replace it.
Jun 26, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
Soyo dylto32c
The DVI input on this set is meant for picture only.. ex. to display computer picture.
if you want audio with your picture. you must connect to either inputs YCBCr or YPbPr which both of those inputs has audio inputs.
Mar 19, 2008 | Soyo DYLT032C 32 in. LCD Television
EP719 Projector is "Buzzing"
Could be something touching the color wheel
Dec 19, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
32 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
