Question about Mitsubishi Televison & Video
Mitsubshi WS-65315 with no HDMI port and a Blu Ray Player
I purchased a HDMI to DVI converter and I have video. I purchased audio cables and have no sound. What else can I try to make this work?
  • LRussell
    LRussell Dec 27, 2013
    Let me rephrase my question with a little more detail.... I have a Mitsubishi WS-65315 with no HDMI port and a Sony BDP S110 Blu Ray Player. I purchased a HDMI to DVI converter so I have video. The Blu Ray has a digital out coaxial port so I purchased audio cables and have no sound. Will it work on a Bose Wave or am I doing something wrong? What else can I try to make this work?
  • LRussell
    The Blu Ray is a Sony BDP S1100
welcomejee
  • 10594 Answers
SOURCE: hdmi and dvi
No sir, there is not such switch in menu to change input from S video to HDMI or something. Here is one suggestion, Use 3 RCA pins cable (Audio L/R & Video) to connect both unit and check/ remember TV input and same should be selected in TV menu.
Posted on Jul 29, 2008
ohms
  • 1879 Answers
SOURCE: Setting up HDMI / DVI port as a selectable Imput
Do I have to also connect a Audio Cable set with the HDMI or DVI Cable?
Yes, Audio is still separate.
Are the HDMI and DVI ports Bi-Directional?
It goes one-way, Out from the source (DVD Players / some Game Consoles / Sat Receivers), In on the receiving end (Recorders / TV / Projectors).
A Receiver is perfect for your set-up. All Equipments that broadcasts audio/video signals goes into it, then from it goes to whatever Projector / TV you have.
Posted on Sep 08, 2008
SOURCE: Sony KF50we60 hdmi-dvi sound cuts when plugging into a ht-sf2300
DVI = HDMI without the audio connectors. So basically you need to connect your audio in some different way, PS3s allow you to keep your video signal as HDMI and change the Audio signal to component, so that is one way or doing it, not sure if the blue ray players allow you to do this though.
Posted on Jan 11, 2009
SOURCE: Connecting Magnavox NB500MG9 Blu-ray player
could be the hdmi is shot. try unpluuging the unit from the wall for a few hours and try again
Posted on May 10, 2009
satavlad
  • 405 Answers
SOURCE: HDMI and or Receiver problem
While Bluray pluged into the TV change the resolution from AUTO to 720P then plug Bluray back to the receiver and see if it solve your problem.
Posted on Nov 28, 2009
I just bought a phillips blu ray and trying to hook it up to my sanyo 50" plasma through a hdmi i get video but no sound the tv says to use the dvi port and audio 3 inputs but the blu ray does not hav
Hello there, the hdmi cable is a great way to get high definition video from a bluray player to a tv, but if the bluray player is part of a surround sound system you will need to get the sound to the tv separately. There is often a red and white audio terminal in the rear of the bluray player, sometimes located next to a yellow terminal, these are known as a component connection as each component (coloured terminal) is separate and operates a separate function, but all 3 connections can be used together to create a SCART equivalent. You may need to connect an 'Audio Component to 3.5mm jack' cable from the white and red terminals to the headphone/line in socket on the tv.
alternatively, as wilth my player, there is a button on the remote which switches the audio source from component, hdmi, SCART, etc, this may be the same for you.
hope this helps.
Mar 12, 2014 | Televison & Video
Can't get any sound when playing discs through a blu ray player connected via a hdmi cable and DVI adapter.
The DVI adapter stops the audio. Use the audio out ports on the bluray player to connect an audio pair cable to the tv.
Jan 08, 2014 | Hyundai Televison & Video
How to plug the blu-ray into the tv
It depends on the TV inputs. You will need to provide your own cables for most connections. If your TV has an HDMI in, get an HDMI M/M cable of an appropriate length. (Use an online shop for better prices.) This will provide the best picture. (If you have a sound system with HDMI ports, you may be able to go EDBC011 HDMI out to the sound systems HDMI in. Then the sound system HDMI out to the TV HDMI in.) If the TV has a DVI port, get an HDMI to DVI cable (again M/M). For this option, you will also need to connect the audio cable (see below in the composite or component video section).
Alternatively, this Blu-ray player has component and composite video out ports. Note: composite video is limited to SD. For these, you will have to connect the audio cables (RCA l/r audio or digital audio out). The composite video cable is included with the blu-ray player when new. For these, match the colors of the jacks to the wires to make sure that you have them correctly connected. You can put the audio cables to your sound system or your TV, as appropriate for your setup. For some TVs, you may need a RCA audio to 3.5 mm cable (all male ends) or adapter (for example RCA F/F to 3.5 mm M with an RCA audio cable or 3.5 mm F to RCA M/M with a 3.5 mm audio patch cable) . This applies for units with only the PC audio in.
Make the connections with the TV and the video player off (turn off the audio system if you are including that set of wiring). Then turn on the TV and set it to the desired input (use the Input/Source button on your remote or TV). Turn on the audio system (if using one) and blu-ray player.
If you have problems, first try different cables. Try other input connections and try different devices. It's possible for either the TV or the blu-ray player input/output jacks or boards were damaged.
The manual for the EDBC011 is available here: http://www.elementelectronics.com/support_docs/edbco11/edbco11_manual.pdf .
I hope this helps.
Oct 12, 2011 | Element Electronics EDBCO11 Blu-Ray Player
How to connect blu ray player hdmi to my laptop
1) Look at your laptop computer to see if you have an HDMI cable port. This port is roughly half an inch wide and provides both the HD audio and video signal. If you don't, you are going to use a DVI port on the laptop. This is the same port you use to connect monitors to your computer.
2) Plug the DVI-to-HDMI adapter into the DVI port on the laptop with the Blu-ray player. If you have an HDMI port on your laptop, you can skip this step.
3) Connect an HDMI cable to the HDMI end of the adapter. If you have an HDMI port, plug the cable directly into the HDMI port.
4) Plug the other end of the HDMI cable into the HDMI port on the HD television. Power on your television, press the "Input" button and select "HDMI." You can now see the contents from your Blu-ray player on the TV.
Thanks for rating
Good luck
Feb 11, 2011 | Televison & Video
I would like to know if I can connect a HDMI cable from My tv model WS-65315 to a Direct TV HD receiver?
NO> If your TV supports and have HDMI connections and your HD receiver has an HDMI output then you should have no problem displaying Video. Just make sure you change the input signal of your television to HDMI input. After looking at the spec's of this model these are the following inputs you have. your best picture quaity would be to use componet cables instead, which can show full screen 1080i format, your television does not show at 1080p whis is what HDMI is known for.
Connectors
Rear Input Connectors S-Video x 2 - Component x 3 - Composite x 2 - DVI x 1 - RF x 2 - 1 x RS-232C - Audio (RCA) x 6
Front Input Connectors S-Video x 1 - Composite x 1 - Audio (RCA) x 1
Rear Output Connectors Composite x 1 - Audio (RCA) x 1 - RF x 1
Another good option is use to use a DVI to HMDI connector and hook it up this way. But note: you will have to use audio cables for the DVI input.
Sep 28, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Hook up a lg blueray player to mitsubishi medallion 65"
Yes, there is an adapter which will take the hdmi output of the blue-ray and convert it to dvi. You will also need to connect the blue-ray audio out (rca jacks) since the hdmi is both audio and video (digital) and the dvi is video only.
Jan 04, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Is the hitachi 46W500 blue ray compatible
It doesn't have an HDMI port, only a DVI port. You'd have to get an HDMI-to-DVI cable to get a true "digital" signal on the screen, but you'd still have to do your audio with the RCA jacks because DVI is video only whereas HDMI is audio and video.
As far as Blu-ray compatible, yes and no. It's a high-def TV, so if you hook a Blu-Ray player up to it you'll be in good shape but the built-in DVD player will not read or play Blu-Ray movies.
Dec 31, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
Can SPN4235 Support Blu Ray Signals?
After I got over my fustration I did a little more reading and discovered that I could use purchase a
HDMI to DVI converter cable. Since DVI, unlike HDMI, is video only I also had to purchase a digital optical (it also carries audio) cable to get sound. It cost me an additional $70 for the two cables but it was worth it. I reasonably happy with the 1080i resolution which is all my SPN4235 is capable of at least until I can afford a new 60" HD Plasma TV.
Dec 26, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Televison & Video Logo
44 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
