Question about Motorola Mobility MBP33 Baby Monitor
Parent Unit not charging
Parent Unit Not receiving charge. Replaced battery and charger.
My RCA tablet won't turn on and will not charge, what can I do?
If battery is depleted, then no, it will not turn on.
If battery charger is dead, phone won't charge or turn on.
If battery charger cable is broken, tablet won't charge or turn on.
You need to ensure you have a good working charger, and a good cable. Only a known good charger and a known good cable can charge the unit. Borrow or invest in a new charger and cable (they're cheap on eBay).
Only once you know the charger and cable are good can you determine that they are not the problem.
Depending on how old the unit is, it's possible the battery can no longer hold a charge and needs to be replaced. You won't know that though until you first determine the charger and cable you're using are working properly and providing a good charge.
May 07, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
Why won't my charge garmin nuvi 1450 charge
Its the wall charger that's broke ' ask for a replacement ' I did and was replaced with no problems free of charge ..hope this helps you ..
Jul 12, 2014 | Garmin nuvi 650 GPS Receiver
MPB33 motorola baby monitor
For better assistance you can contact our Baby Monitors specialist.
http://www.motorolacordless.us/
Best Regards,
Katy
Motorola Support
Dec 27, 2013 | Motorola Mobility MBP36 Baby Monitor
Base not charging parent monitor
The rechargeable battery will need to be replaced.
Mar 20, 2012 | Angelcare Ac401 Deluxe Baby Movement Sound...
Batterie
You tom tom uses a lithium ion rechargeable battery that lasts at least four hours after charging it fully. To charge it fully, you need to connect it to a charger and allow it to charge for about 2-3hours, if he battery is weak it will loose charge easily loosen its strength easily and if it is dead, it will not hold a charge at all.
What exactly is wrong with your battery? if it is not holding a charge, then i will advice you you first try to use it on another device and plug it for about 2 hours before using it in there, if it works, then it means your battery is still working perfectly fine, but if it does not, then it means the battery is dead and needs to be replaced.
Test your charger also by using it on another device to see if it will charge the device, if it charges it, then it means your charger is alright, but if it does not, then it means the charger is faulty that is why it is not charging the battery. And all you have to do is replace the battery.
Also you need to test the device, by fixing another well tested battery into it, and using a well tested charger on it, if it does not come on, or seem to charge, then it means there is a problem with the connection port or something with the unit.
Hope this information helped.
Jan 07, 2011 | Tomtom GO 700 GPS Receiver
Batteries won't charge w/ on board charging unit.
Since you have replaced the batteries and the charger there is most likely a problem with the wiring.
May 29, 2009 | Pride Mobility Products Jazzy 1103 Ultra...
Battery Charging, Nuvi 35
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
SHARCNET-USA
Dec 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tom tom will not charge using 12 volt charger
I have the same tomtom and it has the same problem. Sorry to say it is the battery. You cant change it it has to go to Tom Tom. I just bought a new one. Hope this helps.
Nov 17, 2008 | Tomtom ONE GPS Receiver
Sony DCR-VX1000E batteries
Li-Ion batteries cannot be charged efficiently with power supplies or NiCad chargers, they need a pulse charger dedicated to Li-Ion batteries. Also, there is a danger in charging with other sources as Li-Ion batts. will catch fire or explode if not charged properly. Please get a charger that is made for those batteries
Jun 19, 2008 | Sony Handycam CCD-TRV37 Camcorder
Blinking and Whining
I had this happen, and I solved it by connecting it to the car charger for a while, then bringing it in and connecting it DIRECTLY to the AC charger for a full charge. (This assumes the battery is not just kaput.)
Here's what I think happens: The AC charger doesn't have enough current capability to run the unit by itself AND keepp the battery charged (bad design), so, if left continuously ON, the battery will eventually drain. In this state, if you shut it off, the unit senses a low-battery condition and will try to charge, but the charging circuit tries to draw too much from the AC charger and the voltage droops (causing the whine) to the cutoff point (causing it to stop charging, another case of bad design). The car charger has more current capability, so it gets the battery charged enough to use the AC charger again.
Nov 28, 2006 | Delphi MyFi SA10113 XM Radio Receiver with...
Motorola Mobility MBP33 Baby Monitor Logo
200 people viewed this question
Top Motorola Mobility Baby Gear Experts
Motorola Mobility
Motorola Mobility
John Gardner III
John Gardner III
Level 1 Expert
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
