Question about Thermador PRDS304US Dual Fuel (Electric and Gas) Kitchen Range
One of the burners on my thermadore stove won't ignite. There is no clicking and no gas. Please advise.
    Top Expert:
  • Thermador Master
  • 9,472 Answers
You have a faulty spark module. Here is the replacement part to order.
Posted on Dec 28, 2013
SOURCE: both ovens do not heat max heat is 150 to 200
good luck.  We have the same range and have had issues with the ovens since the range was installed.  The overn does not heat evenly on convenction or bake.  Thermadore doesn't stand behind the product and neither does the distributor.  They tell us that Thermador isn't standing behind the product so there isn't anything that can be done.  We spent $8000 for an oven that burns the back corners of everything we bake.
Posted on Oct 30, 2007
  • 1314 Answers
SOURCE: Thermador oven/broiler turns off after 5-8 seconds
two things come to mind a faulty safty valve thats the device that the ignighters connect to the other maybe trash stopping the screen on the pressure regulater are any codes displayed on the clock
Posted on Jan 30, 2008
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
SOURCE: Gas stove Thermadore 36 inch Model PGR366 PL Oven wont bake but will broil
this may seem like a silly question if you've already tried it but have you checked the over temp breaker? If you have no idea what I'm saying there is a breaker on the back side of your machine. Of course Thermador is so kind to place it convenietly behind the back panel so you'll have to remove that. There should be a little red button in there somewhere toward the top middle half of the machine I should say. If you press that button it may work.
Posted on Nov 11, 2008
jim_james_43
  • 74 Answers
SOURCE: My Thermador gas& ELECTRIC (RDSS30) range cook
the manual for this is here:
http://www.bshextranet.com/files/techtoolbox/Pro24DF_Care-and_Use_9000236134.pdf
Posted on Jan 05, 2011
Our Thermador Pro-Harmony gas range just started to make clicking noises and it will not stop. Nobody turned the stove on. It started clicking on its own. How do we shut it off?
Usually a clicking sound from a gas range is the gas ignitor/igniter sparking to light one of the gas burners
...Check to make sure all functions are turned off. If all are off
could be a defective switch..check to see if you see a spark at any of the gas burners
Sep 09, 2017 | Thermador Kitchen Ranges
How to replace spark module?
How to replace spark module Todd, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/42129-thermador-spark-module-replacement.html
Thermador Stove Burner Won Light
Burner on Thermador cooktop won light
Mar 22, 2016 | Thermador Cooktops
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
Thermador gas stove top is clicking when not on
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 21, 2011 | Thermador SGS36GS Gas Cooktop
How do you replace the ignition module on stove.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 14, 2010 | Viking Professional VGRT362-4G 36 in. Gas...
Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Nov 29, 2007 | Cooktops
Thermador PRDS304US Dual Fuel (Electric and Gas) Kitchen Range Logo
155 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
