Question about NA Pandigital PhotoliOTouch PANSCN05 4-Inch x6-Inches Photo aSlide aNegative Scanner
Lost the calibration card for the pandigital photo scanner
I need a replacement card for the pandigital calibration card and cleaning tools.
Want to purchase some photo sheets
This is a scanner not a printer. You put photographs or negatives into it and it saves then to SD card or USB.
Pandigital Photolink One Touch PANSCN05 4 Inch x6 Inches Photo and Slide...
Jan 18, 2016 | PANDIGITAL PANSCN05 Photo Scanner with...
Just purchased pandigital scanner microSD does not fit into card reader
Just to be safe, verify that there's not any sort of obstruction in the slot. Some makers place a "dummy" card in the slot to keep it clean for shipping.
Looking at the top of your scanning unit, the mSD card should go in gold contacts facing up & towards the unit with the cut corner to the right (facing the head of the scanner). If it doesn't go with slight pressure, return to the seller.
HTH
Dec 10, 2014 | PANDIGITAL Office Equipment & Supplies
Need help with a Kodak Personal scanner
Kodak is passing the buck. You would think that they could provide a calibration card for their own scanner.
Jan 02, 2014 | PANDIGITAL Office Equipment & Supplies
Scanning is backwards
I just got my scanner yesterday and had the same problem with my FIRST jpg. I looked for a solution and found your posting. I had scanned one page of the instruction booklet from the center fold outwards, not in the direction of the text, but rather sideways across it. That image was mirrored. I did another scan in the 'proper' direction, that is, from the top of the page to the bottom, both as a jpg and a PDF and they came out in a normal, readable form. Perhaps you need to do it a few times if you haven't already? Have you tried calibrating it?
Jun 20, 2013 | PANDIGITAL PANSCN08 Handheld Wand Scanner...
Replacements?
If you go to www.pandigital.net and click on all personal photo scanners/converters, you'll see a picture of your scanner. Click on it. Scroll down to the bottom of the page and there'll be options including downloads. Click on downloads and you'll have to know your product specifications to get the right one, but the manuals are all there, in all languages, so make sure you get English. Hope this helps a little.
Jun 18, 2010 | PANDIGITAL Panscn02 Photolink Scanner
Pandigital mini photo scanner pictures have white lines on them
have a pandigital scanner that worked great for about 500 pics then lines stared to show up, tried cleaning and calibrating but did not help, decided to take apart and found that the glass on the surface of the scan part was dirty, cleaned the glass and put back together works perfect, took about 10 minutes to fix
Sep 05, 2009 | PANDIGITAL PhotoLink PANSCN06
NA Pandigital PhotoliOTouch PANSCN05 4-Inch x6-Inches Photo aSlide aNegative Scanner Logo
180 people viewed this question
Top NA Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NA Office Equipment and Supply Expert? Answer questions, earn points and help others
