Question about Whirlpool AWZ412 Front Load Washer
Door does not engage start - Whirlpool AWZ412 Front Load Washer
May tag over the stove microwave model mmv4205dh-1. After I shut the door and press in the time and then the start button a message comes across saying open/close door.
The door switch is adjustable. It is necessary to take the cover off to access the switch. That means taking the microwave off the wall mount.
Aug 26, 2017 | Dishwashers
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
When top is closed it will not start washing
There is a door switch that must be engaged. Raise your door and look for a small slotted opening in the rime of the door frame. Also, in the same spot, on the door, is a small piece of plastic that goes into the slot on the frame to engage the switch. The switch sometimes will come loose and the plastic piece will not engage the switch. Be sure the switch is still in place. If the switch has moved or will not engage, you will have to reattach it or replace it.
Jun 18, 2011 | Kenmore 24032\24036 Top Load Washer
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Will not self clean
soundsas if theres an issue witht the latch assy not recoginzing teh door is closed, and for safety reasons with out door closing will not engage cleaning cycle
Feb 12, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
On starting washer, terrible rat-tat-tat nose, door lock not engaging....
Try to turn can by hand and see if any noise produced by central bearing
May 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Electrolux EOC6690X Pyrolytic Door won't close properly
if the door lock engagement rod is sticking out then with the door open hold the switch down with your finger then hit start then cancel lock rod should go back letting door close if engagement hook is not sticking out may have to replace switch some are bad about breaking but have been impooved
Dec 28, 2007 | Electrolux EOC6690X Pyrolytic Electric...
Whirlpool AWZ412 Front Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
