Question about Honda 1996 Accord
Engine get hot but fan not turn on - Honda 1996 Accord
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Honda Master
  • 1,632 Answers
Check fuse to power blower and wiring first .
Posted on Dec 27, 2013
Ok when I have my heat fan on my 2006 dodge charger 2.17 it dont run hot but when I turn it off it do our when I turn on the ac it run hot
If the engine is running hot you may be low on coolant. Check this first. If coolant level ok, the rad fan may not be working to cool the engine. If the AC is operational, when you turn it on, the radiator fan should come on telling you the fan motor is ok. You still may have an issue with a fan control related to temperature. This can be caused by a fan relay/wiring/temp sensor/ecm. Make sure the thermostat is functioning properly as well
Jun 21, 2015 | Dodge Cars & Trucks
Why do my radiator fans keep goin when car turned off ba falcon
Engine is still hot... you might need to check your coolant level.
Feb 22, 2015 | Cars & Trucks
Very hot passanger floorboard in 2005 gmc serria
catalytic converter stoped up or tailpipe pluged
Oct 07, 2014 | GMC Sierra Cars & Trucks
Fan comes on when switch ignition on instead of when hot Tazz
If the fan not turning on when car engine getting hot,then car will notice overheating.Click this link below for troubleshooting:---http://technoanswers.blogspot.in/2012/02/car-running-hot.html--------To know how engine cooling system works ,click the link below :----Engine cooling components working?
http://repairhelpcenter.blogspot.com/2011/11/engine-cooling-components-working.html
How does Vehicles Engine cooling system works? http://repairhelpcenter.blogspot.com/2011/11/how-does-vehicles-engine-cooling-system.html
------------How to Replace Engine cooling Fan:-- http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-engine-cooling-fan-on.html
-----------Replace Fan Relay but still Radiator cooling fans not working? http://schematicsdiagram.blogspot.com/2011/12/replace-fan-relay-but-still-radiator.html
----------DIC says "COOLING FAN FAULT"? http://schematicsdiagram.blogspot.com/2011/12/dic-says-cooling-fan-fault.html
---------Where Is Radiator Fan relay and Fuse Located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-radiator-fan-relay-and-fuse.html
This will help.
Thanks.
Feb 09, 2012 | Cars & Trucks
Rad fan on always ofter engine shut off. no hot engine message temperture guage at normal range fan stays on @2-3min after engine turned of regardless of running 1 min or 1 hr.
The ECM gets it messages for heat from the engine coolant temperature sensor. The sensor is probably bad. Since the fans come on right away the ECM is in a safe mode for the engine. Meaning it turns the fans on because it can't read the coolant sensor. As far as the fans staying on for a couple of minutes this is normal when the engine is hot. The ECM does this.
Sep 25, 2011 | 1998 Volvo S70
Radiator Cooling Fan is not turning on when engine is hot.
HOT WIRE THE COOLING FAN USING CAR BATTERY AND JUMPER WIRE.IF FAN DONT RUN WHEN HOT WIRE REPLACE FAN.THE ELECTRIC MOTOR BURN OUT.IF FAN RUN WHEN YOU HOT WIRE IT.THE PROBLEM IS THE FAN RELAY OR OPEN COOLANT TEMPERATURE SENSOR
Sep 03, 2009 | 2002 Kia Rio
Coolant fan not turning and air conditioner blows out hot air.
Re-check the relay to make sure it's still good, then check the fan by hot wiring it to the battery. Also check the temp sensor on the engine. If the check light is on, don't drive it 'till you find out why or you can damage the engine.
Aug 25, 2009 | 2000 Jeep Grand Cherokee
2001 aurora engine heats up when not moving down
Likely the fan(s) not turning on when engine gets hot. Is the check engine light on? Read the code(s) and repair as needed. Check (when cold) the fan(s) for free turning--if seem bound or hard to turn, replace the ailing fan. Check the radiator and reservoir fluid level. Watch the fans as the engine heats up. Feel the radiator area where the upper engine hose connects. It will suddenly turn hot when the thermostat opens. The fan assembly should activate somewhat after. Hopefully, the engine code recognized a defective temp sensor and was replaced.
Aug 11, 2009 | 2001 Oldsmobile Aurora
Coolant fan not working- engine staying too hot
The fan might not be working because the sensor in the radiator could be bad.
Jul 20, 2008 | 2004 Mazda 6
Over heating
Check fan thermostatic switch. Could be in the radiator or by the upper radiator hose on the engine. The thermostatic switch is what turns the fans on when the engine gets hot.Fans are supposed to come on when the A\C is on.
Jun 16, 2008 | 1988 Toyota Camry
Honda 1996 Accord Logo
20 people viewed this question
Top Honda Electronics - Others Experts
John
Level 1 Expert
Bill Boyd
ray gallant
Are you a Honda Electronics - Other Expert? Answer questions, earn points and help others
