Question about Luminara Flameless Candle Remote Control - -
Remote doesnt work
I have tried the battery in various positions, changed the battery, verified the candles are "on." Remote won't pair with candles.
Gave flameless candles as a gift. Largest candle does not work -changed batteries.??
Were they part of a set with a remote control? If so, you will need to move it away from the others and aim the remote only at it until you can "sync" it with the others. If no remote, the bulb might have come loose in shipping. Depends on the style as to whether or not you can tighten it.
Jan 05, 2017 | Crafts & Hobbies
Why won't my samsung smart tv emote wont change chanel
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
  1. TV off
Within 3 feet of TV
PAIRING and RESET buttons:
Please rate if Helpful.
Good Luck !!
May 25, 2014 | Samsung TV Remote Control
Lost Candles manual. What "On" position for timer
"your" candlelamps? Can you give me a brand / model name. I know many brands only switch off with the timer
Mar 08, 2014 | Candle Lamp Home
Cannot get the remote to work
I bought 3 sets of flameless candles, remote does not work in none of them, bought new battery, still not working, one of the candles was missing the spring to hold the battery. Was there any quality control?
Oct 22, 2013 | Merchsource, Llc Home
Remote no longer works despite changing battery, are replacement remotes available?
Usually you can buy replacement remotes, or you can buy a universal remote. What product are you trying to replace the remote too? A bit more detail and we can help better.
Oct 15, 2013 | NORTHERN INTERNATIONAL INC Essential Home...
Sensor
your senor bar could be bad... light a candle turn off the lights and move your wii remote around until you see the little hand... be careful not to knock over the candle... if this works replace your sensor bar
Aug 14, 2012 | Nintendo Wii Console
My remote control for my lg flat screen tv not working i changed the batteries and the light won't go on
Take the remote to any working radio, change radio band to SW, press various buttons of the remote and if you can listen to some clicking noise on the radio, the remote is ok. The problem might then be on the sensor and might need attention by a qualified service technician. You can also try switching off the TV, removing the plug and retry after 48 hours.
Aug 02, 2012 | LG Televison & Video
TV IS NOT RESPONDING TO REMOTE. I'VE CHANGED THE BATTERIES AND HAVE TRIED OTHER SAMSUNG REMOTES THAT WORK ON MY OTHER TVS. ANY SUGGESTIONS...
Sounds like problem is with TV. Make sure the remote sensor on the TV is not blocked, it is located at the lower right part of the front of the TV.
Dec 12, 2010 | Samsung BN5900696A Remote Control
ViewSonic RC00136P Not Working
Open the battery compartment, remove the batteries, and examine
the small springs at the POSITIVE end of each battery holder.
Sometimes these springs get compressed and no longer make
contact with the battery. Use a small knife point or small screw
driver to stretch the spring away from the case until it extends
about 1/8". Replace the batteries in their proper orientation and
try the remote. This worked for mine.
Jul 13, 2009 | Televison & Video
Luminara Flameless Candle Remote Control - - Logo
1,147 people viewed this question
Top Luminara Home Experts
Donni Steen
Tom Chichester
Are you a Luminara Home Expert? Answer questions, earn points and help others
