Question about HP Pavilion Slimline s3600f Desktop PC
How to reinstall the cd tray back inside the computer
  • 111 Answers
I think you should take it to a computer specialist ...
Posted on Dec 28, 2013
How to remove the CD tray from a Gateway computer?
hello,
In these particular PC, you have to open the back case, and look inside for the CD tray, figure out where is the issue carefully.
or how to change it too.
take a note or photo of the tray you want to remove.
Carl
Aug 06, 2014 | Gateway ZX6971-UB30P 23 Touch-Screen...
I can not open my cd it will not ejet
This is happening when it is jammed with some wrong inserted disk ..or it does not make contact with the main board so it has no power to react ..or ..if it was disabled..(in the last case it may open when you manually press the button ..)I suggest to take a look on the tray of the drive ..and see there is a hole on it ..If you insert a paper clip in there and press it will manually open..try to remove whatever is inside and place another disk to verify its functionality ..if it works ..fine ..if not ..try to see if it has the icon in my computer ..and if not try to reinstall its driver , by going to device manager ..and select in the list ...right click and update driver..windows should have its driver built in ..
In case it does not react ..go on the back of the laptop and see that it has a screw (or 3) that holds it in place ..remove them and slide the drive ou t..Place it back and restart ..and make sure it is plugged well ..If it still not working you will have to change it cause it may be damaged..
Another thing you may try after removing the disk or manually open i t..is to insert a windows disk and try to boot from the disk ..(go to bios by pressing F10 on start ..and in there select the cd to be the first boot device ..save the settings with F10 and exit ..). when you boot again it will ask to press any key to boot from cd ..if you have a windows cd inside..and you may reinstall the OS and eliminate any errors..this also mean the drive is functional and probably has a damage on the exit mechanism if t still makes the same after reinstalling windows.
Jan 13, 2012 | HP Compaq nx9030 Notebook
CW099D CD-RW cd tray keeps opening and shutting
check the leads that attach your cd-rw make sure connections are secure
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver
hope this helps you
Sep 13, 2011 | CyberDrive CW099D CD-RW Burner
HELLO I HAVE AN OLD TS-H492 CD/DVD DRIVE PROBLEM IS IT KEEPS OPENING DISC TRAY AND WONT STAY CLOSED ANY SUGGESTIONS
hope this helps you
Sep 09, 2011 | Computers & Internet
THE DVD TRAY NOT OPENIG
make sure that the cd rw/dvd rom is getting enough power test all leads that are attached to the dvd including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back in this should activate the found new hardware wizard
click start control panel administrive tools,computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click to update driver
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps you
Aug 01, 2011 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
Have inserted a disc. can not open disc tray to remove disc
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 27, 2011 | Computers & Internet
I have a sony computer, the model where every thing is built in behind the screen. a CD is stuck inside and i cannot remove. anyone have any knowledge on what to do to remove same?
The CD, DVD or BD drive tray may not open when trying to eject a disc. This can occur if there is a mechanical failure, or if there is a disk stuck in the drive.
Please follow the following steps to resolve this issue:
  1. Because some applications can prevent the drive tray from opening, close all open applications.
    NOTE: If the Roxio DirectCD software is running, eject the CD using the Roxio DirectCD software.
  2. Attempt to eject the drive tray using the eject command of the operating system.
  3. Restart the computer to the BIOS by continuously tapping the F2 key on startup and, while in the computer BIOS, press the EJECT button on the computer.
    NOTE: If the drive tray ejects in BIOS, but not in the operating system, reinstall the CD, DVD drive.
Sep 16, 2010 | Sony VAIO VGC-RB40 PC Desktop
I put a cd inside my toshiba satellite turion 64 but i cant open it to remove the cd.can you hep pleasel
If your laptop has a tray feed cd player and not a slot feed, then look on the tray door, you will see a tiny hold near the eject button. Pish a small paperclip into that hole straight, that is the manual release for the tray and you will get your disc back. The computer does not have to be powered on for this to work. The tray has a mechanical spring that will eject the tray out without any powered required.
Jan 12, 2010 | Computers & Internet
Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
HP Pavilion Slimline s3600f Desktop PC Logo
23 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
