Question about Garden
Gasoline pouring out od carberator,what is cauing this ? help
Hi I have a sears craftsman model #c95052477,i ceand the carb,put new eedle valve in,what is causing the gas to pour out of the carberator? pleae help,and wat es te welch plug do ? and were does it go in the carb?
  • Serguei Zhuravlyov
    Serguei Zhuravlyov Dec 29, 2013
    Same thing recently happened to me...In my case, water got in the carburetor bowl and frozen float down, gas was flowing through the carb just with gravity. Checked out youtube, cleaned the carburetor, good to go!
    Filmmaker:
    Uploaded 5 video answers.
  • 40 Answers
You said you replaced the needle, but did you replace the seat that the needle moves in to? If the seat is bad, it may not be sealing well even when the carb is full of gas and the float is pushing the needle in to the closed position. If it is a tecumseh carb, you can buy a kit that comes with a new needle, new seat, new bowl gasket and new bowl nut gasket. The kit is about 3 dollars and should fix you up. The kit i am referring to is part #1606506, but you may want to check and make sure that will work for your model. Regardless, the same pieces that fit your carb should do the trick.
Posted on Feb 16, 2014
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,632 Answers
Replace rubber primer button
Posted on Dec 27, 2013
Testimonial: "hi,do you really thinkthat chaning the primer button will stop the gas from pouring out f the carb or could it be the float is off of alignment ? thanks john"
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
I need a service manual for snow thrower model# 247.888160
manual can be had at link below, if carb. is leaking fuel chances are it has dirt in it and requires rebuilding which I will post a second link to.
press the helpful button
Craftsman 247 888160 Owner Manual
How to Fix Snow Blower Carburetor
Oct 15, 2015 | Craftsman Sears Snow Thrower Manual Model...
I found Gasoline inside My Craftsman riding mower engine, this is the third time I have to drain it and replace it with new oil, somehow gasoline is flowing inside and I have no idea where it is coming...
There is a fuel shut off solenoid on the bottom of the carb and it is most likely stuck open. The gravity flow of the fuel causes it to force through the carb, through the intake valve, through the cylinder and then into the oil sump.
Oct 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Carburator floods
Possibly the needle valve in the carb. fuel bowl.
Jun 05, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a 2004 fxd i have gas pouring out of
its a carberator fault the float valve is stuck down and its flooding the carb,,strip the carb and free off the float valve it may need a new one fitted!!!
Jan 23, 2010 | 2004 Harley Davidson FXD - FXDI Dyna Super...
Gasoline comes out when I pulled out the spark plug. Without the spark plug a large jet of gasoline comes out when I crank it. The gasoline in the tank is gone by the next day and comes out the spark plug...
The carb's needle is stuck open remove carberators float bowl and replace the needle and seat for the float or you can spray the needle and float with carb cleaner while working the float up and down this may work if you don't want to replace parts.
Aug 05, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Engine wont fire has spark gas not getting thruogh
pour alittle bit in carb & if it starts then it could be the fuel pump or the fuel lines
Jul 19, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
269 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
