Question about HP Officejet 7500a E910a All In One Inkjet Printer
HPe910a all in one wide format the touch screen does not respond
The display it's on, but doesn't work
2 Suggested Answers
BaronVonNuke
  • 1915 Answers
SOURCE: My touch screen doesn't respond to touch and I
Does it respond to any touches or is it greyed out? This problem can be caused by either a bad touch pad or a defective scanner. Try accessing other options on the front such as the administrative menu. If those work, then the scanner might be bad or locked? Lift the automatic document feeder lid and check the lock on the left hand side to make sure the scanner is not locked. Restart the machine as well, could be an intermittent problem or static discharge.
Posted on Jun 07, 2011
Canon touch screen stop working
If the copier still works but the touch display won't respond, you will need to have the touch screen panel overlay replaced. That is a very common problem that happens to those touch displays.
Sep 02, 2014 | Canon imageRUNNER 3035 Black and White...
How to reset touch screen
If the copier works but the touch display won't respond, you will need to have the touch screen panel overlay replaced. That is a very common problem that happens to those touch displays
Hi my n97 mini is malfunctioning, the touch screen seems to have a mind of its own coz it decides to response to touches wen eva it like and it is really frustrating.pls i need serious solutions coz i
Hi there.First make backup all the important files/data to mmc or simcard and Format it by using the short code or select "RESTORE ALL"from the phone setting.Even after this the problem persist the only thing you need to do is to change the TOUCH.This sensitive thing will not work properly due to the dis-alignment.So, my comment is to contact mobile repairing shop.Good luck
Feb 20, 2012 | Nokia N97 mini Smartphone
Sony bravia picture to large for screen
Sir press the screen mode button in your remote below input select button, press the screen mode button repeatedly to select smart, 4:3, wide, zoom, or 14:9.
  • Smart- Display conventional 4:3 broadcast with an imitation wide screen effect. The 4:3 picture is stretched to fill the screen.
  • 4:3- Display conventional 4:3 broadcast non-wide screen TV in the correct proportions.
  • Wide- Display wide screen 16:9 broadcast in the correct proportions.
  • Zoom- Display cinemascopic letter box format broadcasts in the correct proportions.
  • 14:9- Display 14:9 broadcasts in the correct proportions. As a result, black border areas are visible on the screen.
Sep 27, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I bought a computer with 15.4 Wide XGA display. It has not arrived yet. I want to put photos in. I believe the wide XGA will distort the photos. Can I make the view normal?
The size of the screen and its shape has no importance if you use a decent imaging program like IrfanView - in it the image will be resized to fit the screen and if the shape doesn't matches the screen will have black bands to compensate.
The only time a distortion will be encountered is when you will try to use it as a desktop background in the Stretch format - just select Center and all will be fixed. Of course the best solution is to crop and resize the picture to fit the screen exactly - you can do that with Irfan.
Aug 10, 2011 | Fujitsu LifeBook V700 Notebook 15.4...
Touch screen stopped working
Have you tried to recalibrate the touch screen in the Set Menu? If so, and it still doesn't respond, then the touch screen might have gone bad. This is something you should have a dealer repair. About a $200.00 repair.
Apr 28, 2011 | Husqvarna Viking 1
Touchscreen not responding
hello sir,
format your phone and try to access your phone.if the touch is still not responding then you can find out that there problem. then contact the company service center of your mobile and change the display screen.just go on with the company for changing the display screen for your mobile. they will replace the original touch display panel for your mobile.this is best for your mobile.because some local service may replace some local display. which may affect the other components of your mobile.
thank you
Jan 02, 2011 | Samsung Star GT-S5233 Cell Phone
MY SAMSUNG GTS5233A'S TOUCH SCREEN IS NOT RESPONDING TO TOUCH.
The mobile screen would have been damaged or a device connected to your screen my be defected .Try to remove your touch screen safe guard sticker then clean the display. If this doesn't work out for you consult your dealer for replacement of new display.
Thank you !!
Jun 17, 2010 | Samsung Star GT-S5233 Cell Phone
Touch screen doesn't respond sometimes
- calibration your phone
- if doesn.t work ,... change the touch screen
Apr 28, 2010 | Nokia 5800 XpressMusic Smartphone
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
HP Officejet 7500a E910a All In One Inkjet Printer Logo
15 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
